keeping cool
Submitted: Monday, Oct 15, 2007 at 19:12
ThreadID: 50587 Views:3097 Replies:6 FollowUps:18
Hoping some of you seasoned campers will help me here. Any tips on how to keep cool when camping up north. Our set up is camper trailer with two batteries and honda gennie. Would a fan make much of a difference? Just want to be able to travel further north and not just during the cooler months.
Reply By: Hairy (NT) - Monday, Oct 15, 2007 at 19:15
Gday,
At night time a fan is good if you use a squirty bottle with it.
Spray a mist of water in the air and the fan cools you down enough to get to sleep.
AnswerID: 266709
Follow Up By: Member - Doug T (Qld) - Tuesday, Oct 16, 2007 at 08:47
Do you have a little fairy travel with you, after he goes to sleep who's going to keep spraying bloody water,
FollowupID: 529029
Follow Up By: handy - Tuesday, Oct 16, 2007 at 17:08
hairy's got a dedicated missus that would spray him all night, lol
FollowupID: 529170
Reply By: Notso - Monday, Oct 15, 2007 at 19:19
Fans Good, at any temp but at 52 degrees there isn't much aside from an Aircon.
We spent 5 months around Fitzroy Crossing in the Wet season. Without the Aircon it would have been a nightmare.
AnswerID: 266711
Follow Up By: Member - AJB (VIC) - Monday, Oct 15, 2007 at 19:24
No air con at Fitzroy! Boy does that bring back some memories. Went insane, still am!
FollowupID: 528926
Follow Up By: Notso - Monday, Oct 15, 2007 at 20:16
Yep,
Woke up in a sweat many times at night and put on the Gumboots and walked 5 metres to the Generator Shed through the snakes. Quick kick in the ^&*( and the lizards would blow out of the exhaust pipe and away she'd go. Aircon again.
FollowupID: 528939
Follow Up By: Notso - Monday, Oct 15, 2007 at 20:17
Should have been 60 metres in me Jamas??
FollowupID: 528940
Follow Up By: Member - Doug T (Qld) - Tuesday, Oct 16, 2007 at 08:54
Notso
JAMA'S ........no wonder you get hot, wearing clothes to bed , what have you got to hide that all of others have'nt,
Ummmmm.............................
Doug
FollowupID: 529033
Follow Up By: Notso - Tuesday, Oct 16, 2007 at 09:12
Have to wear jamas otherwise have bad dreams
FollowupID: 529046
Follow Up By: Mr Fawlty - Tuesday, Oct 16, 2007 at 17:53
Ahhhhhhhhh Notso confucious say man who take problem in hand at bedtime wake up with solution in bed....
FollowupID: 529178
Reply By: Member - Olcoolone (S.A) - Monday, Oct 15, 2007 at 19:40
What you want to look at doing is making a tropical roof for you camper.
Basicly it is another canvas roof that fits over your original roof and has a 100 to 150mm gap between the two.
The air between the two act as insulation and is good in hot and cold areas.
Most canvas places could make it for you.
Regards Richard
AnswerID: 266717
Follow Up By: Robin Miller - Monday, Oct 15, 2007 at 20:09
Hi Richard
Two layered roof is a great way to go , almost makes you think your under a shady tree.
Works well in Vic over summer as well, and is probably the most cost effective thing one can do.
The apparent temp rise under the tarp next to us last summer was about + 10c and the almost got sunburnt under it as well.
Robin Miller
FollowupID: 528938
Follow Up By: oz doc - Monday, Oct 15, 2007 at 21:47
So Robin - are you saying that a tarp over the top would make things hotter than the tropical roof or am I having a blonde moment? Thanks for the input so far.
FollowupID: 528968
Follow Up By: Robin Miller - Tuesday, Oct 16, 2007 at 07:47
No , double layer keeps things cooler Oz Doc.
Even the best single tarp is still hotter than sitting under a shady tree , and you need the air gap Richard mentioned to achieve the best results.
I think basically the problem is not so much that it gets hot sometimes , but that we make it worse than it needs to be.
Robin Miller
FollowupID: 529010
Follow Up By: ExplorOz Team - Michelle - Tuesday, Oct 16, 2007 at 10:29
What's even better is a thermal tarp - ie. a silver one made with that thermal foam layer like your windscreen sunvisor thingys. I've seen these custom-made for camper trailers and have camped with friends that say it makes all the difference.
