Thermo Fan/s on 95 Series Prado TD
Submitted: Wednesday, Sep 12, 2007 at 14:49
Wizard1
I've searched the archive and found plenty of info about thermo fans like the Davies Craig, successfully used in the Patrol 4.2.
Currently looking at replacing the power sapping clutch fan. I would like to know if anyone has details on the results of fitting these fans to a 95 series Prado TD.
I don't need theories and hearsay on what such a setup might or might not do or what effect it had on a different vehicle, but facts on an actual case eiither successful or not.
Davies Craig have no fitting details but suggest, as they do, that I will get better cooling. So I guess I'm sussing out the practicalities and likelihood of success.
Reply By: Olcoolone- Wednesday, Sep 12, 2007 at 16:11
Yes and no.
But I can't tell you anything about why and why not to use thermo fans.
Regards Richard
261724
Reply By: Member - Phil G (SA) - Thursday, Sep 13, 2007 at 08:08
No replies :-(( Once you eliminate theories and heresay, theres nothing left!!!!
I've had a lot to do with Prado diesels since they were released in 2000 - have never heard of anyone fitting electric fans, probably because the viscous coupling rarely is required to lock in.
261840
