Trailer Bearings
Submitted: Monday, Sep 17, 2007 at 19:48
Cram
Hi again, I am just interested in peoples thoughts on how long trailer bearings would normally last.
I have an off road camper trailer that has probably done around 1000ks in very moderate conditions. I have just had the trailer checked out prior to undertaking a big trip and he reckons the bearings are making a noise and need replacing.
I trust the mechanic as I have known him for many years and he reckons they may have developed a flat spot when the trailer is sitting.
Anyway just wondering what people think.
Thanks again.
Reply By: T-Ribby - Monday, Sep 17, 2007 at 20:07
Interesting post. I've just completed a 4,000km trip over some rough roads in my "rough road" camper-trailer and the new bearings I had put in before the trip are fine.
However, better to be sure than sorry, so replace the bearings anyway. Make sure they are not overtightened - I check new bearings after an hour's drive by feeling the cap to make sure they aren't overheating.
It should prove interesting what condition your old bearings/shells are like when they come out and how much grease is left.
T.R.
262726
Follow Up By: T-Ribby - Monday, Sep 17, 2007 at 20:09
Note to self. Please engage brain before putting fingers into gear.
"over some rough roads 'with' my etc"
524229
Reply By: Olcoolone- Monday, Sep 17, 2007 at 20:09
Cram I think I would find a new mechanic, bearings don't develop flat spots if left just sitting.
Most bearing failure is from over heating (lack of grease, wrong grease or pre loading), wear or
water getting in causing pitting.
With the three things listed above it comes down to maintenance and correct installation.
Bearings should last many years and thousands of K's if set up right but checking regularly is a good idea.
Regards Richard
262728
Reply By: Member - Norm C (QLD) - Monday, Sep 17, 2007 at 20:18
Cram, one other point. If you don't know how to change bearing, you should learn. It is simple and the parts are not expensive.
If you do it yourself you won't mind the expense of doing them 'just in case'. It is a spare you should carry on long trips as
well and knowing how to fit them if necessary would be handy.
The expense of failure at high speed in a remote area can be very high...... like the wheel coming off at highway speed.
I'm no expert (though I do change my own bearings', but in my experience if bearings are on the way out they will generate some heat. Take the trailer for a good run 20 km should be enough. Put your hand on the bearing cover and if it is too hot to keep it there for more than a few seconds, you have a problem. But I'm interested in the view of those with more experience than me on this.
Norm C
262730
Follow Up By: Olcoolone- Monday, Sep 17, 2007 at 20:36
Norm, if you pack the bearings correctly, use good grease and pre load the bearing correctly you should not have a problem.
When we do then for customers we never re check them......but on our camper trailer we use a infra red thermometer (I don't trust my own work on my own vehicle) to check wheel bearings and also brake adjustment, using your hand is a good way.
Most bearing set ups are very straight forward, the hardest part is packing the bearing it self.
I can not agree more with your comments about learning to do then your self.
Regards Richard
524235
Follow Up By: Shaker - Monday, Sep 17, 2007 at 23:13
What is the optimum temperature?
524294
Follow Up By: Dave B (NSW) - Tuesday, Sep 18, 2007 at 09:09
Shaker, I have been told that
'if you can hold your hand on the axle, everything is OK, but if it's too hot to hold your hand on there for more than a few seconds, then there is trouble.'
524347
Reply By: Cruiserman1961 (QLD) - Monday, Sep 17, 2007 at 20:25
Hi cram,
how long is a piece of string? You have so many factors to consider.
In my opinion the no 1 killer of wheel bearings is not enough clearance (overtight), followed by lack of lubrication or overload. 1000km's doesn't sound like a lot of work for a off road trailer bearing so i'd be investigating the cause of the early failure. The flat spot your mechanic mentions would more likely apply to the tyres i think. mMaybe the seals are bad and you got
water into the bearings, which would cause rust and pollute the lubricant.
My trailer has done about 14000km's and still has the first bearing sets.
