Advice from other shooters required
Submitted: Wednesday, Oct 10, 2007 at 20:46
Member - Kim M (VIC)
I have a Sako 75 .243 stainless with wooden stock. The rifle is in show room condition (two years old).
I'm in the early stages of a muscle disease, and am now finding it's a bit heavy for me. A good alternative appears to be the Sako 85 Finnlight in the same caliper. Couple of questions:
1. What would I expect as a tradein value (the Leopold scope is not included)
2. Comment re the Finnlight
I'm prepared to put up with a bit more recoil, but need something more comfortable to shoot with.
Kim
Reply By: Anthony (Vic) - Wednesday, Oct 10, 2007 at 20:59
I don't know what your Sako 75 is worth. How many round have gone through it?
A couple of options, you ask for a trade-in price a your local gun
shop for a new Finnlight (should give you a ball
park price) Second, if an SSAA member, have a chat with a the guys in the Field Hunter Group (meet at Springvale Range Vic). Last, look in the SSAA monthly journal, which has secondhand section.
265988
Follow Up By: Member - Kim M (VIC) - Wednesday, Oct 10, 2007 at 21:14
Anthony
It would less than 50 rounds. I'll be talking to a number of local shooters next week before going into a gun
shop. However, I'm interested in receiving advice from other shooters before that.
Kim
528021
Follow Up By: Anthony (Vic) - Wednesday, Oct 10, 2007 at 21:34
There is a new Sako 75 stainless w/ synthetic stock in .243 for sale in Qld for $1849, in an advert in Oct issue of Australian Shooter p.43 (the SSAA monthly mag).
528029
Reply By: Gramps (NSW) - Wednesday, Oct 10, 2007 at 21:01
Kim,
Try
here
265989
Follow Up By: Moose - Thursday, Oct 11, 2007 at 14:49
G'day Gramps
You on there too?
I'm a regular visitor under same name as here.
Cheers from the Moose
528165
Follow Up By: Gramps (NSW) - Thursday, Oct 11, 2007 at 16:43
G'day Moose
I'm only an occasional visitor on there these days although I seem to remember some posts by Moose. If you see some dumb posts by Shooteratter, it's probably me hahahaha
528185
Reply By: George_M - Wednesday, Oct 10, 2007 at 21:17
Hi Kim
I'm not sure that you'll find much difference in the weight of a Model 85, relative to that of a Model 75. I think the difference is a fraction less than half a kg.
I think also that the best deal you'll get on your Model 75 is per Anthony's suggestion - a trade in price on whatever you decide to buy. Failing that, you could try the "for sale" column in the Shooters Journal.
George
265994
Follow Up By: Member - Kim M (VIC) - Wednesday, Oct 10, 2007 at 21:31
Thanks George
There is a considerable difference in the weight of the two rifles (or it feels that way). The Finnlight is far more a grab and shoot rifle.
Kim
528027
Reply By: The Rambler( W.A.) - Thursday, Oct 11, 2007 at 00:02
Hi KIM,
Having done a fair bit of shooting over the years my first question would be what are you using the gun for?If it can be replaced with a smaller callibre you might be better off with a 223,22250, or even a hornet.As for the trade in price on the 243 I would say depending on condition $1500 would be a realistic price without the scope.Good luck and I hope you can continue shooting for many years.
266021
Follow Up By: Member - Kim M (VIC) - Thursday, Oct 11, 2007 at 16:14
Hi Rambler
Pigs and Roos.
Kim
528182
Follow Up By: Russ n Sue - Thursday, Oct 11, 2007 at 19:02
G'day Kim,
I'm with the Rambler on this one. If you main quarry is pigs and roos (and I hope your popping the roos legally), then a 223 is more than enough gun for both of these species. Especially if you are a good shot.
I have a .22, a 223 and a 6.5 x 55 and I find that I only really use the 223 these days.
You can get these in any permutation you want...wood stock, nylon stock, staino barrel, steel barrel and so on. Just choose a combo that's light and reputed to be accurate out of the box and you'll be fine.
Can't really help you with what you can expect for the old one but I suspect you'll do better if you trade it in on the new one.
