tyre pressure alert
Submitted: Saturday, Sep 15, 2007 at 01:51
ThreadID: 49688 Views:4250 Replies:7 FollowUps:8
Hi all,
does anyone use one of those tyre pressure moniter systems ?
I am thinking of fitting them to our new 70series and van tyres.
Have looked around but cant find much imfo.
Any imfomation on them would be appreciated.
Cheers...........BIGDOG
Reply By: Kev M (QLD Bound) - Saturday, Sep 15, 2007 at 07:13
Bigdog
Read this post
Cheers Kev
Russell Coight:
AnswerID: 262188
Reply By: Member - Doug T (Qld) - Saturday, Sep 15, 2007 at 07:33
There is one I seen just recently on the web, it has crappy bits of wire habnging down to touch the road when the tyre goes flat, plus all the wiring needed , the best way is the wireless system , One of them has the sensor on the stem, that could get stolen or torn off, the one I would buy if I had the dollars os the fully internal system , the sensors are located in the inside of the rim and send data to a reciever on the dash , I had the url for that but can't find it,
Doug
AnswerID: 262195
Reply By: Michael A (VIC) - Saturday, Sep 15, 2007 at 07:37
I am planning to fit the Autron system to my new Troopy when it turns up.
http://www.autron.com.au
Michael A
AnswerID: 262197
Reply By: Member - Doug T (Qld) - Saturday, Sep 15, 2007 at 08:08
Here is the external system that probably would be ideal
Pressure & Temperature Monitoring System
AnswerID: 262206
Follow Up By: Kev M (QLD Bound) - Saturday, Sep 15, 2007 at 08:15
Shame it only monitors 4 tyres, not very good if towing :((
Cheers Kev
Russell Coight:
FollowupID: 523700
Follow Up By: Member - Roachie (SA) - Saturday, Sep 15, 2007 at 09:22
Check out the ones that Derek from ABR sells. Called the Jette 400, they can monitor up to 22 tyres simultaneously. They use the external monitor. This means you only need to buy enough monitors to cover the number of wheels you have "on the ground" at any one time.
For example, I have 8 wheels/tyres, but only 6 of them are ever on the road at any one time. So, instead of having 8 sensors in the 8 tyres, I only have 6. If I do get a flat tyre, or decide to rotate my wheels etc, I can keep the same sensor on the same position of the rig, so I don't have to re-program the damn monitor inside the cab.
The issues of the senders being stolen and/or knocked off can be covered too (to a certain extent).
To avoid them being stolen, they come with a lock-nut which threads onto the valve stem and can be held firmly in place with 3 very small Allen bolts. This would make them a PITA to remove (for airing up/down etc), so what will be doing at the next opportunity (when I get my tyres balanced etc), will be to get a second valve stem fitted. This will be one of those short solid stems they use on mag wheels etc and I will get in mounted more towards the inside of the rim and so that it doesn't protrude outwards.
That should help to alleviate the 2nd issue (of the units being accidently ripped off in rough terrain).
FollowupID: 523709
Follow Up By: Member - Brenton H (SA) - Saturday, Sep 15, 2007 at 13:11
Hi Roachie.
I recently had a reply from Derek (see thread 49479) re the performance of the tyre monitor system.."My tyre pressure monitors worked 100% on the car but I had to fit 15mm metal valve extenders on the van as the valve stems are very short and the rim / van was creating interference and I was getting a sensor drop out every now and again."
Might pay to keep that in mind if you are going to locate the senders further into the rim. Also I beleived (and I may be wrong here ) that it is illegal to drill any further holes into the rims??
FollowupID: 523730
Follow Up By: Member - Roachie (SA) - Saturday, Sep 15, 2007 at 18:47
G'day Brenton and thanks for the thoughts.
With regard to the signal strength, I think the fact that the planned new valves would be fully metalic (as opposed to the standard rubber type), the signal strength should be okay. Given that the system is set to be able to monitor a tri-ax semi trailer (22 wheels), you would imagine that it should be able to pick-up the signalsfrom a close-by camper trailer or caravan.
