Technical info on fridge
Submitted: Sunday, Sep 09, 2007 at 20:12
goldiedingdangdo
Have a 40ltr Engel that has died, I have a fair bit of nouse on most things and thought if there was some troubleshooting, technical info I might have a go at sorting the source of the problem, compressor is just not kicking in.
Thanks Ian
Reply By: Member - Roachie (SA) - Sunday, Sep 09, 2007 at 20:43
Ian,
Does it play-up on both 12v and 240v?
If so, I would say it'll be a technician's job.
If it works ok on 240v, but not on 12v, then I would suggest you need to check the cable and the 12 volt power source/wiring etc
Roachie
261270
Reply By: GerryP - Monday, Sep 10, 2007 at 20:06
Could be many things. However, I agree with Roachie's comments above - check that first. Otherwise it's a series of tests to see where you have power and where you don't. By following the circuit from the lead, through to various components and to the compressor, you may be able to isolate the problem. You may also like to check the thermostat/on-off switch for continuity in the on position. Unfortunately, there are electronics in there which can make it rather tricky to fault find.
Please remember to be very careful, 240 volts can kill so try to limit testing to continuity where possible, otherwise switched on to 12 volt.
Good luck
Gerry
261432
