lightforce xgts unimpressed
Submitted: Thursday, Sep 13, 2007 at 20:45
ThreadID: 49634 Views:3702 Replies:11 FollowUps:21
ok i know im going to get flack from this but.......i got a set of xgts ..supposed to be the ants pants off lights...... i also have a set of nane lights.....both pencil beams.............i used the clear blue covers on the xgts as was supposed to give a whiter light ........now as i do a lot of distance night driving.......i realy want to see things....but im unimpressed by these new light force lights i got......and for the $500 i payed there no better at distance than my $180 nanes...ive even gone back to the clear covers with a little improvement but .....not what i was expecting ....................was i expecting to much from these lights.....??????????is there a trick to them i don't know .....any ideas...????
Cheers Bundy
Reply By: Derek from Affordable Batteries & Radiators - Thursday, Sep 13, 2007 at 20:53
Hi Bundy
HID is a better quality light.
If you want better light than the XGT's then think about a set of HID's. My HID's on my cruiser are great. The only problem is they are so bright when you dip to low beam it is like you have gone blind. I am currently looking at importing HID inserts for popular 4wds low beam.
Derek.
AnswerID: 261952
Follow Up By: Member - BUNDY BOY (WA) - Thursday, Sep 13, 2007 at 20:56
Derek........is it true you can upgrade xgts to HID......
FollowupID: 523416
Reply By: Derek from Affordable Batteries & Radiators - Thursday, Sep 13, 2007 at 21:12
Yes, but like most things it is easier to buy the right product from the start.
HID conversion kits are quite expensive.
AnswerID: 261958
Reply By: Member - John - Thursday, Sep 13, 2007 at 21:35
Bundy, as Derek said, HID's are great, but you really need the HID headlights as well. 35 watt low and high, 50 watt spots, 6000k temp, brilliant white light.
John and Jan
AnswerID: 261964
Reply By: Bonz (Vic) - Thursday, Sep 13, 2007 at 21:49
Lights are just ways of throwing different wavelength heat out in front of an object. If your Nanes are the go stick with them.
Best lights I ever had were 100w aircraft landing lights 5.5 inch. Great lights, spread and depth, but I like my XGT's.
The blue lens would have been reducing the light you would see from the XGT's. Blue light has the lowest reflective properties and cause what u see is really reflected wavelengths of heat, with blue light u see less. So I am not surprised they were better with a clear lens.
AnswerID: 261966
Follow Up By: Member - Charlie (WA) - Thursday, Sep 13, 2007 at 22:35
I agree Bonz, best light I ever had too. Great beam, tough & not to expensive. Crappy swivel though.
FollowupID: 523438
Follow Up By: Bonz (Vic) - Thursday, Sep 13, 2007 at 22:39
The swivels on mine were the earlier ones and once they were locked in they didnt move. Mate had the same thing with the elbow in the swivel bolts and they were useless
FollowupID: 523445
Follow Up By: Stu050 - Thursday, Sep 13, 2007 at 23:02
The best lights that I had were also the 5 inch aircraft landing lights, athough using the 150W sealed beam bulbs.
A very good pencil beam, although the mounting system was cr@p.
FollowupID: 523455
Reply By: Member - Doug T (Qld) - Thursday, Sep 13, 2007 at 22:04
Geez Bundy,
What do you want to do ....sizzle the guide posts. I have 170mm Lightforce and they light up reflectors at 3.2 klm,
I take it that have used relays.....maybe get a bigger Alternator , a $350.00 one like mine ,
Been workin a bit eh
AnswerID: 261968
Follow Up By: Doggy Tease - Thursday, Sep 13, 2007 at 22:13
Try nearly $800 for a new one for the truck mate,nearly had a corronary whn i got thebill.....:)
rick.
meow.
FollowupID: 523429
Reply By: Member - Robert G (WA) - Thursday, Sep 13, 2007 at 22:25
Bundy,
I'm not trying to be a smart arse but have you tried adjusting the lights (rotating to change between pencil and spread).
I have the 240 blitz and have used them before and find them pretty good. I had IPF lights on my last car and the blitz are better than they were.
AnswerID: 261973
Follow Up By: Member - Roachie (SA) - Thursday, Sep 13, 2007 at 22:32
Robert,
You can't adjust the spread/pencil output on the XGTs in the same way as you can with the Blitz.....
Roachie
FollowupID: 523437
Follow Up By: Member - Roachie (SA) - Thursday, Sep 13, 2007 at 22:35
Robert,
Roachie
FollowupID: 523439
Robert,
Roachie
FollowupID: 523441
Follow Up By: Bonz (Vic) - Thursday, Sep 13, 2007 at 22:37
Spot on Roachie
FollowupID: 523442
Spot on Roachie
FollowupID: 523443
Spot on Roachie
FollowupID: 523444
Follow Up By: Member - 'Lucy' - Thursday, Sep 13, 2007 at 23:10
Robert you are excused, however I feel I must point out that you have just been 'super nobbed' by the best in the business.
