GPS / Street navigator
Submitted: Friday, Sep 14, 2007 at 10:31
ThreadID: 49646 Views:2972 Replies:10 FollowUps:16
Anyone know if there is a machine to do both ? Would like a street navigator that can be used as a normal GPS as well ie background topo map , waypoints , goto etc
Reply By: Wontok - Friday, Sep 14, 2007 at 11:38
There are a number of PDA type GPS's on the market that come with a street pilot type program.Copilot Route 66 and the like and you can also use Oziexplorer on them
AnswerID: 262047
Reply By: Robin Miller - Friday, Sep 14, 2007 at 14:00
Seriously check out the Garmin 276c Stevo
I have personally organized 10 Gps's this year for different users and applications, of which 4 have wanted the lot and this unit delivers it.
You need a budget of about $8-900 though if getting from USA
and $1500 in buying Aussie.
This thing can even beep when the cars voltage drops to much.
Robin Miller
AnswerID: 262064
Follow Up By: Stevo 62 - Friday, Sep 14, 2007 at 14:05
Thanks for the advice
FollowupID: 523531
Follow Up By: The Explorer - Saturday, Sep 15, 2007 at 10:17
Robin - mate of mine has been trying to get hold of an in car GPS unit that displays maps and at same time (ie on same screen) Speed and Odometer/distance travelled. There are a number of GPS units that do this but their screens (and the numbers) are too small to read clearly in the car. Currenty he is running a Magellan XL (big screen with Dast topo - good maps) and a Garmin 60cx with the large number screen.
So - I get the impression the 276 maybe what we are after - there are no shops here (unless I drive to perth 200Ks) that stock it so chasing your opinion on how good the 276 is. Screen looks great - assuming speed and odo can be display over map? Are the numbers big enough to read easily when driving? Will shonky maps work on it?
Any advice appreciated. Thanks.
FollowupID: 523716
Follow Up By: Robin Miller - Sunday, Sep 16, 2007 at 07:16
With the 276c , its screen only a centimeter larger than the XL's at 3.8 inch , but its quality, resolution and brightness and significantly ahead. In terms of dots it has approx 4 times as many and about twice the brightness.
The value of this for me is that I need to use 1.5 magnifying glasses to focus close in and they bring the screen up and because of the resolution nothing suffers so readability is great.
There are multiple ways to display the numbers you refer to both as overlays and beside the maps.
I chose to use mine my displaying the map with 4 overlaid variables 1 in each corner. I like to show car voltage speed position and ETE.
As overlays they are not quite as readable as the option to display them with a white background on one side of unit.
When watching my speed I use this mode - as I can drive and just read numbers without glasses.
You can also display 4 variables of your choice only across the whole screen and here they are so big you can read from well outside the car.
UNlike most others the 276c has two distinct modes of operation an Automotive mode and a Marine mode which can together deliver some 10 definable screens.
I switch mine between auto with city navigator and marine with Shonky maps on it which I prefer over T4A because of the contours which a easier to read for me.
Robin Miller
FollowupID: 523851
Follow Up By: The Explorer - Sunday, Sep 16, 2007 at 09:13
Thanks Robin - sounds like its the GPS he has been looking for. Good thing is my mate gets to pay for it and I get to play with it!
FollowupID: 523878
Reply By: glids - Friday, Sep 14, 2007 at 15:19
You could check out the GPS Australia forums.
Someone asked a similar question there - see:
http://www.gpsaustralia.net/forums/showthread.php?t=2874
The HP PDA unit (model rx5765) would be worth looking at at the current price ($100 cashback).
Many of the PDA based GPS units will allow voice direction using proprietry software (Sensis, Tomtom, etc) that comes pre-loaded, and you can add/load OziExplorer (CE edition) with maps on SD chips for other off-road work. However, as far as I know, you cannot get voice direction on these maps - they only show the map data plus your location, direction, speed etc and any waypoints you may have loaded/saved.
Search the above forum for further info.
AnswerID: 262073
Follow Up By: Member - Oldplodder (QLD) - Friday, Sep 14, 2007 at 16:01
If you put waypoints and a route into Oziexplorer it will give you voice commands. But you need to preplan.
FollowupID: 523556
Follow Up By: Member - Oldplodder (QLD) - Friday, Sep 14, 2007 at 16:13
Also, :o)
I have the Asus 636 PDA with co-pilot and Ozieplorer CE, and has built in GPS.
Friend has HP PDA with external GPS aerial.
Mine works well except I can not run both programmes at the same time on my PDA, while he can.
FollowupID: 523559
Follow Up By: Sand Man (SA) - Friday, Sep 14, 2007 at 18:46
What you need then is Franson GPSgate. Allows multiple programs to share the one virtual port.
