Has anybody used a caravan water tank under their 4wd?
Submitted: Sunday, Sep 16, 2007 at 21:43
Pyro 1
Evening all,
thinking about install a caravan style
water tank under the 100 series where the spare used to be(its now on a carrier). I think i would fit a Camec 59l or
Roto Milllard 64l , I would also instal a bash plate. What are your thoughts and has any body else done this?
Reply By: Jimbo Vic - Sunday, Sep 16, 2007 at 21:46
Brilliant idea.
Forgive me stating the obvious, but the hose and tap will have to mounted quite low to allow for the gravity feed.
262574
Follow Up By: Muzzgit [WA] - Sunday, Sep 16, 2007 at 21:57
You could use an electric pump, or just the boring
old hand pump out of an old caravan.
Pyro, not forgetting that 65 litres is 65 kilo's
524046
Follow Up By: Member - Longtooth (SA) - Sunday, Sep 16, 2007 at 22:06
I was just in my caravan today and the inside
hand pump pulling
water from the
tank underneath works admirably. Perhaps the same principle would apply!
524049
Follow Up By: Pyro 1 - Monday, Sep 17, 2007 at 09:46
Jimbo,
I was going to either you a small pump or pressurise it using air compressor.
524085
Reply By: Member - Karl - Sunday, Sep 16, 2007 at 21:57
Theres are guy on the 80 Series
forum - offroad80s.com - who has done it to his Cruiser and it looks good and is very neat.
Karl
262577
Follow Up By: Pyro 1 - Monday, Sep 17, 2007 at 10:18
Thanks Karl,
that bloke has done a nice job and is exactly what I was thinking.
524103
Reply By: Derek from Affordable Batteries & Radiators - Monday, Sep 17, 2007 at 08:38
Hi Pyro
I have fitted 2x 20L jerry cans between the chassis and side steps on my LC100 (one each side). I used the red ones available from repco and fitted a top 'dip' tube and overflow to each one. They are then connected by a 2 way valve and small electric shurflo pump under the bonnet.
Derek.
262613
Follow Up By: Pyro 1 - Monday, Sep 17, 2007 at 09:49
Hi Derek,
Nice idea, is it possible to get some pics.
524087
Follow Up By: Member - Matt Mu (Perth-WA) - Monday, Sep 17, 2007 at 10:02
Yeah c'mon Derek...share!!!
Matt.
524094
Follow Up By: Derek from Affordable Batteries & Radiators - Monday, Sep 17, 2007 at 10:08
Sorry for the delay. Had to find the camera, crawl around under the car. Upload to photobucket.........
524098
Follow Up By: Derek from Affordable Batteries & Radiators - Monday, Sep 17, 2007 at 10:15
I pressure fill them from the connection in the bonnet until
water runs out the overflows. I find them very handy to go fetch
water when
camping. No need to carry extra cans and I then simply pump the
water into the camper.
524101
Follow Up By: Pyro 1 - Monday, Sep 17, 2007 at 13:59
Derek,
how exactly are they held in?
524152
Follow Up By: Derek from Affordable Batteries & Radiators - Monday, Sep 17, 2007 at 14:58
There are
well positioned anchor points on the chassis through which I placed 25mm pieces of heater hose. I then threaded a 4m ratchet strap through these points and pulled it up tight.
They have been in position for 6 years and even lasted the latest
Birdsville trip. The only repair I have done is to replace one of the jerry can caps that split for some reason but has been fine since.
Derek.
524163
Reply By: Member - John L G - Monday, Sep 17, 2007 at 11:07
Not under, but acroos the back floor behind the front seats.
Same dillemma and ended up at Camec to have a look a their range of pre-moulded Caravan tanks. Found an 80 litre that fits exactly across the vehicle and slots in with a cm to spare - could have been made for the job and even has a circular indent which fits over the transmission hump.
Has all the outlets-inlets with options either side, under or over and can be easily removed when need be, tho I don't because vehicle left permanently set up.
Simply have one hose leading up a bulkhead for a breather and the outlet, which doubles as filler under pressure, has a tap fitted on a hose and lives inside the vehicle by the back door.
Easy as and cheap as chips.
262643