Michelle Martin
Marketing & Customer Support
FollowupID: 529067
Follow Up By: T-Ribby - Tuesday, Oct 16, 2007 at 11:43
we have a zip-on thermal roof on our CT but for serious shade we also have a b.big tarp which extends well over the lot including the awning. Need some extra poles and ropes. Also have a box fan which runs through convertor.
T.R.
FollowupID: 529083
Follow Up By: Moose - Tuesday, Oct 16, 2007 at 13:31
G'day Guys
One presumes that during the day the inside of the camper wouldn't be used much - unless it is for a midday siesta. Ignoring the midday siesta I fail to see what benefit a double roof over the body of the camper would have during summer.
I can appreciate that it would probably make the sleeping area warmer during the colder months by trapping a layer of warmer air up there.
I can also believe that having an extra tarp over the awning would make things cooler in that area.
But I don't see how it would help with making sleeping at night more comfortable. In fact I imagine it would make matters worse because of that extra trapped layer which I imagine would actually keep internal temperatures higher.
Am I missing something with respect to the double roof argument as a hot weather solution?
Cheers from the Moose.
FollowupID: 529111
Follow Up By: Robin Miller - Tuesday, Oct 16, 2007 at 14:38
Hi Moose
No don't think you are missing anything - we were just replying to the general question
about keeping cool, and as you suggest you don't want a trapped air situation.
Most of the damage I have seen is from people sitting under a tarp during the heat of the
day and wondering why they get red even with a 50 factor tarp.
By and large this is caused by re-radiation from the hot underside surface.
Two layers or in the case of a camper, a tarp over it making a second layer, generally happens such that there is quite a gap to ensure air doesn't get trapped in it at any time.
By tarp I'm referring to the silvered poly tarp as the effect is greater than with pure canvas and it is the separated two layers that allows circulation that does the trick.
As you imagine anything done to assist air flow works even better.
Just a comment on sleeping at night, here the same effect works also in that if you sleep on a strecher or lair bed or some system that allows circulating air underneath then its much cooler. than say a mattress on the ground/floor.
Robin Miller
FollowupID: 529127
Follow Up By: Member - Olcoolone (S.A) - Tuesday, Oct 16, 2007 at 21:05
A tropical roof is what use to be used before air conditioning was around, alot of containers, earth moving gear and buildings use to use it.
The air between the inner roof and the outer roof would act as a insulator and the hot air between the two would rise keeping the lower air cooler.
We stiil design and use tropical roofs in some applications to help in cooling.
Much the same as a house, the inside of the house maybe 20 deg. and in the roof 40 deg.
you have to have a gap of about 100mm plus to make it wok.
Just goooooogled it and found Kimberley Kamper offer it as an option.......heres the link:
http://www.kimberleykampers.com/energy/tropical_roof.php
Regards Richard
FollowupID: 529223
Reply By: Member - Uncle (NSW) - Monday, Oct 15, 2007 at 20:50
This is the setup we have used for a while and works great, keeps the inside about 8 to 10 deg cooler.cheers Unc
AnswerID: 266735
Reply By: Member - Doug T (Qld) - Tuesday, Oct 16, 2007 at 08:50
oz doc
As Hairy suggested a Fan , if you start to perspire a bit the fan will cool you, ...unless you have a water squirting fairy like hairy's to keep you cool all night.
Doug
AnswerID: 266780
Follow Up By: oz doc - Tuesday, Oct 16, 2007 at 09:32
Thanks guys. Going to give the fan and tropical roof a try up at 80 mile beach and see how we go. Think I'll give Hairy's fairy a miss though.
FollowupID: 529055
Reply By: Member - Doug T (Qld) - Tuesday, Oct 16, 2007 at 09:02
oz doc
I can remember my old man use to wet a hessian bag and let the breeze flow through it , it worked too, So if your tent has a fly screen you could rig up a 20lt plastic container of water on top of the car or in a tree, connect a very small plastic tube with a tap on it and allow water to drip onto the tent above the screen so the water runs down the screen , 15lt would last nearly allnight.
AnswerID: 266784
Follow Up By: Mr Fawlty - Tuesday, Oct 16, 2007 at 17:58
Sounds like you are describing the invention of the coolgardie safe....
Remember when we all had canvas waterbags hanging of our front bumper - absolutley essential on long trips from Sydney to Gosford - but they do work via the evaporative effect. Havent seen one for years, must look into it...
FollowupID: 529180
