AnswerID: 264855 Submitted: Wednesday, Oct 03, 2007 at 12:36
Peter 2
replied:
Willem
Unfortunately it is not unknown on GQ's but more common on GU's especially when fitted with heavier springs and carrying a bit of weight.
In an extreme situation they tear off the chassis completely and crush the brake and fuel lines up against the floor. A friend had this happen to his GU in WA while on hols and it was a very expensive body off the chassis repair.
I'd be drilling the ends of the crack as suggested and then trying to get it welded in situ by a competant welder.
It may require removing the rear diff housing and running gear to enable better access, the last resort would be either lifting the body up enough or taking it right off.
When they repair the spring towers on the utes they weld a length of RHS across the top of the spring towers between the chassis rails to stop the towers flexing up on the inside, might be a bit hard on the wagon though, depends on how close the floor is.
 Click Image to Enlarge |
| Peter
1988 M1026 Humvee |
Reply 3 of 7
FollowupID: 526721 Submitted:
Wednesday, Oct 03, 2007 at 17:40
Willem posted:
G'day Peter
Yep. My mate is going to make up a frame to fit under the body of his GU so that the flexing stops on the turrets. I do know that this could be an issue with GQ's.
I will drill a small hole to arrest the crack to start off with. It is accessible. I have not carried great weights in the GQ and now have transferred all the weight to the trailer. The back of the vehicle is very light. I do have the poly-air bags in the rear and run them at about 10psi. The truck has done 346,000km so the few repairs I have to do now are minimal.
| Willem
Surfing the Porcupine Grass
FollowUp 1 of 4
FollowupID: 526746 Submitted:
Wednesday, Oct 03, 2007 at 20:37
Member - Glenn D (NSW) posted:
Hows it going guys ,
My next door neighbour had the same body off experience with his GU . As you said a real show stopper on the wrong side of the country , Noticed on your member profile you are in the TLCC Peter, may be the same guy he is a member as well.
There were a fair few posts a few months ago on the chassis / spring mount crack topic . Many blamed airbags , but dual wheel carrier type bars also got a hiding .
I reckon I would give the in situ fix a go before major surgery , The worst that can happen is it will crack again . At least you will be able to keep your eye on it.
Glenn.
| PATROL |
FollowUp 2 of 4
FollowupID: 526934 Submitted:
Thursday, Oct 04, 2007 at 19:56
Yeah , changed the glow plugs.
Starts first time now on cold mornings.
In hind sight it used to do a smokey start every now and then and I was thinking maybe the injectors were needing a service. I guess it never got cold enough to be a real problem.
Hope you sort your crack out.
Glenn.
| PATROL |
FollowUp 4 of 4
