Re Thread #48389 Broken Glass on Solar Panel
Submitted: Friday, Sep 28, 2007 at 11:08
Penguin (NSW)
Woohoo! I just had a call from the insurance company and, after a lot of procrastination, they're going to pay for the panel which I've already replaced.
Rather surprising really given that it was an aftermarket add-on and it wasn't declared on the policy. Thanks NRMA.
Mike
Reply By: Member - Poppy (QLD) - Friday, Sep 28, 2007 at 14:07
Mike
Big brother is watching you hehehe
264273
Reply By: michael & lisa - Friday, Sep 28, 2007 at 21:53
you can fix broken glass on soler panel
264330
Follow Up By: Member - Pedro the One (QLD) - Friday, Sep 28, 2007 at 23:10
Please advise ????
I have a friend with a cracked and starred solar panel .... would appreciate "how to!"
Thanks ............
526064
Follow Up By: michael & lisa - Friday, Sep 28, 2007 at 23:28
If its only the glass, take it to a glass glazer and they will put another sheet of glass over the top, only if no moister has got in. I bleep tered ours and they fixed it. Works
526065
Follow Up By: stocky - Saturday, Sep 29, 2007 at 08:07
Depends on the panel type....if its a thin film panel (brown type) the panel is on the back of the glass and depending on the crack direction it will either not work at all (cracked full length ALONG line of cells) or will work at reduced capacity (crack across full width of cells).
What M&L said stands though for the "blue" cell panels :-) - a smear of silicone keeps the
water out till you can get to a glazier
526073
