80 series sub/altimeter gauge globes
Submitted: Thursday, Oct 11, 2007 at 08:32
Robnicko
HI,
Does anyone out there know of aftermarket globes that will fit in the alti/sub fuel
tank gauge of an 80 series cruiser (overhead console)?
They are similar to LED size but have a circular base with +ve and -ve tabs.
Preferably in
Melbourne would be appreciated. The Toyota part number is 84999-50280 and $10 each seems a bit steep.
Thanks,
Rob
Reply By: Steve L - Thursday, Oct 11, 2007 at 09:04
I couldn't find any when looking last year, so bit the bullet and bought the Toyo parts.
266057
Follow Up By: Robnicko - Thursday, Oct 11, 2007 at 09:09
Thanks Steve.
I am trying to locate them on the web, If successful I will pass on any info.
Rob
528112
Reply By: Axel [ the real one ] - Thursday, Oct 11, 2007 at 10:00
Think you will find that the globes are the same as the globes in the switches , sub
tank- rear demister ect ect , I picked up replacement globes at "Aussie Auto" but would think that Repco would also have them , seem to remember that paid 50cents each ,,
266066
Follow Up By: Robnicko - Thursday, Oct 11, 2007 at 10:03
Thanks Axel,
I have been looking at the Narva website and they seem to have a very similar globe as
Thanks again
Rob
528125
Reply By: Member - Douglas M (SA) - Thursday, Oct 11, 2007 at 19:27
Hi Robnicks,
remove the old globe from its plastic holder and replace it with a "
water-clear" light emitting diode as near as possible to the diameter of the original globe with a resistor in series. Jaycar. Dick Smith or Altronics should have them and will advise you of the value resistor to use. When you remove the blown globe you will see what is required. You end up with the LED where the old globe was and a resistor on the opposite side. LEDs are polar so if it won't come on turn the new "globe" 90 degrees and it will work. It is much cheaper than buying a new overhead console and will last forever.
doug
266166
Follow Up By: Robnicko - Friday, Oct 12, 2007 at 11:38
Doug,
Thanks for the reply. I just removed the globe from the holder and see what you mean. I will go to Jaycar later today.
thanks again,
Rob
528357
