winch recovery with snatch strap
Submitted: Saturday, Sep 29, 2007 at 19:35
ThreadID: 50127 Views:6703 Replies:10 FollowUps:7
Gday all Gave the winch a roll out today just too keep it moving and although very pleased with plasma rope length
got to thinking and wondered if req could a snatch strap be used as a winch extension or tree trunk protector if req and would this render snatch stap u/s my guess is yep this would stuff the snatch stap but would the strap of reasonable qaulity handle this sort of use Cheers Barn
Reply By: Scubaroo - Saturday, Sep 29, 2007 at 20:23
I don't think you would want to use a snatch strap as a winch extension - apart from the fact most if not all manufacturers strongly recommend against it, the winch would start stretching the snap strap instead of moving the vehicle, and there's a very real risk that when the vehicle does move, it's snatched instead, and leaps forward unpredictably. Recovery should be a controlled exercise - using a snatch strap is just introducing an unpredictable variable into the winching operation.
A dedicated 30m winch strap is only about $100 from memory - cheap insurance.
AnswerID: 264398
Follow Up By: Member - Doug T (Qld) - Saturday, Sep 29, 2007 at 20:59
Scubaroo
I would agree 100% with your answer to Fred's workmate.
As for extension straps I think in my ARB recovery box of tricks I would have 3x30m 2x20m 1x5m chain, tree trunk protector , and the chances are the object I would need to connect to will be 2m out of reach.
Doug
FollowupID: 526138
Follow Up By: Member - Duncs - Sunday, Sep 30, 2007 at 19:10
You are spot on Doug and I have a friend who says that if you got another 2m of strap then the anchor point would move further away.
Oh his name is Murphy. You may have met him.
Duncs
FollowupID: 526231
Reply By: Philip A - Saturday, Sep 29, 2007 at 20:25
AFAIK, as long as you kept within the load limit of the strap it is OK.
BUT they are so elastic that you would end up losing quite a bit of pulling power of the winch as the snatch strap would stretch so much that you may end up with a few winds on the drum.
And you would also lose length of pull, but this is rarely important.
Regards Philip A
AnswerID: 264399
Reply By: Mike Harding - Saturday, Sep 29, 2007 at 21:04
I would not use one as a winch extension rope but... as a tree trunk protector... providing you wrap the vast majority of it's length around the tree (multiple times?) and only use the ends as an anchor point I cannot see why that would be a problem.
Mike Harding
AnswerID: 264405
Reply By: obee - Saturday, Sep 29, 2007 at 21:12
If thats all you have I dont see a problem. Straps should take a lot more than the vehicle weighs and you are only puling horizontally with a bit of help from the wheels. Often it only takes a little extra help to get a vehicle moving out of a bog. I once did it with the equivilent of a couple of truckie hitches on an old craypot rope. I shudder to think of the amount of energy going into a strap when a two tonne plus vehicle hits the strap at speed. In comparison, I think the winch is benign. If the winch got to the point where it broke or damaged the strap, you would want to start looking for the bulldozer pulling you from the opposite direction.
Better to keep the strap in prime condition, however, and use something else.
Please dont rely on my advise however, and use your own judgement. I dont want you calling me from your hospital bed because you misread what I am saying. You got a better chance getting out of a bog with a warranty from Nissan than suing me in court.
I have been known to be wrong.
All the best,
george w bush
AnswerID: 264406
Reply By: Hairy (NT) - Saturday, Sep 29, 2007 at 22:07
I just left a mates place after a gand final show.....was it the best thing to do ?? or should I have had a couple more???
AnswerID: 264422
Follow Up By: Kumunara (NT) - Sunday, Sep 30, 2007 at 09:58
Hairy
You live in the NT. You should have stayed and had a couple of more cartons.
The game was so one sided it was boring anyway.
Tjilpi
FollowupID: 526183
Reply By: Member - Kiwi Kia - Saturday, Sep 29, 2007 at 22:41
No problem using the snatch strap as long as you keep out of the way if anything comes adrift !
The winch is only a gradual pull and if you can also have the wheels driving slowly on the bogged vehicle everything should be fine. If the bogged vehicle was in neutral and suddenly came free then the snatch strap would certainly accelerate things though.
AnswerID: 264427
Reply By: Shaker - Saturday, Sep 29, 2007 at 22:48
If you have an extension strap & a snatch strap side by side, how do you tell the difference?
AnswerID: 264428
Reply By: barney rubble - Saturday, Sep 29, 2007 at 23:48
Thanks all for your replys appears some winch straps & chains need to go on the shopping list but a snatch strap could be used if nothing else is available but the outcome could be unpredictable
Thanks Freds mate
AnswerID: 264434
Reply By: Willem - Sunday, Sep 30, 2007 at 09:22
Recently I had to use all means to get a mates ute extracted from a serious bog.
We connected everything we had in our possession.
One Brawn winch and cable
Two snatch straps
One Tirfor with cable fully extended
One Tree trunk protector
A variety of Bow shackles and D-shackles.
All equipment was subemerged in muddy water!
It seemed to work very well as the extended straps and cables worked together to glide the ute out of trouble.
All hands stood well clear just incase of a failure somewhere along the line.
In an emergency I would use a snatch strap but not as a rule.
AnswerID: 264441
Follow Up By: Kumunara (NT) - Sunday, Sep 30, 2007 at 10:01
Willem
Good advice about the stay well clear.
I would hate to see what the result would be if a snatch strap gave way when being used on a winch.
Tjilpi
FollowupID: 526184
Follow Up By: Willem - Sunday, Sep 30, 2007 at 10:11
Tjilpi
Go and have a read in my website below. Click on 4x4 and then scroll to the bottom of the page where the stories are listed. Click on 'A Close encounter with a Bow Shackle'
FollowupID: 526185
Follow Up By: Member - Kiwi Kia - Sunday, Sep 30, 2007 at 14:15
Tjilpi, doesn't matter if you are using a winch or not.
Any strap used on a recovery operation has stored energy and is potentially lethal.
FollowupID: 526205
Follow Up By: Bonz (Vic) - Sunday, Sep 30, 2007 at 15:10
We all seem to be worried about the snatch letting go its probably the highest rated thing in the back of the car, with that long linkage anything letting go would be interesting,
worth seeing as long as it was someone else car hehehehe
FollowupID: 526215
Reply By: me2@neuralfibre.com - Sunday, Sep 30, 2007 at 18:40
You would be nuts. The snatch strap stores the winch energy. If anything fails, it all gets released in abig hurry and people die. You want non strenth that way there is minimal stored knietic energy in the event of failure. The risk is not the strap snapping, but something else, anything else, and the strap releasing it's energy into whatever lump of steel it's still attached to.
300km/hr+ guaranteed with a few kg
Paul
AnswerID: 264498
