Holden Motors
Submitted: Monday, Oct 08, 2007 at 16:41
ThreadID: 50356 Views:1924 Replies:4 FollowUps:0
Hi. Does anybody know if a Holden red or blue engine can be converted to ULP? and is it very costly or efficient?
Reply By: Notso - Monday, Oct 08, 2007 at 17:27
As I recall, Holden went to a Nissan motor for a few years on the changeover to ULP while they were developing their own, or modifying a yank motor.
So obviously they didn't think so.
Main problem is valve train wear, eg valve stems and seats that were protected to some extent by the lead in the fuel.
AnswerID: 265588
Reply By: Ianw - Monday, Oct 08, 2007 at 17:56
The only modifications needed are fitting of hardened valve seats and lowering of the compression ratio for ULP. If premium unleaded was used then the compression would not need to be lowered. If you were not using it for highway use then the valves and seats will last a long time anyway without modifications as the temperature would not get high enough to erode the valve seats.
Ian
AnswerID: 265594
Reply By: Gerhardp1 - Monday, Oct 08, 2007 at 18:00
Check this link for some solutions.
Site Link
Should be no problem to find what's best for you.
AnswerID: 265596
Reply By: Member - Christopher P (NSW) - Tuesday, Oct 09, 2007 at 23:23
ditch the holden idea and buy a foord or tojo!!!
Hehehe
AnswerID: 265847
