Mounting and dustproofing a toolbox for offroad camper.
Submitted: Saturday, Sep 15, 2007 at 17:33
ThreadID: 49709 Views:2699 Replies:2 FollowUps:5
Just need some advice on the best way to mount an alloy chequerplate toolbox on the A frame, and also the best way to dustproof the lid? The toolbox is 1100 x 370 x 410. Thanks in Advance Brew.
Reply By: Member - Luke (SA) - Saturday, Sep 15, 2007 at 18:06
G,day Brew,
I would weld some angle to your draw bar, flush with the top. Then put some 50x3 (minimum) flat bar on the inside of your box and put a couple of bolts through that and through the angle on the draw bar.
The flat bar only being there so the bolts don't pull through the alloy.
Another way you could do it is build a frame out of angle around the base of your box, weld a couple of flat bars across the bottom, weld or bolt frame to the draw bar (if bolting, same principle as above with angle on draw bar) and bolt the box to the frame you have made.
I'm not the best at explaining things like this without using my hands lol so I hope you understand
Cheers Luke
AnswerID: 262292
Follow Up By: Brew34.5(SA) - Saturday, Sep 15, 2007 at 18:11
Hi Luke, thanks seeing you cant explain well without using your hands maybe you can do it for me lol. I would make sure there were a couple of brews in it for you as this is Mrs Brew as you can see still cheeky.
Thanks again Dawn
FollowupID: 523763
Follow Up By: Member - Luke (SA) - Saturday, Sep 15, 2007 at 18:38
Hi Dawn,
Is this a case of Stuart not wanting to do it so your doing the home work for him lol
I could do it for you if you like
Cheers Luke
FollowupID: 523772
Follow Up By: Brew34.5(SA) - Saturday, Sep 15, 2007 at 19:49
Hi mate...........as a welder i am a good storeman lol.
FollowupID: 523786
Follow Up By: Olcoolone- Saturday, Sep 15, 2007 at 20:23
Hello Brew, I can help you out with out sealing stuff.
Regards Richard
FollowupID: 523790
Follow Up By: Brew34.5(SA) - Saturday, Sep 15, 2007 at 20:39
Thanks Richard. Where abouts are you? ( I know its just around the corner somewhere) PM me if you don't want to post the details on here. Cheers Brew
FollowupID: 523793
Reply By: outback epicurean - Saturday, Sep 15, 2007 at 18:29
Similiar to last reply, put a galvanised toolbox across the A frame using flat steel inside the box and boled through the flat steel and toolbox through the A frame. Used the rubber door seal stuff around the top where the lids closes down. Also ran silicon rubber up the corners as they are not sealed. Also, the lid faces the back of the trailer. Had no problems at all with dust or water getting in though only used for all the extra stuff so nou amajor problem anyway.
good luck
AnswerID: 262300
