Public Weighbridge in Adelaide
Submitted: Sunday, Sep 30, 2007 at 08:38
ThreadID: 50135 Views:13344 Replies:3 FollowUps:4
We found out that we are overweight on our rear axle, so we tossed some stuff and relocated other stuff when we got to Adelaide. Now we need to weigh the rig again and, not knowing Adelaide, we need to find a public weighbridge...preferrably a free one.
We are in the Marion area. Can anyone help?
Russ.
Reply By: PeterInSA - Sunday, Sep 30, 2007 at 09:13
Russ
I have weighed our van at De Youngs Salvage, 31 Seaford, Seaford (or Old Noarlunga).
Go down South road past Reynella, Morphett Vale, Hackham, over the Onkaparinga River Bridge and Seaford Rd is the first Turn on the right.
De Youngs is about 550m down the road on the right. Go down to the Gravel/ Sand/ Garden supplies area. Drive your vehicle over the ramp and there is a visual readout.
No charge unless you want an official receipt. From memory Greg or Geoff are the guys running the Landscape section.
Question How did you find out that you were over weight on your rear axle. I have one of those Jacks that can tell you the weight (kept in the front boot), but never use it?
AnswerID: 264440
Follow Up By: Russ n Sue - Sunday, Sep 30, 2007 at 10:35
Hi Peter,
thanks for the info. I did a couple of tyres in and the tyre service at Alice Springs suggested that I might be a bit too heavy for the tyres I was running, so I went over the weighbridge at Alice Springs. First I weighed the entire vehicle, which was overweight, then I weighed each axle to see where the problem was.
Turns out that the down-weight of the camper hitched to the car, plus about 100Kg of stuff in the car were causing the problem. I think we're sorted now.
Russ.
FollowupID: 526187
Reply By: DIO - Sunday, Sep 30, 2007 at 10:37
From memory there is a Road Transport Office on Sturt Road, sthn side between the Sturt Police complex and the Marion Caravan Park. Someone in there will be able to point you in the right direction. They will have a comprehensive list of them - or at least they used to.
AnswerID: 264449
Reply By: Member - jdwynn (SA) - Sunday, Sep 30, 2007 at 11:43
Some interesting stuff on your rig/profile Russ
Where were you required to have a porta potty?
210l of water - that's a lot. Why so much?
Best wishes for your travels. JD
AnswerID: 264456
Follow Up By: Russ n Sue - Sunday, Sep 30, 2007 at 15:20
G'day JD,
Many local government councils in WA operate camp areas, but will not allow you to use them if you don't have a porta potty. I'm told that this is the case in many other states too. So hence the porta potty.
The water is for two reasons: First we often camp out for several weeks where there are no facilities and secondly we have the full complement of batteries in the camper, all of which are forward of the axle, so we carry the extra 90 litres of water right at the rear of the camper to counter-balance the down-weight a bit.
The trouble with the KK is that the outboard motor mounting bracket is at the front, as is the gas bottle, two jerry cans and the front storage box. The only things aft of the axle are the water tank and the spare tyre, which is marginally rear of the axle.
The result is over 300Kg of drawbar weight on the hitch. To solve this we have ditched the boat and all that goes with it, including the motor. We won't fill the two jerry cans unless we are doing long hauls like we did recently down the Tanami Rd and from Alice to Adelaide.
Also we have taken weighty items from the rear of the car and put them at the rear of the camper trailer. We've also packed everything we haven't used in the last five months and it's going back to WA. And we had around 90Kg of canned and packet foods under the bed of the camper, also forward of the axle, so that has come out and will be redistributed and/or eaten and not replaced. The washing machine is going back to WA as well. We'll use it when we get a caravan in a few year's time.
I can't be sure but going on the weight of what we've taken off or shifted, I think we should be OK now.
Russ.
FollowupID: 526216
Follow Up By: Garbutt - Sunday, Sep 30, 2007 at 17:20
Which way are you going next, I'm in the Riverland and have access to a weighbridge.
GB
FollowupID: 526224
Follow Up By: Member - jdwynn (SA) - Sunday, Sep 30, 2007 at 17:36
Thanks Russ, very interesting. Gee I have known caravans to have axle in wrong position in terms of weight distribution (led to court action in one case) and wonder if KK have it right given amount of effort you have put in to get tow ball weight down. I guess it ensures overall weight kept at a low level which is good. Regards JD
FollowupID: 526225
