Whinning Rear Diff
Submitted: Monday, Sep 24, 2007 at 20:48
ThreadID: 50000 Views:3300 Replies:7 FollowUps:8
I have a whining rear diff and was priced 600 - 800 for a rear diff rebuild. I remember a mob called cost effective maintenance who reckon there products could help increase or extend the life of diffs. AW10
Has anyone had any good bad or indifferent experiences from the products in particular the AW10 additive?
Troy
Reply By: Stu050 - Monday, Sep 24, 2007 at 21:05
Be aware that it is not suitable for use in Limited Slip diffs.
How many KM's has the diff done?
It may be better to bite the bullet and investigate the whine, rather than maybe masking a potentially bigger problem that could leave you stranded or worse.
My .02
AnswerID: 263783
Follow Up By: hl - Monday, Sep 24, 2007 at 21:16
What car is it?
I have a Patrol 2001 with the big (H260) diff in it and it also whines a bit at around 95/100k. It has done 84,000k and the whine has been there for at least the last 40,000 and has not changed. At the 80k service I thought I'll try a fully synthetic oil and I used Penrite SIN140 (I think). It has not made a very noticeable difference. So, before you blow 100 bucks on expensive oil, consider this.
FollowupID: 525401
Follow Up By: troy - Monday, Sep 24, 2007 at 22:44
its a hilux with 247000 done. I think a diff rebuild is in order but just wanted some answers first. On a bit of a working holiday around oz and heading home in jan so was hopefully wanting to make it last til then but ... i doubt it
FollowupID: 525425
Follow Up By: Member - Christopher P (NSW) - Tuesday, Sep 25, 2007 at 10:46
Hi Troy your diff is due for a rebuild at approxiamately 250k, i know mine was rebuilt around then and somebody stole it, so if you find it there's a good diff in it? :op
FollowupID: 525467
Reply By: Vicar - Tuesday, Sep 25, 2007 at 06:38
hi troy,
that is around the right price, get a second and third opinion if your worried, but if the diff breaks when your on the move, it could be just as costly getting it somewhere it get it repaired if your out in the sticks...
AnswerID: 263813
Reply By: Member - Doug T (Qld) - Tuesday, Sep 25, 2007 at 07:14
Troy
In 1967 I had a 1962 EK Holden, I had travellled across the Nullabor to Perth and when I got onto the new Canning Fwy ...as it was then I noticed a whine from the rear,a couple of months later I found the whine was a rear wheel bearing,
I now have a Toyota Landcruiser that 711000 ...still using the original 1994 Diff, I add 1 small tube of Nulon each time I change the oils in theDiffs, gear box and T/Case.
AnswerID: 263816
Reply By: Smudger - Tuesday, Sep 25, 2007 at 09:47
Mate,
My Disco came with a built in whine.
Did hear of one that didn't have a whining diff once ..but the guy sent it back to the factory and they fixed it.
AnswerID: 263836
Follow Up By: Member -Signman - Tuesday, Sep 25, 2007 at 11:42
That'd be right!! Just another whining/wingeing Pommie!!!
FollowupID: 525475
Reply By:- Tuesday, Sep 25, 2007 at 11:11
For $800 I would certainly do it by myself. Follow book, it is really easy to do, apart of access to press no special tools required. Good bearing kit put you back for $150 or so and I would put remain $650 into diflockers and kill two birds at the same time. Additive to fix it? Dream on (but for a while stay on the road).
Cheers.
AnswerID: 263844
Reply By: Andrew-rodeo - Tuesday, Sep 25, 2007 at 12:48
I get this whinning noise from the passenger seat, is there anything that i can do about that?
There is a product out there called Slick 50 it is expensive but does work.
AnswerID: 263852
Follow Up By: troy - Wednesday, Sep 26, 2007 at 19:04
i made sure my passenger seat was empty when i was double cheaking the noise but bugger me the noise was still there.
I think that, as been previously stated, the diff is due for a rebuild given its 12 years old with 247000 on the clock. Maybe i'll contemplate it at a later stage.
FollowupID: 525771
Reply By: Steve from Top End Explorer Tours - Tuesday, Sep 25, 2007 at 13:34
The question that needs to asked is, is it a constant whine or is it a whine when you take your foot off the accelerator ?
If it is a whine when you take you foot off the accelerator it whould probably mean bearings, if it is a constant whine it's probably the crown wheel and pinion.
I took my diff centre out my self had a work shop do the crown wheel and bearings and set the pre load then I put the diff back in myself.
Cost of parts was about $350 cost of labour about $200, so if they quoted $600 to $800 that would be a fair price in my book.
Hope this helps.
Cheers Steve.
AnswerID: 263856
Follow Up By: troy - Wednesday, Sep 26, 2007 at 19:00
The whine isn't very noticable until your doing 90+. The whine i guess is constant but isn't as noticable with the foot off the accelerator at the high speeds.
FollowupID: 525769
Follow Up By: Steve from Top End Explorer Tours - Wednesday, Sep 26, 2007 at 21:05
Hey Troy
To me that is a crown wheel and pinion, so there for not that urgent in repair, it will just get more annoying the longer you leave it, pulling out replacing a crown wheel,pinion and bearings then replacing the diff, $600 to $800 is fair.
Cheers Steve.
FollowupID: 525785
Follow Up By: troy - Thursday, Sep 27, 2007 at 13:14
Thanks for the advice, life is full of learning and spending. I dont think the good wife will be able to put up with it for much longer, me i just turn the stereo up!!!
FollowupID: 525885
