Leaking water dooverlackies for rear wipers....
Submitted: Thursday, Oct 04, 2007 at 22:54
ThreadID: 50254 Views:2454 Replies:1 FollowUps:7
Whatever those things are called that the water comes out of; mine leak. It's an 80 series with barn doors and when parked at home facing forward up a slight incline I find that the right one leaks. Anyone else come across this?
I guess I could face downhill to solve the problem lol
Reply By: Richard Kovac - Thursday, Oct 04, 2007 at 23:13
B
you will fined a small check valve fitted somewhere ever at the pump or in the clear tube, maybe stuck open or RS, try and fine it and check it out
Richard
AnswerID: 265099
Follow Up By: Bware (Tweed Valley) - Friday, Oct 05, 2007 at 00:27
Thanks Richard,
I'll check it tomorrow.
I note that you didn't offer a technical name for dooverlackies ;-)))
FollowupID: 526983
Follow Up By: Oldsquizzy (Kununurra) - Friday, Oct 05, 2007 at 00:34
Bit like a hoosermajig aint it?
FollowupID: 526984
Follow Up By: Bware (Tweed Valley) - Friday, Oct 05, 2007 at 01:54
Oldsquizzy you could be right; I think dooverlacky is the term reserved for things that have moving parts lol
FollowupID: 526987
Follow Up By: Gerhardp1 - Friday, Oct 05, 2007 at 10:53
It's a whatchamacallit.
FollowupID: 527027
Follow Up By: Gerhardp1 - Friday, Oct 05, 2007 at 10:55
Thingamabob, jiggeramoo
FollowupID: 527029
Follow Up By: Redback - Friday, Oct 05, 2007 at 11:06
A hoosawhatsit, fandangley thingamejigit
FollowupID: 527033
Follow Up By: Sand Man (SA) - Friday, Oct 05, 2007 at 11:06
Oldsquizzy,
I have it on good authority that the "hoosermajig" you are referring to is actually called a "thingermajig".
As for the original piece of apparatus for the rear wipers, wouldn't it be called
"washer water tubing", or,
"water washer tubing", or,
"windscreen washer tubing".
Aw hell, thingermajig will do just fine.
Bill
FollowupID: 527034