Secondly, if they wanted to ping me for something like drilling another hole in my rims, it would be well down on the list of things they would be worried about (chief among them the 3500kg minimum weight of my Patrol)...... hahaha. However, I don't believe the drilling of a 2nd hole is illegal, as there are a number of blokes who fit those internal bead locks which require a separate air inlet via a hole drilled in the rim.
Cheers mate
Roachie
FollowupID: 523775
Reply By: Member - GeeTee (NT) - Saturday, Sep 15, 2007 at 08:57
I have a TPMS system. Previuosly handled by one of the forum sponsors I think ( the system rejected the name ! ! !) l but now Jax Tyres I believe. Excellent setup and saved me a couple of tyres by alerting me before the tyre deflated too far. Had it in the Prado we just sold and now swapped it to the new Patrol.
AnswerID: 262213
Follow Up By: pickle - Saturday, Sep 15, 2007 at 09:59
Currently testing these on my vehicle for the last two months Gates Wireless Tyre Monitors
Initial indications are impressive and will have report out on Pajero Club Public Forum next week.
FollowupID: 523712
Reply By: Martyn (WA) - Saturday, Sep 15, 2007 at 11:27
Big Dog,
I fitted Sensatyre wireless monitors about two years ago, just about to take the other three out, had enough. The unit for a start kept falling out of the vents onto the floor when going over rough ground. Always had the RR sensor which was dicky, used to come on eventually, forgot how to change from the high pressure setting to the low setting so the alarm was always on when running low pressures, not the devices fault I know but it wasn't easy to change from high to low. The LR sensor started leaking air after about 18 months, very very slow leak that eventually caught me out. I didn't have the device one when the pressure was to low.
For me I just buy good tyres and check the pressure regularly. I spent a bit of money and bought an infra red temperature gun I monitor the temp more often now, seems to work quite well.
Getting them fitted in the first place was hard enough, all the tyre houses wanted $25 plus balancing for each wheel to fit them, and then they wouldn't take responsibility if any of them got damaged. Did it myself in the end for nothing, it was easy enough as long as your careful. Don't forget to get the wheels balanced after fitting.
Keep the shiny side up
AnswerID: 262230
Follow Up By: BIGDOG24308 - Saturday, Sep 15, 2007 at 17:10
Thank you all very much, you have given me much to work with.
Cheers..........BIGDOG
FollowupID: 523756
Follow Up By: acdc - Friday, Sep 21, 2007 at 19:12
I've had a Sensatyre kit for 3 years with no problem, they have 2 year warranty, why don't you contact the supplier.
FollowupID: 524932
Follow Up By: Martyn (WA) - Saturday, Sep 22, 2007 at 01:06
ACDC,
I bought via the internet from a company over East, they wanted me to send the unit back to them so they could figure out what was going on. I took the valve sensor out of the tyre and in all honesty I never got around to sending it back to them. A second one developed a small air leak so that was two out of four, that was it for me, all be came to hard, I didn't want the problem when I was miles from anywhere. Took the safer option, I'm taking the rest out this weekend.
FollowupID: 524961
Reply By: Member - barry F (NSW) - Saturday, Sep 15, 2007 at 18:26
Hello Big Dog, guess it comes down to how many dollars you've got & the sort of terrain you cross plus the value of the tyres you are running & availibilty in remote situations.We have just bought the simple system from www.aussietowmate.com.
As Doug from Qld says there are wires, but they are all supplied with the kit. Crappy connection plug between vehicle & van, so we are in the process of fitting a quality plug similar to van plug arrangement ($15.00). The system is easy to install & is very simple. Just hope it works!! Better still, hope it doesnt have to work.
But we only stick to the black top with 4x2 twin cab towing a 16 foot pop top. Good luck
AnswerID: 262299