Yep! Roachie and Bonz
FollowupID: 523458
Follow Up By: Muzzgit [WA] - Thursday, Sep 13, 2007 at 23:56
Is that the knob on the end that stops ur hand slippin off hahaha
FollowupID: 523464
Follow Up By: Member - 'Lucy' - Friday, Sep 14, 2007 at 00:01
Your words not mine - but I do like them. (LOL)
And
Stuttering knobs to boot
FollowupID: 523465
Follow Up By: Member No 1- Friday, Sep 14, 2007 at 08:03
wish you two would stop stuttering
FollowupID: 523473
Follow Up By: Member - Robert G (WA) - Friday, Sep 14, 2007 at 09:36
Ouch, Gulp. lesson learned (hopefully!)
FollowupID: 523494
Reply By: David from David and Justine Olsen's 4WD Tag-Along - Friday, Sep 14, 2007 at 07:39
I too am not overly impressed. I am going to make one a spread using the special cover. I also think the red lens would be better because it would retain night vision when the lights are off as well.
I find the XGT pencil beam very sensitive to appropriate alignment. get them aligned well, an the light is not too bad. The problem is, the mechanism that locks them is next to useless on corrugations. Mine never stay put.
Best light setup I ever ha was on my rally car. 5.5 inch aircraft landing lights and Cibie Super Oscars
David O
AnswerID: 261997
Reply By: Member No 1- Friday, Sep 14, 2007 at 08:01
get rid of the lens covers......what ever cover
we tried them out when shooting cats and fox's using nightforce hand held spotlights...the amount of light that gets thru is usless for distance shooting....but they do hilight fox eyes at close range say up to 50m...but past that bloody useless
and as some else said above...give em plenty of heavy gauge cable and relay etc etc which can provide the grunt needed to drive them....voltage drop is also a killer
AnswerID: 262004
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Sep 14, 2007 at 08:30
Nudie, you are right on with the cable. Some people like to give their light systems a handicap right at the start.
I hope you take your blue glasses off when shooting as you would need to use a 24v battery on a 12v light to overcome the lenses.
FollowupID: 523479
Follow Up By: Member No 1- Friday, Sep 14, 2007 at 08:42
yep i do cos i cant see a bloomin thing with them on
FollowupID: 523482
Reply By: Member - BUNDY BOY (WA) - Friday, Sep 14, 2007 at 08:32
Thanks everyone.......yer have rewired them again...and as said a little better......but still not up to what i was expecting......don't get me wrong .....there's a load of light out front.....i was just expecting more in the straight down the road.line...............maybe i will have to find some landing lights for cutting power ......
Cheers Bundy
AnswerID: 262012
Follow Up By: Member -Signman - Friday, Sep 14, 2007 at 14:07
Just how far do you expect to 'see' down the road- and what range are you getting now...
I would think that seeing about 1.5km down the road would be more than enough for normal night driving!! But then if you want to push on at 130kph then that may be different...
FollowupID: 523533
Follow Up By: Member - 'Lucy' - Friday, Sep 14, 2007 at 14:27
Yeah! my type of guy.
Bundy boy, I like turning night into day at 1.5 - 2.0 kms as well and to do so I employ 3 Ironman Supa-Nova HID'S up on the top.
Besides what Bonz says, by the way he is a one eyed, blue heat, lightforce eater who is so smitten with heated blue crap that he wouldn't admit under the threat of torture that anything else post Lightforce is better.
Mate don't waste your money on blue, red, purple, pink, polka dot pieces of plastic Chit.
HID'D are the way forward young man.
Fry the eyeballs of a gnat at 500 - 1000 metres.
Toast a Roo as you pass
Make a GU boil (which doesn't take much I must admit)
Go for it I say.
FollowupID: 523534
Reply By: TerraFirma - Friday, Sep 14, 2007 at 10:16
HID's rule..! I have some Xenon Hella's , one pencil and one spread , the pencil has a range of 750 meters, hell I can't see that far so it don't matter. Great lights and great technology HID but you gotta be careful you don't blind anyone out there..
AnswerID: 262033
Reply By: Muzzgit [WA] - Saturday, Sep 15, 2007 at 12:26
Bundy, if you don't wanna spend too much, try the IPF 900XS. See if you can get one of the spot for a test, to compare.
Hell, lets get together and compare my 900XS against your XGT!
4WD monthly also recon the Cibie Oscar SC are pretty good.
AnswerID: 262236
Follow Up By: Member - John (Vic) - Saturday, Sep 15, 2007 at 19:25
"4WD monthly also recon the Cibie Oscar SC are pretty good"
Hmmm!!!! They must have had a big advertisement that issue??
FollowupID: 523783
