Codan 8528 HF radio problems.
Submitted: Tuesday, Sep 18, 2007 at 12:52
prado-wolf
Hi There,
we are off to the Simpson in a couple of weeks and have some doubts about our
HF radio at the moment.
I need someone in
Melbourne area , a technician or very competent guy that can assist me to see whether it is working properly or not.
Thanks guys
Reply By: res.q.guy - Tuesday, Sep 18, 2007 at 13:51
Telstat Communications, 52 Brunel Rd. Seaford, 3198.
Ph: 97869422, are Codan dealers, and fixed my Codan quickly and at a reasonable cost.
Neil
262861
Reply By: Tony MD - Tuesday, Sep 18, 2007 at 13:53
Not a technician but reasonably competent in East
Brighton. What are your doubts?
262862
Follow Up By: prado-wolf - Tuesday, Sep 18, 2007 at 13:59
Have fitted new Multi tap antenna , having difficulty picking up VKS 737 skeds.
Need to check whether new antenna is trasmitting ok or not.
Would it be possible to make a time for me to call you on the HF to see what happens?
Call
sign V3041.
HF is actually in my partners vehicle , his name is Rob.
524399
Follow Up By: ddr - Tuesday, Sep 18, 2007 at 14:37
I could help out too if you need, im near Knox, I checked my Radio only last week.
I find it very hard to pickup Skeds around the Eastern suburbs.
V2346
Dan.
524402
Reply By: rescue134 - Tuesday, Sep 18, 2007 at 15:29
where abouts in
Melbourne?
this time of the year it's hard to pick up the sheds, if you want you can make contact any time befour 18:00 sked for a radio check or beckon call a base station? i am in outer east subs. i am happy to help if required.
kevin
V952
262869
Reply By: Rob C (VIC) - Tuesday, Sep 18, 2007 at 16:03
Hi Kevin, Dan, Tony
Thanks for replies. Any chance one of you could call me to arrange a time and frequency for a test transmission to check my radio? (Tel 0402 248 062 or 9333 6051) I have tried Selcalls and
Beacon tests but no luck to date. I've just fitted a new multi tap antenna with the 5 VKS 737 frequencies and want to check that the main ones are receiving / transmitting OK.
Rob
262875
Reply By: Tony MD - Tuesday, Sep 18, 2007 at 18:12
Left my number with Rob.
HF conditions are woeful at the moment, especially with higher than usual noise levels in the city.
You should be able to hear overseas music stations slightly off frequency on 11612kHz.
Cheers, Tony
262887
Follow Up By: ddr - Tuesday, Sep 18, 2007 at 19:31
Tony wana post the time & Freq you guys will be trying?
I might Join in ;)
524435
Follow Up By: Tony MD - Tuesday, Sep 18, 2007 at 21:52
Not sure on a sked time yet but will post it. May be short notice & also need to avoid VKS skeds, so 3995kHz or 11612kHz may be best, depends on time.
524460