Cheers, Udo
262732
Reply By: Willem - Monday, Sep 17, 2007 at 20:31
My Offroad bush trailer's bearings needed replacing after one season and about 20,000km. Both sides had the rollers pitted.
Looks like it might be an annual thing to replace. Around $36 for both
wheels so it is cheap insurance.
262734
Reply By: Member - Christopher P (NSW) - Monday, Sep 17, 2007 at 20:55
Hi Cram, Bearings are cheap, cheaper if you get them yourself, if your mech is as good as i think he is why would he diddle you out of 1- 2hours worth of work????
My best mate is a mech and he's told me once, told me a thousand times" Prevention is better then Fixing" so get the bearings replaced and carry not ONE set of Spares But Two!!!
You change one you change them both????
They shouldnt be too much down at the local bearing/ bolts/ engineering
shop!!!
Oh happy travels
262742
Follow Up By: Cram - Monday, Sep 17, 2007 at 21:00
Know way am I suggesting that he is trying to rip me off and I have no issue in replacing them. I am just curious about what type of life span they have.
Thanks for the good wishes on travelling. I/We are looking forward to it.
524237
Follow Up By: Muzzgit [WA] - Monday, Sep 17, 2007 at 21:34
Mate, just a follow up on what is said above. Find out what grease your mech uses and buy the same. As noted on the castrol web site, DO NOT MIX DIFFERENT GREASE TYPES.
Some grease types have a high clay content, and do not take
well to the additives in some other types of grease.
524243
Reply By: Member - Stephen M (NSW) - Monday, Sep 17, 2007 at 22:11
Hi Cram just while you are on this subject what do people think of those bearing buddies (spring loaded to keep feeding grease in, when right out pump in more grease). I have these on my 4x4 camper ?? Regards Steve M
262767
Follow Up By: AdrianLR (VIC) - Monday, Sep 17, 2007 at 22:56
The theory on a boat is that when you plunge a hot wheel into cold
water the bearing may suck
water in as the air inside the bearing reduces in volume. On a Bearing Buddy, the spring compresses instead. I have them on our boat. If you subject your camper to similar situations eg
water crossings after long hard runs, then bearing buddies would make sense (although I haven't got them on the Trak Shak - have never got 'round to it).
The downside is that people keep topping up the grease and force the axle seal out. This is a bad thing!
Adrian
524284
Follow Up By: Skippy In The GU - Tuesday, Sep 18, 2007 at 07:24
I don't think much of bearing buddy's , they don't have a good seal, it still lets
water in.
Every year I clean and repack my bearings on my boat trailer and it might only go into the
water 8 times.
The guys at Electric brakes in
Adelaide use normal caps and add silicone around the seals and it hasn't leaked in 3 years.
With a boat you should always wait until the brakes have cooled down before plunging into
water. It's hard to do that when driving in a convoy through
creek crossings
524324
Reply By: Member - Norm C (QLD) - Monday, Sep 17, 2007 at 22:13
While on the topic of packing bearings. i first learned to do this in the Army over 30 years ago. Apart from packing the bearing correctly, we used to fill the whole are with greas and also the cap before you put it on.
I undersand that is now regarded as old thinking or not necessary. If you use good grease and pack the bearing
well, there is no need to fill the cap and everywhere else.
What is the modern (read newer than 30 years) thinking on this?
Norm C
262768
Follow Up By: Member - Stephen M (NSW) - Monday, Sep 17, 2007 at 22:31
Hi Norm, you must have been taught around the same years as
mine old man was. He always did the same thing to his van and boat trailers. Any thoughts on my previous reply ?? Regards Steve M
524274
Follow Up By: Member - Norm C (QLD) - Monday, Sep 17, 2007 at 22:41
Stephen, I've got no experience with Buddies, but I know some people who swear by them for boat trailers.
One comment I heard on them is the danger of assuming you just need to keep the grease up to them without inspecting the bearings occasionally. Guess that's up to the owner.
But that's about it for my knowledge on them.
