Jayco Eagle Wiring Diagram
Submitted: Sunday, Sep 16, 2007 at 18:36
ThreadID: 49759 Views:17740 Replies:2 FollowUps:5
Does anyone have a wiring diagram for a Jayco Eagle?
Its a 2003 model.
I fitting a battery to it. It looks like there is provision in the existing wiring, i would just like to see what the plans is.
If someone could scan the wiring diagram - it would be great.
Thanx
Swampy
Reply By: TD100 - Sunday, Sep 16, 2007 at 19:46
if it uses the black fronted Setec power supply you can connect the battery dirict to the unit,it automatically changes over from 240v to 12v and charges the battery when on 240v.cheers Paul
AnswerID: 262543
Follow Up By: Muzzgit [WA] - Sunday, Sep 16, 2007 at 20:14
And you must not forget in Jayco 12 volt electrical systems, white is earth which means black is positive!
Silly, I know, but that's how they wire 'em.
FollowupID: 524030
Follow Up By: TD100 - Sunday, Sep 16, 2007 at 20:53
standard wiring colors white is earth,black is aux supply,blue is electric service brake etc etc cheers Paul
FollowupID: 524035
Follow Up By: Muzzgit [WA] - Sunday, Sep 16, 2007 at 21:54
Yes I know, but sometimes this doesn't seem apparent when you are connecting a black cable to a positive battery terminal, that's all!
It just seems opposite to everything you would normally do!
FollowupID: 524045
Reply By: Anthony (Vic) - Monday, Sep 17, 2007 at 12:34
Hi Swampy,
I have a pdf of the wiring diagram. Give me an email address to send to. The diagram don't give much info.
cheers Anthony
AnswerID: 262654
Follow Up By: swampy66 - Monday, Sep 17, 2007 at 19:54
Thanx Anthony
please send it to roopaw at westnet dot com dot au
Cheers.
Swampy
FollowupID: 524225
Follow Up By: disco1942 - Monday, Sep 17, 2007 at 22:59
The web site for Setec is this one. From this page you can download the users manual for the later model, it is similar to the older one.
These units are not an efficient battery charger. They are similar to to the ones described in the article imported rv electrics
FollowupID: 524287
