2005 Toyota Landcruiser TD GXL Problem
Submitted: Monday, Oct 08, 2007 at 22:09
White Knight
Just wanted to see if people have had issues with newer landcruiser. I've just found a oil patch in my driveway. I grabbed out the crawler to slide under and have a look. Found that the front right drive shaft seal is leaking. This maybe caused by a recent trip up to
Cape York with the river crossings (failing to cool down enough). Luckily it's covered under warranty. Anyone else had similar issue?? Is it worth me paying the extra to get the left hand side replaced while their at it, or take the punt and wait till the warranty runs out, then guaranteed the left will then go ($1200 to replace).
Reply By: Member - DOZER- Tuesday, Oct 09, 2007 at 14:00
do u mean the c/v boot?? outer near the wheel?? Will have sustained damage on rocks or sticks....just get that one replaced...but make sure the c/v is not clicking on full locks, otherwise get the lot replaced.
265757
Follow Up By: White Knight - Tuesday, Oct 09, 2007 at 20:41
no, the opposite end. The drive shaft seal from the front diff.
527794
