Site Search
Section Image
Change tyre size/speedo error
Submitted: Tuesday, Oct 02, 2007 at 19:50
greenant
Found this ans thought it may be of interest
http://www.miata.net/garage/tirecalc.html
Greenant
Advertisement
ThreadID: 50198 Replies: 3
Views: 1597 FollowUps: 5
AnswerID: 264782   Submitted: Tuesday, Oct 02, 2007 at 21:15
ExplorOz Team - David replied:
Why not just use the one published on ExplorOz: Tyre Size Calculator
David & Michelle
Click Image to Enlarge
Always working, not enough travelling ;-)
Reply 1 of 3
FollowupID: 526585   Submitted: Tuesday, Oct 02, 2007 at 21:28
Member - John posted:
Touch'e
Before the last trip
FollowUp 1 of 3
FollowupID: 526709   Submitted: Wednesday, Oct 03, 2007 at 17:10
Shaker posted:
Maybe because it is a little hard to find, unless you know it's there, & it doesn't Google.
FollowUp 2 of 3
FollowupID: 526711   Submitted: Wednesday, Oct 03, 2007 at 17:15
ExplorOz Team - David posted:
Should google - but think it is page two. It will work itself out in time. No stress - but hey now you know.
David & Michelle
FollowUp 3 of 3
AnswerID: 264818   Submitted: Wednesday, Oct 03, 2007 at 07:54
Member - Bucky (VIC) replied:
Just use a GPS to give you your speed, If you have one !
60, 80, and 100 km/hr, and check your speedo, I have done this to several of my mates vehicles, and the problem is solved
Bucky
I must obey !
I must obey,, I must obey,, I must obey !
Reply 2 of 3
AnswerID: 264863   Submitted: Wednesday, Oct 03, 2007 at 13:41
Steve L replied:
Definitely using a GPS is the way to go.
The problem with ALL the tyre size calculators out there is this - not all tyre manufacturers make tyres that match the specifications printed on the sidewall.
For example, a 285/75R16 'should' have a diameter of 833.9mm if you calculate it using the tyre section, sidewall and rim diameter figures. Unfortunately, you will find that most manufacturers do not stick to this, and most 285/75R16s (with the exceptions of Coopers and Mickey T - and maybe a couple of others) have their 285 tyres usually with a diameter of 840+mm, with BFG having their AT at 852mm!!! (I.e. not even close....)
That results in a sigfnificantly different speed reading compared to what the tyre calculator suggests. This is the case for most tyre sizes, and when the diameter is out, the circumference, etc. are all out as well (as are the comparisons between tyre sizes).
Use a GPS or get the manufaturers specifications for the specific tyre you're using (or wanting to buy) and do your own calculations from there if you want to be sure you've got it right.
Reply 3 of 3
FollowupID: 526701   Submitted: Wednesday, Oct 03, 2007 at 16:26
Member - Graham H (QLD) posted:
Would that be because some tyres have 8mm of tread as standard and some have as much as 14mm.
Just curious but seems logical
Our new home away from home
Another Kiwi that flew the coop
FollowUp 1 of 2
FollowupID: 526702   Submitted: Wednesday, Oct 03, 2007 at 16:35
Steve L posted:
It's not really something to do with tread depths.
For example, a Coopers ST or STT 285/75R16 is 833mm in diameter, while the BFG AT in the same size is 852mm and many others are around the 841mm diameter. The BFGs total tread depth is not 19mm, let alone its tread being 19mm deeper than the Coopers.
I think it's simply the manufacturers building in tolerances or something. There is a 3% variance in the ADRs or similar that they are allowed to be within in terms of their sizing, so perhaps they are taking advantage of that?
FollowUp 2 of 2
