For Information
Submitted: Monday, May 19, 2003 at 15:40
Member - Martyn (WA)
Last week I asked a question about coolant and which is the best etc, thanks to everyone for the answers, as a follow on to this I sent an email to Nulon techo dept via the web page asking about all the issues I had, I would prefer to stick with Nulon because it's what I've had in the engine since I built it, changing from one coolant to another seems to cause more problems than it's worth. I was expecting the usual salesman type email reply via the net, instead I had a gent called Chris who phoned me up and answered all my enquiries over the phone, I found this very refreshing to get to speak to someone who could answer all my questions "straight off the bat".
By the way I will never never use tap
water again, I consider myself told, I promise, that message came across loud and clear from the fourum. Keep the shiny side up
Reply By: Member - Cocka - Monday, May 19, 2003 at 17:46
What was the post # of your original Q. I wouldn't mind a geek at it.Carpe Diem
20438
Follow Up By: Member - Martyn (WA) - Monday, May 19, 2003 at 18:03
Cocka,
The thread number is 4999, any other info you want let me know, I have a truck load now.Keep the shiny side up
13096
Follow Up By: Member - Cocka - Monday, May 19, 2003 at 20:39
Martyn 4999 is the # of this post. What was the original post you put up about coolant. Ta.Carpe Diem
13114
Follow Up By: Member - Martyn (WA) - Monday, May 19, 2003 at 20:50
Whoops, still haven't got the hang of this, I'm only new you know 4905 is the thread, try that one.Keep the shiny side up
13116
Reply By: Ellis - NT - Monday, May 19, 2003 at 23:48
Can u give us a quick run down on what they said?
Thanks, I found the thread quite interesting.
20495
Follow Up By: Member - Martyn (WA) - Wednesday, May 21, 2003 at 21:39
Ellis,
Talked about different types of
water and which was the best, tap
water was at the bottom next to anything you can find in an emergency, to the top of the range being this reverse osmosis
water, distilled
water, soft
water where acceptable. Concentrations of the coolant also got a run, it's better to put a concentrate in than a pre mix blend because you can never guarantee the strength after you add the new mix to the old mix or at least what's left in the system. Talked about stray currents and the effects of them, what to do to preven them and how to find them. Keep the shiny side up
13314