I run Oziexplorer and CoPilot on the Dell Axim PDA at the same time.
The only "problem" I find is that you need to start Oziexplorer first. CoPilot takes up the full screen and you need to close it to access Ozi.
With just Ozi running you can access the switcher bar to swap to another application without shutting it down but not so with CoPilot.
TomTom is even worst. It will not share anything with another program, even using GPSgate, therefore I now use CoPilot as a preference.
Bill
FollowupID: 523601
Follow Up By: Member - Oldplodder (QLD) - Friday, Sep 14, 2007 at 20:41
Thanks sandman.
Did try gpsgate.
Didn't work.
Got onto copliot tech help and they agreed it wouldn't work.
Yes, the problem is copilot.
FollowupID: 523647
Follow Up By: Sand Man (SA) - Saturday, Sep 15, 2007 at 20:24
What version are you running?
CoPilot 6 works very well with GPSgate and other programs.
TomTom Navigator 6 is the dog that won't behave on mine.
Bill
FollowupID: 523791
Follow Up By: Member - Oldplodder (QLD) - Saturday, Sep 15, 2007 at 20:40
Thanks,
I am running early ver 6 and an upgrade is available.
Might try it.
FollowupID: 523795
Reply By: Member - GeeTee (NT) - Friday, Sep 14, 2007 at 16:35
I agree with Robin. I have had a 276C for a couple of years now. Used it here, New Zealand and Canada... works great. Loaded topo and T4A 1.2 for the Canning Stock Route in July ... great.
I have just bought a 60Cx to used when we go hiking, that also looks like being the goods.
AnswerID: 262081
Follow Up By: StormyKnight - Friday, Sep 14, 2007 at 18:47
Just wondering on the 276C, do I just put my Oziexplorer jpg file & the associated map file on an SD card & choose the right mode on the 276C & it will work just as in oziexplorer?
Richard
FollowupID: 523602
Follow Up By: Robin Miller - Monday, Sep 17, 2007 at 13:28
Hi Richard
The 276c uses vector maps only - not Ozi types - also doesn't use SD card but its own proprietry type
Robin Miller
FollowupID: 524146
Reply By: CSR-Petenjen - Friday, Sep 14, 2007 at 16:50
Also have a look at the new Magellan CrossoverGPS
AnswerID: 262084
Reply By: Member - Straps (SA) - Friday, Sep 14, 2007 at 18:07
Garmin Quest does me well
AnswerID: 262100
Reply By: Member - Brett (WA) - Friday, Sep 14, 2007 at 19:31
Stevo, I've got a HP iPAQ 2490 and with that, I jumped onto the Johnny Appleseed website, bought a PDA mount and GPD reciever. I also bought TomTom for road use and OziExplorer for off road use. Works a treat and I can also check email with the wireless capability as well.
Cost a bit but it's more than what I need. I recommend it!
AnswerID: 262124
Reply By: Member - Doug T (Qld) - Friday, Sep 14, 2007 at 21:29
Hey Stevo
Check this out GPS
AnswerID: 262142
Follow Up By: Muddy doe (SA) - Friday, Sep 14, 2007 at 22:13
Ahhhh - great to see the page back up!
New address? Looks good.
FollowupID: 523671
Reply By: Stevo 62 - Monday, Sep 17, 2007 at 12:48
Thanks for all the suggestions . Looks like there are a few good options
AnswerID: 262659
Reply By: 0ldfosil - Thursday, Oct 04, 2007 at 16:31
Don't know if this has been mentioned before ,but you can buy Tracks 4 Australia direct from the maker for $40.00 on ebay. Thereby saving yourself a heap of money from the price of the commercial version. I've been using this version for the last six months on a GPSmap60csx and travelled all states except SA and found the maps to be great. Only found a few places that weren't covered and will consider sending this info for inclusion on his update site.
AnswerID: 265025
Follow Up By: Skippy In The GU - Friday, Oct 05, 2007 at 07:38
Why pay $40 when it's a free download , also you should try Shonkymaps it's also a free download.
FollowupID: 526997
Follow Up By: 0ldfosil - Thursday, Oct 11, 2007 at 00:08
The freebee doesn't have as much detail as the one you buy.
But thanks for the comments you've made up my mind for me. the tracks I've been on that aren't on this data base or any other for that matter, I'll keep for myself, I wouldn't want people like you out in the places I go to. Hope you can find your way home from the carpark. If it ain't scratched it ain't been bush.
FollowupID: 528064
Follow Up By: Skippy In The GU - Thursday, Oct 11, 2007 at 08:49
I don't understand it's the same program.
What makes you think I only travel on the blacktop and you drive on tracks that your the only person in this world that can
Maybe it's best if you did buy the paid version, as least it only shows tracks that only AWD can go on
FollowupID: 528103
