Cibie Super Oscar lenses
Submitted: Saturday, Sep 22, 2007 at 14:24
ThreadID: 49935 Views:7813 Replies:5 FollowUps:5
A passing truck recently broke one of my Cibie Super Oscar driving light lenses. Appreciate info on where to get a reasonably priced replacement lens - Cibie stockists want $123 which I think is a bit rich. Happy to consider a second hand lens if anyone has one. Mine are 180 mm diameter
Reply By: Geoff (Newcastle, NSW) - Saturday, Sep 22, 2007 at 15:08
Mal,
Unfortunately that's the going rate for Supe Oscar lenses.
Only other solution I have is to watch Ebay, they come up from time to time on there.
Geoff
Geoff,
AnswerID: 263446
Reply By: Member -Signman - Saturday, Sep 22, 2007 at 15:23
Did you try Opposite Lock..I think they are Cibie distributors!!
AnswerID: 263450
Follow Up By: Geoff (Newcastle, NSW) - Saturday, Sep 22, 2007 at 16:03
That they are Mr Signman, that they are.
I plumb forgot about that angle, thanks.
Geoff.
Geoff,
FollowupID: 525022
Reply By: Member - Doug T (Qld) - Saturday, Sep 22, 2007 at 17:17
Not had that problem since I started using Lightforce, The last glass lights I had was Cibie square's , had the plastic covers on but still had one lens fractured.
AnswerID: 263458
Reply By: Member - Mark E (VIC) - Sunday, Sep 23, 2007 at 09:34
Mal,
Is it a spread beam or pencil beam? I have an old one lying around here somewhere.... I'll have a look.
Mark
AnswerID: 263547
Follow Up By: Old Mal - Sunday, Sep 23, 2007 at 09:41
Hi Mark, I currently have two pencil beam Cibies but would be happy to have either a spread beam or a pencil beam to replace the broken one.
Look forward to hearing from you
Mal
FollowupID: 525154
Reply By: Member - Mark E (VIC) - Sunday, Sep 23, 2007 at 09:49
where are you located?
AnswerID: 263551
Follow Up By: Member - Mark E (VIC) - Sunday, Sep 23, 2007 at 09:51
Offline at:
meddey at optusnet dot com dot au
FollowupID: 525155
Follow Up By: Member - Mark E (VIC) - Sunday, Sep 23, 2007 at 10:39
Mal,
Just ad a look in the shed. Have one spread beam, slight rust marks on the reflector. Rivets replaced with nuts and bolts as they worked loose on the corrrrrugations, 2 lock nuts, globe. It's yours if you want it.... let me know
Mark
FollowupID: 525164
Follow Up By: Old Mal - Sunday, Sep 23, 2007 at 11:05
Hi Mark,
Really appreciate the offer - I also replaced the pop rivets with nuts and bolts for the same reason ! My reflector and backing housing is OK - just the lens broken.
I live in Fremantle WA but am currently visiting our son in Geelong for a couple of weeks but also have other relatives to visit in Ashwood and East Keilor over the next few weeks. Where are you located ? My contact number is 0407 423 163 or let me have your number so we can hook up.
Many thanks
Mal
FollowupID: 525167