Norm C
524281
Follow Up By: Olcoolone- Monday, Sep 17, 2007 at 23:16
Norm I hate to tell you not much has changed in packing bearings, we still fill the hub and dust cover up...mainly to stop
water getting in and to much grease is never enough (unless you pop the seal out or the cap off).
We use Castrol APX-T grease for nearly all applications.
Regards Richard
524295
Follow Up By: Gronk - Tuesday, Sep 18, 2007 at 00:16
You can fill up the cap and/or hub with grease but apart from making you feel good , it doesn't make the bearing last any longer !!!!
The only grease a bearing has access to is the grease packed in it..
The only way all the excess grease could get to the bearing was if the bearing started to overheat and made the other grease "run" towards the bearing !!!!!
A good example is to get a tub of grease and lower a drill into it ( at a fairly moderate speed ) and see that after making a hole in it, all the extra grease does nothing....
524304
Reply By: Shaker - Monday, Sep 17, 2007 at 23:18
I really don't understand why everybody seems so paranoid about trailer wheel bearings, in what way do they differ from normal vehicle front wheel bearings?
We do literally 10s of thousands of kms in our cars & vitually never give them a thought.
Maybe from new manufacturers buy cheap hubs with cheap bearings, but once they have been replaced with quality bearings it shouldn't be an issue.
262780
Follow Up By: Member - Phil G (SA) - Thursday, Sep 20, 2007 at 19:37
Shaker,
"in what way do they differ from normal vehicle front wheel bearings?"
Its an interesting question. 2 Things are different:
#1 The bearings are a lot bigger in your 4wd because a drive shaft needs to go through the middle of them.
#2 Heat. Heat is necessary to drive out water vapour and to melt HTB grease. Your 4wd gets heat everyday from the brakes. Trailer does not - it probably rarely gets hot from the brakes, it sits stationary in the driveway, so trailer bearings that are sitting around often get rust damage.
524783
Follow Up By: Shaker - Friday, Sep 21, 2007 at 18:55
When I said normal vehicle I meant passenger vehicle,as that is what most trailers use. either Holden of Ford Slimline.
I have also worked many yaers in the motor industry & never heard that infrequently used vehicles have a shorter bearing life.
I think one of the biggest differences is that unqualifed people are more likely to tinker around & replace their own trailer bearings, whereas, they would think twice before doing their own car.
524927
Follow Up By: Member - Phil G (SA) - Saturday, Sep 22, 2007 at 05:06
Hi Shaker,
Sorry I misinterpreted the "normal" bit.
Maybe the infrequently used vehicle still benefits from the heat from the brakes ???? And maybe we could add "cheap seals" to the cheap trailer hubs and bearings you mentioned above. Trailer bearing failures are very common and vehicle bearing failures are not as common.
From what I've seen, the unqualified people tend to do no bearing maintenance at all :-))
524963
Reply By: Dion - Monday, Sep 17, 2007 at 23:26
I guess there is one way to fix the paranoia about not getting the grease correctly into the bearing and that is to change over to an oil hub bearing. With oil, the bearing always has lubrication.
Dion.
262783
Follow Up By: Shaker - Monday, Sep 17, 2007 at 23:58
I did look at them, but thought they look a bit vulnerable to being knocked out off road like Bearing Buddies can be.
Any decent bearing correctly packed with grease should last for 1000s of kms.
524302
Reply By: Allan F (Gold Coast) - Tuesday, Sep 18, 2007 at 07:00
Hi Cram
On all my trailers I replace the bearings and seals every year and always carry spares.. Cheap insurance!
Nothing worse than having a bearing fail and an axle break
miles from anywhere ( happened once on a campervan I had 25 years ago ).
Cheers Allan
262797
Reply By: traveller2 - Tuesday, Sep 18, 2007 at 08:34
As has been said three things will stuff the bearings, wrong grease, too tight and crook seals.
The correct grease to use is Castrol APX -T or similar in other brands NOT HTB (the trailer bearings never get hot enough to melt HTB so they only get the little bit packed in initially).
