Advice on buying a camper trailer
Submitted: Sunday, Sep 09, 2007 at 22:06
ThreadID: 49511 Views:7019 Replies:11 FollowUps:8
Hi. We do a lot of camping and have finally decided to buy a camper trailer. We are looking at a hard top/floor (either will do, more to do with sealing out the dust etc). Ant recommendations. Limited budget. Have looked at a TREK and was considering purchasing, until I read comments on this site. Any advice would be appreciated. Cheers
Reply By: Olcoolone- Sunday, Sep 09, 2007 at 22:36
How much are you wanting to spend, is it going off road, on average how many days away are you going to spend in it on each trip and what are you towing it behind.
Regards Richard
AnswerID: 261286
Follow Up By: karen68 - Sunday, Sep 09, 2007 at 22:42
Thanks Richard.
In response to your questions
1. Unfortunately finances only allow us to go to $20K max.
2. Yes it will go off road
3. At the moment we camp for 3-4 days, 6 times a year, and do a 4 week trip every second year. We would camp more often on weekends, if we had something that was easy to put up.
4. We have a AWD Ford Territory
Look forward to your reply.
FollowupID: 522627
Follow Up By: Olcoolone- Sunday, Sep 09, 2007 at 23:03
You have a hugh range to choose from, we have aTrakShak that we love.
The TrakShak has 2 queen size beds and heaps of room for the kids, one thing with TrakShaks is you could buy a secondhand on for $15000 plus but make sure it is an Australian built one ....even though the newer Chinesse ones seem OK.
It takes us about 10 minutes to set up and about 30-60 minutes to pack up depending on how organised we are.
There are plenty of other good brands as well and I would not worry to much what other people say as some like one brand over another....it's personel choice and you may like something on one then the other.
You might want to have a look at "Australian off road camper trailer" forum...heres the link and the have a trader section.
http://www.campertrailers.org/index.html
Regards Richard
Two things to consider are.
Trailer brakes
Water storage
Don't worry to much about suspension types either.
When you start going over $10-12000 you go into a differant range of trailer...but don't think the cheaper ones are not as good.
FollowupID: 522636
Follow Up By: Shaker - Monday, Sep 10, 2007 at 09:00
Don't worry about suspension? Hmmm .......
Most trailer failures are in the suspension.
FollowupID: 522654
Follow Up By: Olcoolone- Monday, Sep 10, 2007 at 10:08
Is it is leaf, leaf with shocker or indapendent
FollowupID: 522668
Follow Up By: Member - Mark E (VIC) - Monday, Sep 10, 2007 at 10:53
"...Don't worry to much about suspension types either...."
I went about the selection of a camper trailer in a slightly different way.....
Firstly, I wanted something reliable that wouldn't fall to bits. I've travelled on many of these badly corrugated roads...Gunbarrel, GCR, Cape York, Tanami etc and by far the most common failure of trailers is in the suspension and secondly in chassis cracks. So I looked long and hard at this FIRST. From my research (though this will always be a topic of discussion) I found Track Trailers, who build trailers for the military, for them to transport sensitive electronic equipment and sattelite dishes etc) to have a very impressive setup on the TVan. It is called MC2 suspension and is fully independent, with King Spring coils and Koni Shocks. I have seen it in operation on video and it is very impressive when loaded correctly.
Track also have an older model called the Desert Eagle which features this suspension....and that's what I bought. In terms of all the little 'luxuries' like stainless steel kitchen etc, I was less concerned about this as it's pretty useless if the trailer is broken down on the side of the road in the outback. I opted for lots of storeage, lockers, electric brakes, 240/12v wiring and a nice simple, practical design.
Different people will value different things as their priorities and I second the suggestion to have a look around the campertrailers.org website and the associated Yahoo Group. There is a wealth of information and many very experienced travellers on those sites.
Good luck in the search.
Mark
FollowupID: 522676
Follow Up By: Shaker - Tuesday, Sep 11, 2007 at 23:33
Mark, that is exactly what I did, disregarded all the bells & whistles, a stainless steel kitchen isn't going to get you home with a broken spring!
I also bought a Track Desert Eagle with MC2 suspension.
FollowupID: 523060
Reply By: Gronk - Sunday, Sep 09, 2007 at 23:17
Not sure what you mean ??? A hard top means a KK or Aussie Swag etc ??
