Power consumption monitor for a caravan
Submitted: Sunday, Oct 14, 2007 at 18:10
ThreadID: 50549 Views:4227 Replies:8 FollowUps:9
I have recently seen a caravan with a 12v power consumption monitor which at the same time indicated how much power was consumed when various appliances were switched on and also indicated how long you could run these appliances with the available battery power.
That was a bit long winded but I hope you can understand what I mean.
If anyone has details of such a monitor and where they can be bought I would be most gratefull if you can advise me on this forum
Reply By: Member - Phil G (SA) - Sunday, Oct 14, 2007 at 18:33
Not exactly what you want, but I measure volts, current and capacity with an Eflite Power meter.
Capacity is limited to 9.999 amphours, but it will measure up to 120amps. Very useful in getting your head around how much electricity you're using.
AnswerID: 266536
Follow Up By: Member - George (WA) - Tuesday, Oct 16, 2007 at 16:58
Thanks Phil not exactly what I am looking for
FollowupID: 529166
Reply By: PeteS - Sunday, Oct 14, 2007 at 19:36
Hi George
Have one of these in my KKaravan. Seems most marine dealers have them.
Try this link DC Meter or do a google search for BEP DC monitors. Looks as if it set you back a few $.
Pete S
AnswerID: 266550
Follow Up By: Member - George (WA) - Tuesday, Oct 16, 2007 at 17:00
Thanks Pete, not what I am looking for
FollowupID: 529167
Hi George
Pete S
AnswerID: 266551
Follow Up By: PeteS - Sunday, Oct 14, 2007 at 19:37
Ooooooooops. Twice as good :-)
FollowupID: 528776
Reply By: Scrubcat - Sunday, Oct 14, 2007 at 20:11
Google "Xantrex- Link 10" or "Xantrex Link 20", Excellent but not cheap.
Scrubcat.
AnswerID: 266561
Follow Up By: Member - George (WA) - Tuesday, Oct 16, 2007 at 17:01
Thanks Scrubcat, that seems to do the job, bit pricy
FollowupID: 529168
Reply By: PradOz - Sunday, Oct 14, 2007 at 20:16
Hi George - Have a look at this new 12 volt monitor on ebay. AT around $70 it mabe a cheaper option if it is what you are looking for. It looks very similar to the $300+ one mentioned in the other reply.
Ebay item - 330175206154
Cheers Mick
AnswerID: 266562
Follow Up By: Member - Mike DID - Monday, Oct 15, 2007 at 23:07
This is only a Voltmeter and Low Voltage Alarm - it makes no attempt at determining Capacity use dor capacity Remaining.
FollowupID: 528987
Follow Up By: Member - George (WA) - Tuesday, Oct 16, 2007 at 17:03
Thanks Mike, it is not what i am looking for. Also need the other read-outs
FollowupID: 529169
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Oct 14, 2007 at 23:10
Hi George
If you want amp totals then the NASA BM-1 is a better option.
This is what I use in my own van. Just note they are 4 inch so you need some space to mount them.
Derek.
AnswerID: 266586
Follow Up By: Member - George (WA) - Tuesday, Oct 16, 2007 at 22:29
Thanks Derek. That looks like what I need. Do you have any idea of price. You can email to me via this forum
FollowupID: 529241
Follow Up By: Member - George (WA) - Tuesday, Oct 16, 2007 at 22:31
Derek can you also advise if this is suitable for 2 battery set up. Battery's connected together for 12v output. I can never what it is called, in series or inline
FollowupID: 529242
Reply By: Member - George (WA) - Tuesday, Oct 16, 2007 at 17:06
AnswerID: 266845
Reply By: Member - George (WA) - Tuesday, Oct 16, 2007 at 17:08
AnswerID: 266846
Follow Up By: Member - George (WA) - Tuesday, Oct 16, 2007 at 17:10
Ooops, pressed the button twice. Derek can you also advise if this is suitable for 2 battery set up. Battery's connected together for 12v output. I never know it that is in series or inline
FollowupID: 529172
