Kluger Test
Submitted: Friday, Sep 21, 2007 at 14:00
ThreadID: 49909 Views:3686 Replies:3 FollowUps:6
KLUGER Test
The latest car we have had on overnight loan for testing is the
new Kluger Grande 4wd/AWD.
The marketing has uprated it in all catergories and so we were
eager to compare it to our 4800 Patrol and the Disco3 Porsche4wd Prado and others we have had recently.
First impressions often count and this was not good as we couldn't
figure out how to lock it after taking delivery. This is the top of
range model and its gone all electronic and has no key any more.
When your close to it it knows and requires having both the brake
footbrake and start button operated in special sequence to activate it.
It took fully 5 minutes to figure out how to lock it, as I had apparently applied the foot operated handbrake after pressing the stop engine button and not before.
We never did figure out how to have the radio on without the engine running.
My childish streak turned up the seat heating to maximum and it took an unsuspecting wife quite a while to figure out what was happening.
The electronics are everwhere and appear of good qualiy unlike the Disco 3 we hawe did like the fact that when you put the car into reverse the huge screen auto-switched to a reversing camera, which worked at night.
This car has grown and is as wide and long as our Patrol and at 2055kg its not much lighter either. It now has a very credible 206mm ground clearance.
Sitting in the car though was very much like in a submarine with a huge dash/bonnet and high sides making visibilty worst than the Patrols.
Driving - On highway its a quiet and easy if not heavy feeling tourer capable of 11.6lt/100km however we got 13lt/100km. But overall comfort was not noticeably better than the petrol Patrol (which uses 17lt/100km).
IN The Dirt - This car now has several electronic systems designed
to make it a better 4wd (according to ads), these include Hill descent control Stabilty control, traction control and a few others.
Its huge ground clearance (same as Patrol) meant it did prety well
puttering over around over rocks but we have a nice test road known as Basin Olinda Rd here which is a narrow winding corrugated 2wd dirt road rising more than a 1000ft and a real test of vehicles.
This road had just had an inch of rain, was mushy, as is probably exactly where you would expect a car like this to shine.
With over 200kw on tap and all traction systems going we headed off and the car felt good, hard into corners you could feel
this systems cutting in preventing excessive wheelspin and keeping
the car straight, despite the mud and slippery conditions that had
other cars in a crawl.
It handled corrugations very well, braked beatifully. Its all
electric motor controlled steering was perhaps a little vague.
Up near the top of Mount Dandenong, a dead end track intersects
with the main dirt road with a 300mm deep gutter seperating the two.
Trying to fool the traction control we drove across the gutter at 45 degrees and sure enough on our second try we got the front/Rear opposing wheels basically off-ground and sure enough it couldn't figure out what to do and we were stuck. You could feel the system locking wheels and trying to grab but no luck. A bit of reverse/forward with the auto transmission and a lot of right foot and eventually it grabbed and kicked us not very neatly over the obstackle.
Dissapointed we took it home, wheeled out the Patrol and drove
exactly the same course to get and honest comparison.
The Patrol has about the same power, but is not quite as quick.
It wasn't quite as good in the stability department but was more
predictable. You could spin a wheel anytime and as the conditions
were bad we tried 4wd high range which kept sliding down significantly.
However the NO-ABS Patrol was hard to keep straight under full lock up braking. My conclusion here was that the Kluger was better if your not into driving.
Now back at the gutter that defeated the Kluger, the Patrol just
drove smoothly and consistently across. As it had open diffs this
simply came down to that most basic of things, wheel articulation.
Overall its not fair to compare the Kluger in hard 4wd stuff and I don't but its designed and touted for far more than highway cruising and in our opinion at $60,000+ its just isn't up to the job.
Robin Miller
Reply By: GoneTroppo Member (FNQ) - Friday, Sep 21, 2007 at 14:50
Well written piece Robin.
60K plus is a big ask and gets you into a lot of other cars. put another 10 to 20 to it and you're in some class company.
After all these cars will spend very little time doing what you just did. BM VW Merc Audi etc etc all have more badge credilbilty.
AnswerID: 263317
Reply By: Outbacktourer - Friday, Sep 21, 2007 at 15:11
Thanks for posting your thoughts Robin, particularly after having test driven the previous model for nearly four years we will almost certainly buy one of the new ones shortly!
Interested to know what you thought of the new remotely operated electric/split tailgate arrangement, bluetooth, flexible seating arrangement, 3 zone climate control, DVD entertainment and the other stuff new in this model from the last.
As for the value, I suspect that when you add up what you get and compare it to the competition, particularly the Euro's you will find it actually represents good value for money, certainly was last time around for us.
OT
AnswerID: 263320
Follow Up By: Robin Miller - Friday, Sep 21, 2007 at 19:01
Its amazing OT , we all evaluate things accordinging to whats important to us.
The high door sides , multiple air bags , Stab control and others things all add up to a very safe car in a crash , but along with those and the huge number of small electronic innovations , all those things added up to very little for us and we marked the car down purely because it couldn't cope with a mild 4wd situation.
For another person , with a different viewpoint it would be a wonderful car.
Robin Miller
FollowupID: 524928
Follow Up By: Outbacktourer - Saturday, Sep 22, 2007 at 08:12
Robin,
How did you find the NVH on the unsealed? The current model feels a bit "tinny" over corrogated or rougher roads.
Our use is as an all round mum's family taxi (2 + 2 + 2 x 4 paws) the only interest for AWD for us is the extra safety factor in wet/slippery conditions, so different needs to you, and hear what you are saying. Got other vehicles for the other.
The current Kluger is basically a jacked up Camry Wagon with a taller body and lots of fruit from the Lexus RX. I suspect the new model is much the same on steroids. Went OK on the beach but not much more than that.
Regds
OT
FollowupID: 524968
Follow Up By: Outbacktourer - Saturday, Sep 22, 2007 at 08:30
Robin,
Regds
OT
FollowupID: 524970
Follow Up By: Robin Miller - Monday, Sep 24, 2007 at 08:17
Very good on NVH Ot , and we specifically included roads with some rattling type corrugations
Robin Miller
FollowupID: 525292
Reply By: Member - Dunworkin (WA) - Friday, Sep 21, 2007 at 22:23
Our daughter & SIL bought one a couple of weeks ago, (it is not the 4wd model), they took it out of the salesyard on the Friday night and headed up to Shark Bay on Monday. They are very impressed with it, have had no problems with getting all extras working. The economy they got heading up the highway was 12L/100klms. It was the safety features on it that sold it for them.
D
Simba, our much missed baby.
AnswerID: 263383
Follow Up By: Robin Miller - Monday, Sep 24, 2007 at 08:22
On that basis Dunworkin I suspect they made a wise choice.
Robin Miller
FollowupID: 525294
Follow Up By: Member - Dunworkin (WA) - Monday, Sep 24, 2007 at 11:09
They are very happy with it, they were tossing up between that and the Kia Carnival which has more room than the Kluger but they forewent the extra space for the other extras that the Kluger had.
D
FollowupID: 525317
