Aftermarket Turbo Oil Feed for 1HZ
Submitted: Wednesday, Oct 10, 2007 at 11:45
Ruffstuff.
Hi Folks,
I'm considering having an turbo fitted to a my 1HZ.
can anyone tell me were they take the oil feed from on the motor?
the Turbo is a Mitsubishi TD05.
Reply By: Member - 120scruiser (NSW) - Wednesday, Oct 10, 2007 at 11:49
You screw out your oil pressure switch, fit a t piece that takes the switch and the other side goes into a braided line that goes over the engine and into the turbo.
All fittings come with the Denco kit. I fit these kits as I like their quality and service. No affiliation, just a fitter.
265892
Follow Up By: Ruffstuff. - Wednesday, Oct 10, 2007 at 12:28
120scruiser,
Thanks for your reply, any idea what the thread size is for the T-piece/ sender?
527910
Follow Up By: Member - 120scruiser (NSW) - Thursday, Oct 11, 2007 at 18:39
1/8 gas will do the trick.
528203
Reply By: ob - Wednesday, Oct 10, 2007 at 17:12
120scruiser. just an enquiry re turbo oil feed. does taking oil to lube turbo from this fitting affect pressure reading on gauge?
thanks ob
265932
Follow Up By: Member - 120scruiser (NSW) - Thursday, Oct 11, 2007 at 18:40
I have fitted quite a few turbos including one to my own 1HZ and never noticed any difference in oil pressure, at least not enough to make a difference.
528205
Reply By: Member - DOZER- Wednesday, Oct 10, 2007 at 19:47
The thread is 1/8 bspt or something compatable with that... Once the turbo is fitted up, oil pressure will remain thesame at above idle and if anything, slightly less at idle due to more being used and lost from the oil gallery....
265960
