firewood in the outback
Submitted: Saturday, Sep 15, 2007 at 22:46
ThreadID: 49723 Views:2782 Replies:9 FollowUps:5
Hi All , Me and a mate are heading out to innaminka on 29th sep from Melb via the corner for three weeks , should i take a chainsaw and is it difficult to get firewood in these areas we are a bit unsure as its our first time to this part of the country.
Thanks for any information you may be able to help us with.
Grant M
Reply By: Member - Kim M (VIC) - Saturday, Sep 15, 2007 at 22:54
Grant
A chain saw is'nt necessary. Pick up wood as you go along.
Kim
AnswerID: 262350
Follow Up By: 98nav - Saturday, Sep 15, 2007 at 22:57
Thanks Kim , Thats one less item in the back.
Grant
FollowupID: 523824
Follow Up By: Blaze - Saturday, Sep 15, 2007 at 23:10
Hi 98nav
Not much wood in what they call the town common camp site, but as Kim says just collect it on your way on yor day trips around the area you can collect plenty.
If you have desert parks pass you have more areas to choose to camp in.
FollowupID: 523825
Follow Up By: 98nav - Saturday, Sep 15, 2007 at 23:23
OK Thanks Blaze,
I just signed up as a member of EO so now i can get purchase a desert pass.
Thanks for reminding me about it
Grant M
FollowupID: 523828
Reply By: Member - Bucky (VIC) - Sunday, Sep 16, 2007 at 04:47
We just pick it up, along the way. You will need about 1/2 of what you recon you will need.
Found that if you look along dry creek beds, you will not have to go too far, off road.
Chainsaw not needed.
Cheers Mate
Bucky
AnswerID: 262378
Reply By: MEMBER - Darian (SA) - Sunday, Sep 16, 2007 at 09:06
Yep - skip the chain - heavy and overkill for the job - I usually pick up a cheap carpenter's saw from the hardware just before we go bush - for about $10 you will get a very sharp cut - you can run through thick and hard tree branches in no time, where needed.
As the others have said you can soon pick up wood, but the saw enables you to target a few logs for longer burning. Don't forget to gather wood well out of towns - there's nary a twig near the main camp areas !
AnswerID: 262402
Reply By: Member - Terry G (NSW) - Sunday, Sep 16, 2007 at 09:24
Grant
From the Desert Parks Pass Information booklet:
"Chainsaws are not permitted in the desert parks. If you are travelling and have a chainsaw with you, dismantle the major components of the machine and render it inoperable before you enter any of the desert parks."
Tessa
AnswerID: 262404
Reply By:- Sunday, Sep 16, 2007 at 09:48
G'Day Grant,
Last year one of our group became designated "firewood gatherer"
Best find was a 2 - iron at Innamincka
Brought it home with us.
Rolande
AnswerID: 262413
Reply By: Sand Man (SA) - Sunday, Sep 16, 2007 at 09:51
Yes, forget the chain saw.
You should only collect fallen timber and I find any saw isn't necessary. What doesn't fit in the main fire surround will, once it's burnt down a bit.
Popular Camping areas are becoming increasingly difficult to find timber close by and it is better to collect some on the way in.
I always carry a couple of bags of "fire logs" which are compressed something-or-other that burns as good as, or better than most timber and even leaves "embers" as the fire dies down.
This gives me three or four nights supply, "just in case".
Bill
AnswerID: 262415
Reply By: Member - John and Val W (ACT) - Sunday, Sep 16, 2007 at 10:06
Hi 98nav,
If you are going out to Coongie Lakes (strongly recommended) its gas fires only.
As others have said, collect firewood as you go and away from camping sites and you will not need a chainsaw. Carry an axe to break up larger branches. Avoid huges bonfires so the wood supply lasts longer.
Enjoy your trip,
Val.
J and V
- Albert Einstein
AnswerID: 262417
Follow Up By: Max - Sydney - Sunday, Sep 16, 2007 at 18:04
If you go to Coongie (magic) and cannot cope with no fire, you can camp at Kudremichie Outstation about 25 km back from the Lake.
We stopped there two nights in June, and loved it. Others did go back to the outstation as they needed the fire.
Max
FollowupID: 524005
Reply By: DIO - Sunday, Sep 16, 2007 at 10:46
If when you travel into these bush areas and you don't see much in the way of wildlife particularly the small reptiles, mammals and the likes, it's probably because someone has pinched the fallen timber they once used as their shelters. Keep it in mind, don't go overboard with huge bon-fires.
AnswerID: 262426
Follow Up By: Hairy (NT) - Sunday, Sep 16, 2007 at 12:40
Or at least eat the wildlife rather than leaving them homeless.
FollowupID: 523924
Reply By: Member - Davoe (Nullagine) - Sunday, Sep 16, 2007 at 11:33
buy one of those butane stoves.; Takes up FA room and 30 bux gets you the stove and enough gas for the trip.
Then as others have said organise your wood but if it rains or you get caught short for whatever reason you have the stove
AnswerID: 262435
