Caravan Smart chargers,anyone used this ebay one.LINK INSIDE
Submitted: Tuesday, Sep 18, 2007 at 18:35
ThreadID: 49831 Views:4313 Replies:4 FollowUps:8
Reply By: Member - Roachie (SA) - Tuesday, Sep 18, 2007 at 19:28
I have 2 of these (the blue ones); both are 15 amps output.
I wish I'd only have had to pay $85- for them.....usually they are (were?) over $200- each.
If they are the same technology and quality as the ones I have, you certainly won't be disappointed.
I have one mounted permanently in the camper trailer and the other permanently mounted in the cargo box on the Patrol. They both run 24/7 whilst we are here at home (most of the time unfortunately!!!!!;-((.....)
AnswerID: 262892
Follow Up By: Member - Matthew C (WA) - Tuesday, Sep 18, 2007 at 20:02
Roachie as a fellow chev owner i will take your advice mate and have a crack at it,sounds like they may be ok if i get it at a reasonable price.
MAtt
FollowupID: 524441
Follow Up By: TerraFirma - Wednesday, Sep 19, 2007 at 10:36
Also worth considering the Ctek chargers if you can afford them and if your battery is 100ah or greater then you could run a 25-30amp charger which would decrease your return-charge times.
The Ctek are the Rolls Royce however from reading the specs on these ones they seem fine.
Perhaps Derek could give us some reliability reports on these as he sells them on www.sidewinder.com.au
FollowupID: 524510
Follow Up By: Member - Matthew C (WA) - Saturday, Sep 29, 2007 at 13:17
Ok so i got my charger,NOT SURE if its any good yet, we will see.Hey do yours have little switches on the side to adjust float voltages and how much DC voltage it puts out.If so can you give me any advice on how to set it up. I want to use one outlet for my accessories like radio,lights nad the other output for charging my Deep Cycle.
Is a deep cycle just a lead acid battery or is is AGM,Flooded cell<GEL.???
MAtt
FollowupID: 526099
Reply By: Member - Matthew C (WA) - Tuesday, Sep 18, 2007 at 21:09
Ok got one for $147.50 including postage,they can stick there insurance.
Matt
AnswerID: 262916
Reply By: Grungle - Wednesday, Sep 19, 2007 at 06:56
Why would you (the seller) say its the same as the blue one then take a single photo of the yellow one half obscured by packaging and the plaster photos of the blue one as the main promoting picture.
You would think if it was new and improved that it would focus on the yellow one. Sounds suss.
OK now that I have gotten that out of the way, I have 2 of the blue ones in 30A - one for the camper and one for the patrol (as Roachie does). The one in the camper is around 3 years old and was sourced through Solarforce (ebay) and although it did fail twice, Solarforce were fantastic in their after sales service. Fist time they swapped the mainboard (in warranty period) and then replaced the whole charger when it was just out of warranty free of charge. That was last year and it has been going strong ever since. The one in the Patrol is only 6 months old but is going strong.
They have handled quite a wide variety of AC sources from cheapy generators to inverter generators to modified sine wave inverter to mains power.
David
AnswerID: 262930
Reply By: TerraFirma - Wednesday, Sep 19, 2007 at 10:33
These are the same ones Derek Bester sells, check his prices also.
AnswerID: 262953
Follow Up By: Member - Andrew (QLD) - Wednesday, Sep 19, 2007 at 10:52
Yet his are $275 (+$25 P&H) ...... a huge difference in cost if that's the case.
FollowupID: 524512
Follow Up By: Member - Matthew C (WA) - Wednesday, Sep 19, 2007 at 10:55
Yep thats why im going for this one $100 cheaper.
Matt
FollowupID: 524515
Follow Up By: TerraFirma - Wednesday, Sep 19, 2007 at 11:04
Yeah fair point, wonder why they are showing the Blue ones and then selling the yellow ones..??
FollowupID: 524518
Follow Up By: Brew34.5(SA) - Wednesday, Sep 19, 2007 at 20:46
This seems the best price on ebay and its the blue one. Site Link
FollowupID: 524622
Follow Up By: Member - Matthew C (WA) - Wednesday, Sep 19, 2007 at 21:16
Yeah thats not bad but i got mine for $127 plus $20 p[ostge,with your one there will be a $20 postage and also $9.50 COD charge.
Not sure if mine blue or yellow yet,but maybe they are just the new ones.????.
Matt
FollowupID: 524633
