3rd Battery for 100 series
Submitted: Sunday, Sep 09, 2007 at 20:52
Pyro 1
Hi, I am thinking about putting a third battery into my 100 series std diesel. It already has a dual system controlled by a TJM IBS controller which I have found to be fantastic to date. Question is has anybody put a third under the bonnet on a 100 series and if so what, where how big? And one other question is what would be the best way to wire into my existing system? Thankyou.
Reply By: Topend - Monday, Sep 10, 2007 at 06:26
Opposite Lock have a battery tray for a third battery in the TD100. It is positioned on the passenger side at the rear of the engine bay and fits an N70.
May or may not fit the standard diesel but worth checking out.
Topend
261305
Follow Up By: Pyro 1 - Monday, Sep 10, 2007 at 07:14
Thanks Topend i will have a look.
522646
Reply By: Hopper51 - Monday, Sep 10, 2007 at 08:46
I fitted the Opposite Lock 3rd tray to my TD100 about 12 months ago. Everything you need to put it in and relocate items such as the fuel filter is supplied. I suppose you could piggyback it with the 2nd battery and make the two into one large battery. I would probably make it a separate circuit with its own controller so if one battery fails it doesn't affect the other battery. I have used a Redarc isolator for years with no problems at all - it is significantly cheaper than the likes of the IBS unit.
Chris W
261319
Follow Up By: Member - George (WA) - Monday, Sep 10, 2007 at 10:50
Hi Chris, are you able to post some pictures of your battery set up ?
522675
Reply By: TD100 - Monday, Sep 10, 2007 at 20:18
i also have a 3rd 100ah gel cell controlled by a piranha controller and piranha tray in my 100 TD leaving the 2 main batteries in parallel for winching duties and also have the ARB compressor mounted behind the battery against the firewall,plenty of room to get at or around them still.the aux fuse panel is also in that corner.would post pictures but dont think i can??i stand to be corrected.cheers Paul
261437
Follow Up By: Pyro 1 - Monday, Sep 10, 2007 at 20:43
TD100, just wanted to know what brand the tray was and did they supply extra brackets for relocation of fuel filter? Thanks
522801
Follow Up By: TD100 - Monday, Sep 10, 2007 at 21:29
it was a piranha tray,a flat strap from the tray that bolts to the firewall mounts the filter assembly,still easy to access to change filter,cheers Paul
522815
Reply By: Member - Rod M (NSW) - Tuesday, Sep 11, 2007 at 10:50
Pyro I have a 3rd battery fitted in the back of the truck, I found there was enough space behind the fridge slide in my draw set up to mount a sealed gel cell, ( confirmed with the NRMA that it would not void my policy before doing the set up ) which runs the fridge & 2 power out lets, it stays clean, is
well out of the way & uses space that was previously wasted.
261528
Follow Up By: Pyro 1 - Tuesday, Sep 11, 2007 at 13:50
Thanks Rod,
Firstly nice rig. I had thought of putting one in the back but wanted to fit it under the bonnet if i could.
Thanks again
522919
