Site Search
Section Image
Reverse Light
Submitted: Tuesday, Oct 02, 2007 at 12:54
CYPHER-CHLNGER
Hi all, looking at installing an additional reverse light onto my challenger near the number plate...As often the factory reverse light is too low \ dull to really see anything.
Would also be nice to have the option to turn on via a switch, for camping etc...
Anyone done this before and have any tips, wiring diagrams ?
Also any legal issues ?
Advertisement
ThreadID: 50189 Replies: 6
Views: 667 FollowUps: 7
AnswerID: 264713   Submitted: Tuesday, Oct 02, 2007 at 14:48
Member - Karl replied:
Not sure if this is will help you but I recently had two small 55 watt driving lights from Supercheap installed under the rear bumper of my Cruiser and had then directly wired to the standard reverse lights so that when I reverse it lights up the rear of the vehicl therefore lighting up the road.
The lights are protected by the tow bar and work a treat.
AFAIK - any light facing rear ward can not be greater than 55 watt.
Others have also attached a single rear facing light on extendable poles to their wheels carriers to provide the additional lighting required.
Karl
My new scoop
Click Image to Enlarge
Everyone is entitled to my opinion!!
Reply 1 of 6
FollowupID: 526516   Submitted: Tuesday, Oct 02, 2007 at 15:10
Member -Signman posted:
Are you using the standard wiring/fuse to power an EXTRA 110w with the existing globes?? That's about a 10AMP draw !!
The Ultimate Hitch-hiker
Each morning I seize the day...
but by mid afternoon it has escaped!
Signman- NSW
VKS737 M3364 Selcall3364
Amateur Callsign: VK2EZY
FollowUp 1 of 3
FollowupID: 526517   Submitted: Tuesday, Oct 02, 2007 at 15:11
ben_gv3 posted:
It may not be a good idea to wire it directly to the reverse light circuit unless there is power coming directly from the battery. I believe reverse lights are 40W (2 lights at 20w each) but now you've got another 110W (2 x 55w) in the circuit which may result in cooked wiring. The factory wiring may hold up but I if it was me I would run wiring directly to the battery.
FollowUp 2 of 3
FollowupID: 526536   Submitted: Tuesday, Oct 02, 2007 at 17:44
Member - Karl posted:
An auto sparkie did it for me - told him what I wanted and he did it.
So far works perfect.
BTW the reverse lights are only on for the time it takes me to reverse out of a situation - usually less than a minute or so.
It is a fairly common mod thats getting done here in WA at the moment.
Karl
My new scoop
FollowUp 3 of 3
AnswerID: 264723   Submitted: Tuesday, Oct 02, 2007 at 15:35
baza replied:
I would go with the same wiring 'design' as a set of driving lights, just tap into the reverse light instead of the high beam circuit to active the relay (i.e light wired direct to battery).
Reply 2 of 6
FollowupID: 526529   Submitted: Tuesday, Oct 02, 2007 at 17:09
nickb posted:
I agree, you should wire it through a relay so it switches on the lights when either reversing or via a switch in the cab (or cargo area).
I have a mate who wired his back spot lights(2x55W) to his reverse lights. It was good for about 6mths then the reverse switch on the gearbox burnt out! He never got round to fixing it, he just put a switch in the cab...
AnswerID: 264742   Submitted: Tuesday, Oct 02, 2007 at 17:58
CYPHER-CHLNGER replied:
Thanks Everyone for your help as usual....giving me some great ideas
Reply 3 of 6
AnswerID: 264758   Submitted: Tuesday, Oct 02, 2007 at 18:56
Member - Franga (QLD) replied:
Hey this is frangas son, i am a first year Apprentice Auto sparky, as far as i know it is not wise to run extra lights off the reverse light wire because the reverse switch cant handle the load and will eventual burn out. When wiring the light up i would put an ON OFF ON switch in the dash so u can flick it one way and put it in reverse so it works when in reverse, then flick it the other way will turn it on straight away, when wiring it make sure it is all run through a relay so nothing will burn out.
Let me know how you go.
Cheers frangas son
Reply 4 of 6
Activities Index
WRX Turbo Rally Intro 8 Laps + 1 Hot Lap - Sydney WRX Turbo Rally Intro 8 Laps + 1 Hot Lap - Sy
Sydney - NSW
Rally driving - you've seen it on TV, so stop thinking about it and do it!
Wilson Wilson's Promontory National Park Day Tour
Phillip Island and Gippsland - VIC
Wilson's Promontory National Park is one of Victoria's most loved and naturally maintained national
Motorcycle Ride Day (Your Bike) -  VIC Motorcycle Ride Day (Your Bike) - VIC
Melbourne - VIC
Ever wanted to ride as fast as you want, with no risk of a speeding fine!
Great Barrier Reef Cruise &Seawalker Helmet Diving Great Barrier Reef Cruise &Seawalker Helmet D
Cairns and Tropical North QLD - QLD
Experience the marine life of the Great Barrier Reef by joining our Seawalker Helmet Diving adventur
Book Now - Things To Do
AnswerID: 264787   Submitted: Tuesday, Oct 02, 2007 at 21:39
Muddy doe (SA) replied:
We have two 55w worklights mounted on the rear of the roof rack used as worklights or for reversing when in dark situations or out in the scrub. VERY handy.
They are wired from battery totally seperate from the vehicle reversing lights and have an on/off rocker switch on the dash. I prefer being able to switch them on only when I actually need them. Can be a pain just in city if they were wired in all the time to the reversing lights.
Also if you DO want to use them as worklights (once you do it once you will want to do it all the time), if they are independently wired you can use them whenever you want, without having to put the vehicle in reverse (unless you wire in an overide - more complexity) and can leave them on for a longer time without overheating any wiring (subject to battery capacity!).
I got a switch for the dash that has an led in it so I can see if I accidently knock the switch on. Not a good idea to have 110w of rear facing lighting on going down the highway!
Muddy
Playdoe GXL TD Manual with lots of MUD
Reply 5 of 6
FollowupID: 526668   Submitted: Wednesday, Oct 03, 2007 at 12:15
BIG_red87 posted:
haha that'd be good for when bastards are tailgaiting you too...
FollowUp 1 of 3
FollowupID: 526673   Submitted: Wednesday, Oct 03, 2007 at 12:30
Muddy doe (SA) posted:
Trust me.... I have been VERY tempted a few times!
FollowUp 2 of 3
FollowupID: 526731   Submitted: Wednesday, Oct 03, 2007 at 18:32
Nick R (VIC) posted:
I wanted a rear facing set back in january, was tailgated by someone who also insisted on having their high beams on, HIDs would have been good then.......
NickR
On a Dune that i was told was Big Red
Aio, quantitas magna frumentorum est
Carpe Cerevisi
FollowUp 3 of 3
AnswerID: 264789   Submitted: Tuesday, Oct 02, 2007 at 21:49
Brian (VIC) replied:
I bolted 1/2 of a set of super cheap mini driving lights to my tow bar on my Triton, took a feed from the active going to the lights into a switch to power a relay and down to the spottie (55w). Works a treat no I don't back into the carport posts at night any more!
Reply 6 of 6
