dual water tanks
Submitted: Friday, Sep 21, 2007 at 19:28
Member - Noldi (WA)
whats the best way to hook up dual
water tanks? I'm thinking 2 submersable pumps and some sort of T piece to have the output to one tap. has anyone done this before is there a better way?
Rgds
Ian
Reply By: Member - Roachie (SA) - Friday, Sep 21, 2007 at 20:27
Are you talking about under floor (caravan perhaps?) style
water tanks? You haven't given us much info to go on......
In some ways it is best to keep your
water tanks separated in such a way that if you hole one, you don't lose all your
water.
263364
Follow Up By: Member - Noldi (WA) - Friday, Sep 21, 2007 at 21:05
Sorry roachie, yes under floor, 2 aroud 65 lt (mobile home) for both the reasons mentioned here safety from holing and contamination
Rgds
Ian
524941
Reply By: Member Dublediff(VIC) - Friday, Sep 21, 2007 at 20:38
The other issue is cross contamination, if you get a bad batch of
water in one
tank you cannot isolate it. Best to leave them independant of each other. Cheers ERic.
263366
Reply By: GerryP - Friday, Sep 21, 2007 at 21:37
Hi Noldi,
If you valve the line from each
tank going into a tee piece separatley and simply open the valve to the
tank you want (and close the valve to the other
tank), then the two tanks are isolated from each other. If you then use a self priming pressure pump, you only need the one pump for both tanks. In other words, hoses from each
tank into a valve then to a tee piece, from there a single pipe to the pump. I use this in my caravan with the change-over valves in the cupboard under the sink - it works
If you are using an in-line pump, you could do the same, but the valves would be at each
tank (could be awkward) and the pump needs to be low enough to ensure they are always below
water level.
If you use 2 pumps, then it gets even trickier as you will need to have some sort of electrical changeover to make sure the correct pump is energised, depending on the
tank you are using.
Hope this makes sense...
Gerry
263377
Reply By: disco1942 - Saturday, Sep 22, 2007 at 01:20
Ian
If you are going to use a T piece and a common supply line then you are not really isolating your
tank in regards to contamination. Your contaminated
water will be in the line you are going to pump your clean
water through.
The best way to get isolated systems is to keep have two separated systems. This will include 2 separate fillers as
Keep one
tank for fresh
water and fit it with a
hand pump. If you want an electric pump on this system you use an in line bilge pump not a submersible one (so you do not have to open the
tank to put it in.)
The other
tank supplies the high pressure system. Use a 12V pressure pump and non return valves to couple the second
tank to the HP tap. If you wish to use town
water for drinking you simply connect the town supply, switch off the pressure pump and run enough town
water through to flush the system.
263395
Reply By: Member - Noldi (WA) - Saturday, Sep 22, 2007 at 09:25
Hi all,
thanks forthat certainly brought up some points I had not thought of, out with the pen and paper and draw it out first I think
Rgds
Ian
263419
