A query re factory settings Nissan 4.2 tdi
Submitted: Tuesday, Oct 09, 2007 at 08:24
ThreadID: 50372 Views:2397 Replies:4 FollowUps:8
G'day Folks, I own a 03 4.2tdi Patrol wagon and am getting it dyno'd this Friday. I'd be interested to see what the differences from factory settings were made from people who own one and have had it done. ie pump timing, pressure etc. I already have a 3" exhaust right through including dumpipe. Denco Diesel are doing the work and it will give us a a day in Wagga.
cheers Dave
Reply By: brett patrol - Tuesday, Oct 09, 2007 at 09:23
Hi Dave,
I have an 03 4.2tdi ute, it made 79rwkw with 35" tyres with no engine mods. I had a 3" exhaust and dump pipe fitted and increased boost to 12psi and it made 99rwkw with 35" tyres.
Not bad power for the 1200 bucks it cost me.
Brett
AnswerID: 265705
Follow Up By: Wayne-o (Pilbara WA) - Tuesday, Oct 09, 2007 at 09:28
hey there dave.
Just curious how you got 12lb boost from the standard turbo, considering the maximum achievable is 11, because that's the maximum the diaphram on the wastegate actuator will handle. Not saying ya didn't, just wanna know how. I run 16lb, or 1.3 bar, and had to change actuator assembly.
Wayne-o
FollowupID: 527667
Follow Up By: GO_OFFROAD - Tuesday, Oct 09, 2007 at 10:59
if you dont use the MTQ cast 2/14 inch dump pipe and have a true 3" one made, and retime the pump from .76 to .79, and get MTQ to machine the turbo, and run 15 psi you should see around 130 rw kw + on 35's.
I would recommend a pyro post turbo to gauge in cab to "keep an eye" on things though.
FollowupID: 527688
Follow Up By: brett patrol - Tuesday, Oct 09, 2007 at 12:50
Not sure exactly how they achieved that amount of boost. I do know they played around with the wastegate.
Sorry i couldnt be more help.
Brett
FollowupID: 527701
Follow Up By: GO_OFFROAD - Tuesday, Oct 09, 2007 at 12:59
boost controller, it sees boost one side, and tells wastegate something different ;-)
FollowupID: 527702
Follow Up By: Wayne-o (Pilbara WA) - Tuesday, Oct 09, 2007 at 13:02
I know how a boost controller works, check rig profile.
FollowupID: 527703
Follow Up By: GO_OFFROAD - Tuesday, Oct 09, 2007 at 14:04
you might, but your assuming the reply was for just you......
FollowupID: 527713
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Oct 09, 2007 at 14:24
GO_OFFROAD do you do any tuning as a business yourself? Being in Geelong and closer to me it could be easier than some of the "other side of Melbourne" tuners......
FollowupID: 527718
Follow Up By: GO_OFFROAD - Tuesday, Oct 09, 2007 at 15:31
We sure do, 0409 513 549 if you would like more details, have one with those mods here which is mine as well.
Daz.
FollowupID: 527727
Reply By: Wayne-o (Pilbara WA) - Tuesday, Oct 09, 2007 at 09:30
Madcow.
Factory timing setting is 0.76.
and 9psi boost.
you can get timing advance, simply be aware that the car may run on after the ignition is shut off, for a second or two, although no drama if you have a turbo timer because you won't notice it.
you should be able to make around 110-140rwhp, all depending on dyno though.
wayne-o
AnswerID: 265707
Reply By: madcow - Tuesday, Oct 09, 2007 at 09:47
Ta for that fellas. I'll post the readings next week. Car has 65,000kms.
cheers Dave
AnswerID: 265709
Reply By: madcow - Friday, Oct 12, 2007 at 17:05
Well the results are in.
Max Power 109.6bhp at rear wheels 138kmh
Max Torque 321.7lb-ft at 78 kph
all done in fourth gear though wether top may have made a difference I'm not sure. It has progressive power right across the rev range. Who knows in top gear it may hit the ton!!
AnswerID: 266323
