Spare wheel lifter?
Submitted: Thursday, Sep 13, 2007 at 23:56
The Don
Getting a bit long in the tooth and am finding it increasingly difficult to lift the spare wheel up on the back door. Current vehicle is Jackaroo and looking at replacing it with a Pajero with massive looking
wheels. Can get the spare down O.K., push it off and chase it down the road, but getting the flat up on the carrier is the problem. Has anyone come up with a
bright idea on this topic? Any assistance would be very much appreciated. Don.
Reply By: Dave B (NSW) - Friday, Sep 14, 2007 at 00:31
Don, Telstra appear to have some good lifters on the back of their Nissan Patrol utes that have a canopy on the back.
Out in our area they usually have 2 spares on the back.
Not sure who make them and also not sure if they could be fitted to a wagon door.
Maybe someone here has more clues than I about them.
261986
Follow Up By: The Don - Friday, Sep 14, 2007 at 22:54
Many thanks for that Dave, checked it out but several other replies look more promising for my circumstances. Cheers, don
523677
Reply By: Kev M (QLD Bound) - Friday, Sep 14, 2007 at 06:44
Opposite lock have an attachment for their wheel carriers, it has a small hand winch that allows you to winch the tyre up.
Cheers Kev
| Russell Coight:
261991
Follow Up By: The Don - Friday, Sep 14, 2007 at 22:57
Many thanks Kev, looks promising, may be able to bolt or weld a jib on in front of the carrier, will experiment! Cheers, Don.
523678
Reply By: Member - Alex B - Friday, Sep 14, 2007 at 08:16
Hi Don, 'Roscos' is one of the companies that supply Telstra with canopies with spare wheel lifters.
Their Melb Number is 1300 767 267.
they may be able to help you.
Alex
262008
Follow Up By: The Don - Friday, Sep 14, 2007 at 22:58
Thanks Alex, the
forum has produced several good suggestions for me to try out. Cheers, Don.
523679
Reply By: Trevor W(Brisbane) - Friday, Sep 14, 2007 at 08:34
I have a Pajero and what they do have, that is a pain, is the Pin that takes the spare on the rear metal carrier bracket.You have to feed the spare over this pin which goes through a Stud hole on the rim. Cut that off with a grinder and weld a plate on so that it sits inside the wheel centre,this allow you to rotate the spare to align the wheel studs while putting the spare on the bracket.This was the method used on the older Pajeros.You could consider a hinged bracket so that the spare would rotate vertically down to allow you to load the spare into the bracket and then hinge it back up into its place using an extension handle to get leverage.
262014
Follow Up By: The Don - Friday, Sep 14, 2007 at 23:02
Thanks Trevor, a sound tip if I end up with a Pajero, the Jack just has a lipped lug to drop the wheel on and then able to turn it to locate the studs. It's the lifting up bit that hurts! Cheers, don.
523680
Reply By: Gerhardp1 - Friday, Sep 14, 2007 at 11:47
The solution from left field is to change the trend that sees us getting weaker - to beat the battle of the bulge and the encroaching weakness, I am now lifting weights.
I can recommend this - in 3 months I have gone from leg pressing 60kg 15 times and falling over afterwards, to 230kg 15 times and walking easily. Pushups from 0 to easy 20.
My Jackaroo spare is now easy for me to lift back on (rotated tyres the other day) whereas it had become a real struggle. Not to mention the 5" waist reduction :) I may have to stop soon, the missus is looking at me strangely........
262049
Follow Up By: The Don - Friday, Sep 14, 2007 at 23:11
Thanks Gerhard, I love your solution, but being a skinny old coot that has been around for three quarters of a century I doubt that body building is going to be very successful. Cheers, Don.
523682
Reply By: Sand Man (SA) - Friday, Sep 14, 2007 at 18:04
Got a long handled shovel?
Place the blade on the ground and put the handle end on the step.
Roll the wheel up the handle into the approximate position and swivel the wheel 90 degrees. You may need to place one foot on the shovel blade to stop it from lifting.
The wheel will now be at waist height and it's just a short lift to the "hanger" without back strain.
262098
Follow Up By: The Don - Friday, Sep 14, 2007 at 23:06
Many thanks Sand Man, I like that idea, cheap and simple. Will try it out as soon as Jack comes home. Just done 200,000 service and the CPU packed it in, near enough to $2,500 plus labour, so your solution sounds great! Cheers, don.
523681
Reply By: Member - Roachie (SA) - Friday, Sep 14, 2007 at 21:23
Depending on whether you've got a roof rack or not. If you have then the system I use may be able to be adapted for you.
I run 35" muddies and they sit up fairly high (top of the tyre is 2 meters off the ground).
I have made up an aparatus that utilises a 2000lb electric winch to lift my spare tyres. It works very
well and takes the back breaking part of the task away....
Roachie
262140
Follow Up By: The Don - Friday, Sep 14, 2007 at 23:15
Thanks Roachie, I leave the roof rack home most times to save a bit of fuel, but several good ideas have been suggested for me to try out, never a dull moment! Cheers, Don.
523683
