Pajero NL (1999) Coolant Drain Plug - Where is it?
Submitted: Sunday, Oct 07, 2007 at 08:18
AndrewNetty
Dear all,
I am having trouble locating the coolant drain plug on my 1999 Pajero V6 3.5 (NL) .
Can anyone out there tell where it is (and what I am looking for) as I have not been able to locate it and can therefore only drain from the radiator which is only one third of the coolant system.
Reply By: Col88 - Sunday, Oct 07, 2007 at 19:48
Andrew,
I believe there are two, one on each side of the block.
I remember seeing reference to this on another site. I did a search on it and came up with this. Not exactly what you are after, but it talks about putting a flushing tap in.
http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB69&Number=1024957&Forum=,,,,,,,,,,,,,,,,,,f69,,,,,,,,,,,,,,,,,,&Words=coolant%20drain&Searchpage=5&Limit=25&Main=1024957&Search=true&where=bodysub&Name=&daterange=0&newerval=&newertype=&olderval=&oldertype=&bodyprev=#Post1024957
Longest link in the world, I hope it helps. The original thread on that site has pics of the the drain plug. Have a search there.
265470
Follow Up By: AndrewNetty - Sunday, Oct 07, 2007 at 23:06
Hello, Thanks for your efforts. I could not see any link and therefore I am none the wiser.
Thanks anyway.
regards
527448
Follow Up By: Col88 - Monday, Oct 08, 2007 at 19:50
Cut and paste the THREE LINE LINK into your browser.
This will take you to that thread. You can then search that site for the pics of the block drain plug.
Probably easier to put the flushing tap in or flush it through the thermostat housing though.
527572
Reply By: donks1 - Monday, Oct 08, 2007 at 08:31
the drain plug is in the bottom right of the radiator, where the drain hose comes out, assuming its the origional
donks
265526
