Fuel tank issue
Submitted: Monday, Sep 10, 2007 at 17:30
ThreadID: 49527 Views:2047 Replies:5 FollowUps:4
I have a problem with the long range tank on my GQ. When it's filled right up it seems to have a leak which lasts for 100kms or so. It comes from on top somewhere. I phoned the previous owner and he said that it only did it once for him probably bs). He thinks it was probably the hose which lets the air out when the tank fills?? I really don't know how to go about working out a fix. Are tanks easy to remove/install? Should i be taking it to somewhere like ARB? Any info appreciated.
Reply By: Kev M (QLD Bound) - Monday, Sep 10, 2007 at 18:01
Is it possible that the gasket from the filler/breather has perished??
and when full leaks from there.
To remove and fit the tanks are relatively easy to do, easier if you have a hoist and an extra set of hands.
Cheers Kev
Russell Coight:
AnswerID: 261398
Follow Up By: Brew34.5(SA) - Monday, Sep 10, 2007 at 20:08
Thanks Kev. Something to check.
FollowupID: 522789
Reply By: Grungle - Monday, Sep 10, 2007 at 18:50
Not sure about the GQ's but the GU's have an access panel in the rear cargo area (under the carpet) that you can remove and access the sender assembly of the tank. Find this and then fill her up to see what is happening.
A problem with some LR tanks is that the barbs or replacement hoses are slightly different to each other and you really need tight clamps (or 2 clamps in my case) to make for good seals.
David
AnswerID: 261410
Follow Up By: Brew34.5(SA) - Monday, Sep 10, 2007 at 20:05
Hi Grungle, yes the GQ does have an access panel and i have sussed this out but unfortunately it doesn't allow me to see quite far enough across to where the hoses are. I hope that this is all thats wrong with the tank. I think i may have to remove it :( . Thanks for the response.
FollowupID: 522786
Reply By: al - Monday, Sep 10, 2007 at 19:27
i had the same problem with my gq patrol the wrong type of plastic pipe was used it tends to go very hard does not matter how hard u pull on the clamps it still leaks replace pipe should fix problem it fixed mine who installed tank ?
regards
al
AnswerID: 261426
Follow Up By: Brew34.5(SA) - Monday, Sep 10, 2007 at 20:07
G'day Al, I'm unsure as to who did the installation. How did you access the pipe? It sounds like this may be the problem. Cheers
FollowupID: 522787
Follow Up By: al - Tuesday, Sep 11, 2007 at 16:13
hi brew
if it the same as mine you fill both tanks through the original filler one over flows into the other you access the pipe top end by removing the cover under the wheel arch
the pipe goes over top of main tank then on to second tank which is easy access the hard part is feeding the new pipe over the top of original tank took me about 2 hours may need second person to help when you reconnect at y junction top end.
hope this helps i used stainless steel clamps they use on turbos.
regards
al
FollowupID: 522951
Reply By: Willem - Tuesday, Sep 11, 2007 at 04:31
Brew
I had a temporary problem with fuel leaking out of the cap when me mate cross threaded the screw-in fuel cap. If its not that then it has to be a venting problem.
Tank should be easy enough to uninstall(if thats the word). Use a couple of trolley jacks to balance the tank and lower it after removing all bolts.
AnswerID: 261470
Reply By: Truckster (Vic) - Wednesday, Sep 12, 2007 at 07:36
There is an oring on the fuel sender which nobody replaces when they put new tanks in, thats where I would start
failing that, just lower th tank using a trolley jack, and look that way -ITS HEAVY WHEN EMPTY! theres only MM clearances in there when you lower the tank too, real PITA job, but ya gotta do it.
you do know the inspection panel in the right rear wheel arch allows you to see in there a little easier... specially if you have a body lift.
AnswerID: 261662
