LED battery voltage display
Submitted: Friday, Oct 12, 2007 at 16:10
ThreadID: 50492 Views:3223 Replies:7 FollowUps:7
I am looking for an inexpensive LED cabin mounted battery voltage display for my dual battery set up in the 100 series. Where can i source such a device?
Reply By: Member - Cruiser (NSW) - Friday, Oct 12, 2007 at 16:21
LCD or LED ?
AnswerID: 266311
Reply By: Boobook2 - Friday, Oct 12, 2007 at 16:39
Try Jaycar
www.jaycar.com.au
AnswerID: 266317
Reply By: Fnqt2 - Friday, Oct 12, 2007 at 16:52
Gday Syd R , oppsite lock have a dual battery monitor i have installed in my ute 140 bucks i think it is.
AnswerID: 266321
Reply By: Mikee5 (QLD) - Friday, Oct 12, 2007 at 17:42
ABR who advertises on this site has one. 4 LEDs, Red, Yellow and 2xGreen. I have one and it works.
AnswerID: 266326
Reply By: Brew69(SA) - Friday, Oct 12, 2007 at 19:55
i think the ones that display an exact voltage are the go. The digital one.
AnswerID: 266343
Reply By: yowie - Friday, Oct 12, 2007 at 20:13
This is my setup.
AnswerID: 266344
Follow Up By: yowie - Friday, Oct 12, 2007 at 20:15
The meters are about $15 each with shipping off ebay. They come in Green & Red.
FollowupID: 528450
Follow Up By: Gronk - Friday, Oct 12, 2007 at 23:02
Easy to install ?? In other words.....neg and pos leads coming out the back of the meter ?? Where abouts on ebay ?? Sixty thousand places to look on ebay ??
FollowupID: 528496
Follow Up By: yowie - Friday, Oct 12, 2007 at 23:46
Very easy to install four wires it uses a 5V powersupply ( i used an old Nokia Phone Charger) then just the two wires for the 12V supply.
Ebay Ad LED Volt meters
FollowupID: 528498
Follow Up By: Brew69(SA) - Saturday, Oct 13, 2007 at 08:34
Ok now i'm confused. It uses a 5V power supply? I have this one at home and it states supply voltage at 5V too. It also has 10 pins on the back of the unit. How can i make this work? Any ideas?
FollowupID: 528511
Follow Up By: Member - Olcoolone (S.A) - Saturday, Oct 13, 2007 at 18:19
Why not go to Jaycar or Dick Smiths and buy a LM7805 5 volt regulator, small and easy to setup.
Regards Richard
FollowupID: 528585
Follow Up By: yowie - Saturday, Oct 13, 2007 at 20:18
Brew69
These units are four wire, i would need to see your units circuit diagram. I would think the diffent connections might be different voltage taps, two of them will be the meters supply. If you don't have an old mobile phone charger you ca use one of these.
FollowupID: 528622
Follow Up By: yowie - Saturday, Oct 13, 2007 at 20:30
Brew69
I Just looked at the link sorry i didn't notice it at first.
If you have a CX102B
Pin 1: 5 volts + ( powersupply )
Pin 2: 5 volts - ( powersupply )
Bridge Pin 3 too Pin 5 for two decimal points ( 0v to 20v )
Pin 7: 12 volts + ( your car battery )
Pin 8: 12 volts - ( your car battery )
FollowupID: 528627
Reply By: PradOz - Sunday, Oct 14, 2007 at 21:58
Have a look at ebay and search item number 330175206154.. For $70 it maybe what you want as it only needs a switch to setup for both batteries. It is portable also so you can take it out if you have a use elsewhere. If you have any questions just ask the seller a question as he is quick with a detailed reply. Cheers.....
AnswerID: 266576