A hard floor means the same sort of thing also ??
Please explain ??
AnswerID: 261295
Reply By: Member - Kevin J (QLD) - Monday, Sep 10, 2007 at 07:17
Best p-lace is www.campertrailers.org
This is a Yahoo forum but has a trader page which could well suit you.
Kevin J
AnswerID: 261306
Reply By: Member - Oldplodder (QLD) - Monday, Sep 10, 2007 at 07:54
If you have a Territory, are you considering serious off road, or more just dirt roads? Or an lengthy dirt roads at all?
This sets the level of suspension you may require.
We bought ours 12 months ago, and going through the exercise of soft floor / hard floor, and suspension narrowed it down for us.
Off road / 4wd trailers are heavier for obvious reasons, which is all more weight to tow, and push around on site.
The other thing that helped to narrow down the models was the kitchen set up we wanted.
We ended up with a 2nd hand soft floor, have been tent campers for over 20 years so no concern about soft floor, and just seemed less hassle on site having to get it level, or packing the hard floor on an uneven site.
AnswerID: 261310
Reply By: PradoTrev - Monday, Sep 10, 2007 at 08:32
Hi Karen
Should have a look at camperon canvas campers $20k will get you brand new with all the bells and whistles.
Not just just great canvass (I on my second camper 1st was on road second off road) but a top quaility trailer as well.
Take it every where and it works a treat.
They have a new soft floor out that is just so easy to set up and pack up.
I have a super camper but the new one they have just released is a shorter version say 10 ft on the ground not 14 ft
I saw it at the Adelaide mid year camping show, I alwas like to check out what I missed out on.
http://www.cameroncanvas.com.au/
I like everyone believe what i buy is the best but I have had no problems with the product or the after market back up.
TM2CW
Trevor
AnswerID: 261318
Reply By: PBob - Monday, Sep 10, 2007 at 11:53
Have a look at a Sundowner at Mudgee NSW. They are very well built and individually built to orderand good value.(Iam not related to this company).
AnswerID: 261340
Reply By: Member - Crazy Dog (QLD) - Monday, Sep 10, 2007 at 12:31
TRACKABOUT - the only way 2 go...TRACKABOUT - the only way 2 go...TRACKABOUT - the only way 2 go...TRACKABOUT - the only way 2 go...TRACKABOUT - the only way 2 go...TRACKABOUT - the only way 2 go...TRACKABOUT - the only way 2 go...TRACKABOUT - the only way 2 go...TRACKABOUT - the only way 2 go...TRACKABOUT - the only way 2 go...
Grrr!!!
AnswerID: 261348
Follow Up By: Kev M (QLD Bound) - Monday, Sep 10, 2007 at 12:43
Who was that again?? :))
Kev
Russell Coight:
FollowupID: 522686
Follow Up By: RFLundgren (WA) - Tuesday, Sep 11, 2007 at 23:37
I can vouch for the Safari from Trackabout....great camper.
Richard
FollowupID: 523061
Reply By: Member - Earvin (NSW) - Monday, Sep 10, 2007 at 14:19
Check out Camper trailer forum
Heaps of good information on this forum as well.
AnswerID: 261366
Reply By: Scoof - Monday, Sep 10, 2007 at 17:41
Hi Karen68,
Have a look at a CUB we have had one for 5-6 years and had no probs with it
Cheers Scoof
AnswerID: 261389
Reply By: Sand Man (SA) - Monday, Sep 10, 2007 at 19:08
Karen,
A hard top camper will not necessarily guarantee good sealing of dust, etc.
I have a soft topper and when the camper is folded up and the weatherproof cover installed over the top and zipped up, no dust gets in.
Hard top campers are more for the quicker and easier convenience of erecting, (minus the Annex) and giving you a raised floor.
Generally, the Hard Top campers will not give as much internal room as a Soft Top.
Both styles have their advantages and disadvantages, buy generally, a Soft Top being significantly cheaper, will provide more "bang for buck".
Bill
AnswerID: 261418
Reply By: karen68 - Monday, Sep 10, 2007 at 22:14
Thanks everyone for your advice. We will keep looking and attend a few camping shows. Any suggestions about the best shows to attend in Sydney or Melbourne?
Karen
AnswerID: 261457