Russ.
528213
Reply By: brushmarx - Thursday, Oct 11, 2007 at 11:18
Could try a bit of lateral thinking.
Tie a couple of small helium balloons onto the rifle, the lighter you want, the more balloons required. Easy as, and cheap.
266075
Reply By: Member No 1- Thursday, Oct 11, 2007 at 11:54
any one got some loading data for
38spec for WA15oo match
and varmint shooting with 7mm08 Ack Improved
ooops wrong
forum...hehehe
266079
Follow Up By: Anthony (Vic) - Thursday, Oct 11, 2007 at 12:42
I gather the 7mm08 ack is for the bigger "goat type" varmints.
528145
Follow Up By: Member No 1- Thursday, Oct 11, 2007 at 12:44
yes...but not restricted to them only
528147
Follow Up By: Anthony (Vic) - Thursday, Oct 11, 2007 at 12:56
I used to shoot a bit of silhouete & had a 7mm ack (7x57 case) made up. I had the same issue with no loading data avail but worked it out very slowly. The only problem with it is to heavy the lug around the bush.
528148
Reply By: HowdyDoody - Thursday, Oct 11, 2007 at 12:59
Try contacting the guys at
http://www.platatac.com/
A great bunch of guys who will be happy to advise you or point you in the right direction. I believe they are licensed dealers but may not have specifically what you are after. They are based in Hallam, Victoria. Usually focus only on military or police but their personal and professional knowledge and experience is far reaching.
266085
Reply By: Steve63 - Thursday, Oct 11, 2007 at 16:30
Does it have the Varmint barrel? Have you thought of getting a lighter barrel?
Steve
266127
Follow Up By: Member - Kim M (VIC) - Thursday, Oct 11, 2007 at 16:54
Steve
The rifle is a standard 75 hunter with stainless barrel.
As mentioned above, I'm after something a bit lighter, hence the interest in the Finlite. Unfortunately their around $500 more expensive than the Hunter.
I'd rather stick to Sako because of the accuracy and quality of the rifle. However, I'm open to suggestions provided there is less weight in the gun.
Kim
528191
Follow Up By: Steve63 - Thursday, Oct 11, 2007 at 17:21
Kim,
Barrel and scope are often a lot of the weight. Brother in law had a SAKO 243 rechambered to 243 Ak improved with super heavy Varmint with a Redfield scope. It was so heavy that I couldn't hold it still enough to shoot anything more than 20 m away. It was a pain in the bush. Unless you needed a battering ram. He has changed the barrel to a shorter lighter barrel (still a target quality barrel) in 22-250. Last I saw him shoot he missed one bull in the
seat and post shoot over 200 yards in poor conditions.
I suppose my point is you have a good rifle, rebarreling could be a cheaper option. It could still be a good rifle but a lot lighter. If it needs to be lighter still a could help out.
If you know anyone who shoots Silhouette I would speak to them. They ususally know all the tricks like tapered barrels etc.
Steve
528196
Reply By: V8Diesel - Thursday, Oct 11, 2007 at 18:04
Remington are making a short barrelled hunter from memory.
Aftermarket lightweight stock may be the answer as you keep a proven performer and don't have the insult of low trade-in prices and all the police paperwork. Also, it would make it more practical as a 'knock around' while keeping your sunday best
stock for special occasions.
Nice rifle in a nice calibre with excellent optics - it'd be a shame to let it go.
266145
Follow Up By: Member - Kim M (VIC) - Thursday, Oct 11, 2007 at 19:45
Diesel
That makes a lot of sense. The Remington action is very good. I might change my mind after thinking about what your said.
The answer could be that I retain the Sako, and purchase a knock around light weight for quick use in the bush.
Kim
528230
Reply By: garthyguts - Thursday, Oct 11, 2007 at 19:44
trade in $$450.00
sell $$550/650
best to see if you can swap with someone
266181
Follow Up By: Member - Kim M (VIC) - Friday, Oct 12, 2007 at 17:50
garthyguts
I think you're getting your rifles mixed up mate.
Kim
528426
