Electric Slide on Legs
Submitted: Friday, Oct 05, 2007 at 18:21
Diane
Does anyone know if there is an importer in Australia for electric legs for slide on campers? I have heard of some called happy jacks, but have had no luck in finding any.
Reply By: _gmd_pps - Friday, Oct 05, 2007 at 20:03
I have ATWOOD 3,500 lb jacks on my Slide-On
http://www.pplmotorhomes.com/parts/rv-jacks/atwood-power-jacks.htm
or
http://www.southwestwheel.com/store/c-90-electric.aspx
probably cheaper to have them sent from US
mine have wireless remote but can only do 2 at a time
4 will draw too much power and the controlbox will switch off
and one has to reset them .. apart from that they work
well ..
I don't think they sell here in Australia. I normally don't even look because usually it's a waste of time to try and find such things here .. quicker and mostly cheaper to get it in ..
in this case you have to watch the freight cost but sending them UPS should still work out not too bad ... I guess around A$300 or so for two parcels (2 packed in each) there is no cheap USPS anymore .. they don''t do sea anymore.
good luck
gmd
265212
Reply By: Diane - Friday, Oct 05, 2007 at 20:23
I have just found some called happijacs in the US so that might have to be the way.
At least the dollar might make it a bit cheaper at the moment!
Diane
265217
Reply By: Member - Linda M (VIC) - Saturday, Oct 06, 2007 at 10:58
Hi Diane
Try Freedom Off Road in Penrith NSW. I bought my slide on there and it came with standard Happijac (this is the correct spelling) legs. I'm pretty sure they would keep both the standard and elctric ones in stock as the electric ones were offered as an option.
http://www.freedomoffroad.com.au/
265279
Reply By: Diane - Sunday, Oct 07, 2007 at 10:49
Thanks, I will give them a call tommorrow!
Diane
265411