A tiny amount of freeplay is better than too tight.
Use the double lip rear seals that have a stainless bit that fits into the rear of the hub and use a small smear of silicone on the cap to seal the outside.
As has been said the same bearings on the front of a car will last the life of the car usually.
When I used to use the wrong grease (HTB) I'd be replacing the bearings after every trip, since using the APXT I have never had to replace a bearing and only repack about every 5 years or if a seal gets
rock damage.
Another trick is to fit hubcaps if possible or make protectors to stop rocks knocking the outside cap off. If the cap is lost the bearings are toast very shortly after on dirt roads, dust and grease makes for great grinding paste.
262809
Follow Up By: Member - John L (WA) - Tuesday, Sep 18, 2007 at 10:31
We have off road Swagman camper made in WA. Done over 100,000km's & only on second set of bearings. Now use Bearing Buddies but maintenance checking before every trip is the secret. Stubby holders make great cap protectors - a bit out of shape if you have to pull them off to use for original purpose as some bugger has lost all the spare stubbie holders.
524374
Reply By: Muzzgit [WA] - Tuesday, Sep 18, 2007 at 13:01
The only problem with hub caps or similar is you can't see the tell tale signs of trouble when you get oily crap running outwards from the middle of the rim, which is a sure sign your bearings are about to chit themselves.
262851
Reply By: blown4by - Tuesday, Sep 18, 2007 at 15:17
Assuming you have tapered roller bearings one thing that will cause "flat spots", more correctly called brinelling, is if the trailer has ever been transported over a long distance say on the back of a truck from one State to another from where it was manufactured to where it was sold, possibly prior to you taking delivery of the camper. This is problem with all equipment mounted on bearings when being transported and can only be avoided if the item being transported is supported with the weight off the bearings. What happens is the bearing rollers contact the cup and cone and the movement during transport can allow a wear pattern or "flat spots" to develop in one area due to the high point contact loading not being distributed over the bearing surface as happens in normal operation. Also the lubricant film breaks down it not being distributed by normal bearing rotation compounding the problem. If this is the case the bearings are virtually "stuffed" before the camper is put on the road and once it is put into service the wear pattern is already established and just goes from bad to worse. Other than that the bearings, assuming they are sized correctly for the load, should last for 100's of 1000km provided the correct lubricant is used, dirt and water is kept out and adjustment is correctly maintained. One thing to be careful of if fully packing the bearing cap and the void space in the hub between the bearings is that apart from a waste of money and serving no useful purpose (a smear over the surfaces will prevent any corrosion) in certain circumstances the grease can overheat and leak out over the brakes (if fitted) due to the internal friction of the grease churning around on itself. That is why bearing buddies are of little use except for short distance work with boat trailers where the bearings are being fully immersed in water. Regarding the comments that buddies push out the seal that can be overcome if the seal is installed back to front and dirt/water is kept out by the fact the space is kept full of grease.
262866
Reply By: Cram - Tuesday, Sep 18, 2007 at 20:07
Thanks for all the replies. You have all given me plenty to think about.
I have no issue that there may have been a problem with the bearings and that they may have been faulty but after being billed today I am mighty bleep off with the money I was charged to replace them.
So I will be taking all the advice on board and finding someone who can teach me how to replace,
check, regrease etc.
Once again thanks for the comments.
We head off on Thursday morning for our trip.
262902
Reply By: Member - Brian H (QLD) - Saturday, Sep 22, 2007 at 09:42
My boat trailer bearings get checked every six month or prior to any big trip. To me it is simple and at least I know what the bearing are like. Always take two sets and they are in a PVC tube wrapped in a oiled rag to stop them rusting.
Has worked for me last 20 years.
Last Cape trip one of the trailers did his bearing they were brand new before the trip collasped with only 3000 k om them. They were done by the trailer mod he got the trailer from. He was not very happy ......... and we were in the middle of nowhere when it happened. I am please he had spares.
Brian
263420
