OziExplorer Problem
Submitted: Sunday, Oct 07, 2007 at 15:42
Mikee5 (QLD)
Hi there, can anyone tell me what is going wrong for me?
I import the following from a txt file:
Datum,Australian Geocentric 1994 (GDA94)
WP,DMSX,1,-27,11,91,152,49,28,10/07/2007,14:30,Crown Hotel,A,N,-9999
The waypoint comes up in Ozi as 27 12 31, 152 49 28.
I can right click on the waypoint to edit it but when it has been edited it goes back to the above!
What am I missing?
Mike
Reply By: Member - Peter D M - Sunday, Oct 07, 2007 at 16:42
mike,
i think you are using different datums. it looks like ozi is set to wgs84
regards peter
265439
Follow Up By: Member - Andrew (QLD) - Sunday, Oct 07, 2007 at 17:45
Nope....there is bugger all difference between WGS84 and GDA94.
See below for the answer :-)
527392
Reply By: Richard Kovac - Sunday, Oct 07, 2007 at 17:33
Mike
Maybe try changing you Lat/Long display in the config setting, maybe reading two differance things
Richard
265445
Reply By: Member - Andrew (QLD) - Sunday, Oct 07, 2007 at 17:47
You have an incorrect latitude entered......-27,11,91. There is no such thing as 91 seconds so it will carry an extra minute over and leave 31 seconds (91 seconds = 1 minute +31 seconds) This will produce 27 12 31.
265447
Follow Up By: Mikee5 (QLD) - Sunday, Oct 07, 2007 at 18:00
Thanks Andrew,
Another seniors moment for me I guess.
I re-wrote the txt file and it works.
Mike.
527393
Follow Up By: Member - Andrew (QLD) - Sunday, Oct 07, 2007 at 18:09
Don't worry, i did the same years ago (and i'm not a senior) and it took me some time to find.....i blame others usually. :-)
527395
Reply By: Tony MD - Sunday, Oct 07, 2007 at 18:17
Mike, In ozie, go to FILE - CONFIGURATION - MAPS
In the maps section, alter the Lat/Long display to read Degrees, minutes.
This will read minutes and seconds as decimal minutes and put new Crown somewhere to the north of
Brisbane.(-27 11.910') (152 49.28')
If this is still wrong, then change the Lat/Long display to minutes
(-27 .11910) (152 .4928) and put you NW of
Brisbane.
Once the waypoint is correctly entered, you can then set the configuration back to how you previously had it. Ozie will convert the waypoint coordinates to the selected display.
I prefer degrees, minutes, seconds
Cheers, Tony
265453
Follow Up By: Member - Andrew (QLD) - Sunday, Oct 07, 2007 at 18:55
The waypoint file is in Degrees, Minutes, and Seconds as described by the second field.......DMSX . It is wrong to change the format when it is specified by the file.
The file format is broken down as follows:
WP, waypoint name, latitude(multiple fields), longitude(multiple fields), date , time , waypoint description, symbol, Garmin GPS waypoint display format, height.
527398
Follow Up By: Member - Andrew (QLD) - Sunday, Oct 07, 2007 at 19:01
whoops....forgot to add "coordinates format" eg DMS as the second field, which is important in this thread :-)
527399
