You out there Jimbo?
Submitted: Saturday, Oct 06, 2007 at 22:18
Member - Kim M (VIC)
Jim
I called into your stand this morning, but nobody was in attendance.
I'm after a bit of advice on where I can get anchor points for the inside of a trailer to secure the contents.
The product I'm after is recessed within a flat base that can be bolted to the floor of a camper trailer. They have an anchor point that can be lifted vertically to Attach to a ratchet strap.
Any help you can give would be appreciated.
PS Good product your supplying.
Well done.
Kim
Reply By: Shaker - Saturday, Oct 06, 2007 at 22:39
Carac Dandenong or try Colrain Trail Truck.
265359
Reply By: Jimbo Vic - Sunday, Oct 07, 2007 at 07:30
Kim,
Jenny and I were there all day. Iit may have been whilst I was showing someone the 57 L Engel upright fridge that fits into the "double stacker" to eliminate the need for hard to reach into chest fridges on a slide.
As for the mounting points you are after, give me a call on 03 9706 6527 on Monday and i should be able tp put you in contact with someone.
ATB,
Jim.
265378
Follow Up By: Member - Kim M (VIC) - Sunday, Oct 07, 2007 at 18:03
Will do.
Kim
527394
Follow Up By: Member - Kim M (VIC) - Monday, Oct 08, 2007 at 20:03
Jim
The company you put me on to have them. Many thanks.
Kim
527576
Follow Up By: Jimbo Vic - Monday, Oct 08, 2007 at 20:45
Happy to help Kim.
527588
Reply By: QLD Kev - Sunday, Oct 07, 2007 at 07:38
Kim,
Have you looked at these
Anchor Track
Cheers Kev
| Russell Coight:
265379
Follow Up By: Member - Kim M (VIC) - Sunday, Oct 07, 2007 at 18:15
Kev
Looks interesting. I assume the anchor points slide along the channel?
Kim
527396
Follow Up By: QLD Kev - Sunday, Oct 07, 2007 at 19:06
Kim,
They slide along the track and lock in every 100mm from memory. You can get lengths of track up to 2m and can fit multiple anchor points. They are fixed by high tensile pop rivets.
I have used them in refrigerated shipping containers used as a makeshift
first aid post. They were to hold every thing in place whilst in transit.
Cheers Kev
| Russell Coight:
527400
Follow Up By: Member - Kim M (VIC) - Sunday, Oct 07, 2007 at 19:21
Kev
Can you use a bolt and nut rather than pop rivets?
From experience a rachet can place a far bit of pressure on the anchor point. Thanks.
Kim
527401
Follow Up By: QLD Kev - Sunday, Oct 07, 2007 at 19:27
Kim,
If you can get a bolt to fit I don't see why not. If not you may need to position the anchor points before you fix which would defeat the purpose of the adjustable track mount.
The ones we installed held full sized domestic fridges in place by pop rivets and never failed, that included using ratchet straps.
Kev
| Russell Coight:
527406
