www.ExplorOz.com
Your browser does not support the site menu
Click Here
to load alternative navigation.
Latest News
Road Conditions
Updated 30/08/2008
SA Deserts
QLD Coast
Updated 29/08/2008
Top End
Adelaide and Hills
Flinders Ranges
Outback NSW
Road Conditions
All News...
Site Updates...
Search by Topic
Permits for Queensland
4WDriving
Accessories
Accommodation
Activities
Boating
Campers & Trailers
Camping
Caravanning
Communications
Cooking
Driving Skills
Electrics
Fishing
Itineraries & Planning
Membership
Motorhomes
Navigation
Permits
PlotSwap
Recovery Gear
Servicing
Survival
Technical
Things To Do
Topics
Tours
Trek Notes
Trips with Kids
Tyres
Vehicle Choices
Visit Australia
Newsletters
Your Name
Email Address
Past Newsletters
Full Index
161
162
163
Current Users
Members
25
Customers
Visitors
21
Anon
1154
Total
1200
List...
Not Logged on
Driving Lights Feedback
Submitted: Thursday, Oct 11, 2007 at 21:28
Member - Bruce F (SA)
Article Overview - Driving Lights
If you plan to do any night driving in the outback then a strong reliable light source is a must.
View Full Article...
How does one best set up the
driving lights
on the vehicle so they aim correctly - eg added weight in the rear of the vehicle will cause the beams to aim for the sky in place of the road surface. Also to have the beams placed correctly
on the road
ahead, i.e., aimed correctly, laterally as well as vertically. Is it considered necessary to adjust the light settings every time the vehicle load changes?
Member:
My Profile
Advertisement
Suppress Advertisement - Members Only
AnswerID: 266225 Submitted: Thursday, Oct 11, 2007 at 21:59
DIO
replied: 1. Trial & error
2. Yes if you don't want to blind on-coming traffic and also if you want maximum illumination down the road.
Reply 1 of 6
AnswerID: 266229 Submitted: Thursday, Oct 11, 2007 at 22:06
disco driver
replied: Hi Bruce,
IMHO you would set the
Driving lights
marginly below horizontal with your most common load on board.
Laterally,it would depend on personal preference: some like 2 Spots and others prefer 1 Spot and 1 Spread beam. Some using 2 spots aim them straight ahead, others aim them marginly to the side.
Using 1 Spot and 1Spread, they are generally set with the spot horizontal or slightly lower and straight ahead and the spread beam much the same as it fills in behind the Spot and also covers the verges for a fair distance.
There is no way to set them up to suit yourself than to find a dark street of some length and, using blankets or black plastic (mind the heat from the lights) black out all but the beam you are setting and adjust it to suit your preferences. Repeat for the other lights as necessary.
Good Luck
Disco
Reply 2 of 6
AnswerID: 266245 Submitted: Friday, Oct 12, 2007 at 00:44
Sand Man (SA)
replied: Mate,
If your
driving lights
"head for the sky" when you load up the rear of the vehicle, you have a serious
suspension
problem.
It should not be necessary to adjust the lights everytime the vehicle load changes.
Either you need to replace the rear
suspension
(springs, shockers), or add airbags, or do both.
Click Image to Enlarge
HooRoo !
Member:
My Profile
Reply 3 of 6
AnswerID: 266263 Submitted: Friday, Oct 12, 2007 at 07:58
Member - Oldplodder (QLD)
replied: Two solutions.
1. I havn't found a bit of road yet that is continuously flat for the whole trip. So I set one light a bit high and one a bit low.
I also have my lights slightly crossed horizontally for the same reason, to help with corners and seeing into the verge.
2. I have a stiffer rear
suspension
and air bags for heavy loads, so I can get it back to roughly standard height.
John C - aka Oldplodder
In touring mode, the way it should be.
Member:
My Profile
Reply 4 of 6
AnswerID: 266266 Submitted: Friday, Oct 12, 2007 at 08:59
Member - Chris R (NSW)
replied: Mate of mine has a short steel strap attached to the top of the light. the other end is slotted and attached to the top rail of the bull bar. This takes some of the vibration stress out of the bottom bracket and allows him to make fine adjustments. In fact he now bends that strap to make fine adjustments - obviously a perfectionist.
We only got to talking about this when comparing notes about our experiences with cracked light support brackets - his being ARB bar and mine (I think)
TJM
. My solution to stop cracking in future was to weld vertical supports attaching from rear of light bracket down to the top surface of bumper. (These make for very stable lights. Did similar for front HF aerial support which got knocked around by scrub.)
I cross beams - so not such aproblem - but I do need to get another light for straight up the middle.
Chris
Peace and smiles
Member:
My Profile
Reply 5 of 6
FollowupID: 528344 Submitted: Friday, Oct 12, 2007 at 10:53
Member -Signman posted:
What I use is a Utilux type 'hose' clamp- about 150mm dia.
Cut the clamp opposite the tightening screw and straighten out to a strip. Pop rivet one end to the top of the body of the light, and the other end to (say) the radiator support panel.
This secures the lights from vibration, and allows micro adjustments with the worm screw!!
Each morning I seize the day...
but by mid afternoon it has escaped!
Signman- NSW
VKS737 R3364 Selcall3364
Amateur Callsign: VK2EZY
Member:
My Profile
AnswerID: 266269 Submitted: Friday, Oct 12, 2007 at 09:19
Axel [ the real one ]
replied: How friendly are you with your local road worthy certificate service station / mechanic , correct way is to have the lights aimed using the "light box" and chart , otherwise just use a dark night and lots of fiddiling , a flat place to park and a large wall and a dark chalk to mark the increments up-down-side to side ,,
Opinions are like "bleep" ,everyone has 1 , mine works.
Member:
My Profile
Reply 6 of 6
FollowupID: 528795 Submitted: Sunday, Oct 14, 2007 at 21:54
Mamba No 1 posted:
Axel I think he meant where to align the lights for many different loads. I dont think u can.
New/Updated
West Australian Map Book $9.95
Wildflower Country $9.95
Nissan Patrol GU Rear Door Bracket Extension $26.95
SPOT Satellite Messenger $249.00
Navy/White Racer Polo Shirt - TMTE $37.00
Mens Navy/White Polo Shirt - TMTE $31.95
Ladies Navy/White Polo Shirt - TMTE $31.95
Khaki Polo Shirt - TMTE $24.95
Fast Find
Shop Home Page
Discounted Items
Latest/Updated
All Items
Home
About Us
FAQ
Feedback
Site Stats
Membership
Advertising Campaigns
Site Updates
Forum
Blogs
Forum Archive
Trader
Shop
Treks
Places
Directory
Articles
Topics
RSS Feeds
Link to Us
Terms of Use
Corporate Membership
Privacy Policy
Copyright © 1999 - 2008,
I.T. Beyond Pty Ltd.
All rights reserved.
