Fuel economy - Troopie
Submitted: Tuesday, Oct 16, 2007 at 07:40
Steve
I own a 1996 Troopie which is extremely reliable. However, it is pretty heavy on diesel. I have been thinking of trading the Troopie for something more economical, but would rather keep it and try to improve fuel economy. Any ideas on how I can do this ?
Reply By: Member - Doug T (Qld) - Tuesday, Oct 16, 2007 at 08:44
Lift-Um-Right Foot, keep under 100kph
I used just under 360 lts /2000klm towing a 20ft Caravan .
Plus you must take into account the amount of dollars you will lose as a trade in, the extra $$$$ for another vehicle, you would be better of keeping it , you have a vehicle that has an engine that will last 700.000 plus, I would consider that alone as compensation for a slightly less fuel economy over something that will give a better fuel economy but will break down in the middle of the SD with 200,000 on the odometer.
KEEP IT ....AND STOP THE WHINGIN'
266777
Follow Up By: Steve - Tuesday, Oct 16, 2007 at 09:39
I'm convinced !
529057
Reply By: traveller2 - Tuesday, Oct 16, 2007 at 09:06
As Doug said, drop the speed to 95-105 max, don't cart stuff you don't need when commuting (if it is used for same), the standard narrower 235x16 or 7.50x 16 in a less aggressive pattern will give you better economy than wide muddies, (approx 2mpg in my experience).
Drive it like a light truck(which is what it is!) rather then like a car. Slow acceleration and gentle braking and accept the lower speed on the hills you can get down to 13l/100k if you try. The best economy I ever got was around this figure on outback dirt roads where speed is in the 75 - 85 k region.
266785
Reply By: JimDi - Tuesday, Oct 16, 2007 at 09:11
Steve,
I have an 80 series 1997 petrol. I tow a 20ft Kedron. My petrol consumption sometimes makes my eyes
water, particularly when climbing the ranges. But when talking to fellow drivers about fuel consumption I sometimes wonder about the fantastic performance reults they seem to get.
The mechanic tells me the car is in good nick. It is 1997 model and has just gone past the 200k mark. Shortly need to replace the radiator which is showing signs of age. By staying ahead of the maintenance and trying to anticipate future parts replacements we get by without a lot of heartache. Truth is the vehicle has never let us down in any way.
As a trade in, the reality is the vehicle has very little value and to my way of thinking why should I throw away a perfectly good vehicle. Replacement outlay for a similar new vehicle would set me back some $40k plus. I have not investigated or thought out this figure but I reckon I am not far out.
This is not an answer to your question but I go thru the same process myself from time to time and end up just leaving my wallet in my pocket.
Jim
266786
Follow Up By: Gerhardp1 - Tuesday, Oct 16, 2007 at 10:23
I'd love to know what the 80 series replacement is, that you can get for $40,000+.
Sadly, I think you need to revise that figure to $70,000 plus.
529066
Follow Up By: JimDi - Tuesday, Oct 16, 2007 at 16:38
Gerhardp1,
I have not looked at the possibility of upgrading for a few years so you are maybe right. When I said $40k plus I probably meant $40k pluuuussssss.
Anyway since you have convinced me of $70k plus my vehicle (touch wood) will last a few more years with careful driving and management. I can then sell both van and car and buy that little buzzbox for getting around Brissy.
Jim
529161
Follow Up By: JimDi - Tuesday, Oct 16, 2007 at 16:42
Gerhardp1,
Jim
529162
Reply By: Member - Shane D (QLD) - Tuesday, Oct 16, 2007 at 10:41
Steve,
What sort of economy are you getting?
I have a 105 with a 1HZ and has always got 13.5/15l per 100k, regardless on how its driven,up to 100kph!
Crossing the
Simpson desert it was loaded to 3.5 ton and used 110 liters for the 600k journey.
Best I have ever got was 970k's on 125 liters and did nothing special, perhaps fuel quality play's a big part
Shane
266803
Reply By: Rock Ape - Tuesday, Oct 16, 2007 at 10:50
Doug's right hit your right foot with a hammer so when you push on the go pedal it hurts,
These are figures from a trip I did this year which inclued a lot of dirt and some scrub, steep and rocky.
Troopcarrier with 6.5l V8 diesel loaded with 2 people running 285 75 16s @ 35PSI on bitumin and 28PSI on long dirt runs.
837k 12.9l/h
621k 12.7l/h
792k 12.75l/h
451k 13.65l/h
684k 13.8l/h
594k 13.6l/h
These are deadset correct figures no polly has got a hold of them
Do it easy the Ape.
266805
Follow Up By: Andrew from Vivid Adventures - Tuesday, Oct 16, 2007 at 11:02
impressive - I have a couple of mates with Chev8 troopies and they aren't doing as
well as you.
My 1HZ is 14l/100 when driven unladen like a grandpa (I don't think I am a grandpa, but I have mastered that skill sans hat) up to about 20l/100 when laden with 5 people plus gear trailer through
the desert.
I can usually predict, based on load and foot heaviness what it will be.
From my assessment there is much to be done to a 1HZ except exhaust mods that makes any certain improvement in economy.
529074
Follow Up By: Rock Ape - Tuesday, Oct 16, 2007 at 13:01
Andrew,
I keep revs between 2200 and 2300 max with a light foot which means I am sitting between 90 and 94k/hr, this seems to do the trick, I just have to be mindfull of other road users and make sure I don't hold them up.
Good idea of fuel consumption if I drive to Mt Isa and back giving a 100series some stick 600k and I run out of fuel in both tanks.
Underground 79series ute about 190k and out of fuel (fuel gauges are always u/s
Have a good one
529103
Reply By: The Rambler( W.A.) - Tuesday, Oct 16, 2007 at 12:48
Steve,
As others have said, keep the speed below 100km./hr and you will find a big difference.Ihave had a few Troopys over the years and wouldn't change them for anything.The savings on low cost maintenence and reliability more than compensates for a little extra fuel.Iget an average 7.5 km/l without towing and average 6.4km/l towing the loaded camper trailer(1.1t)
266811
Reply By: Member - Dick (S.E. Asia) - Tuesday, Oct 16, 2007 at 15:16
You have one of the most reliable vehicles ever built, why change it? The bit of extra diesel you use is far outweighed by the trouble free use you will get out of the Troopie.
Dick
in Phuket
266831
Reply By: Member - Keith B (QLD) - Tuesday, Oct 16, 2007 at 15:16
I have just returned from a trip around NSW, fully laden including a roof rack in my 2005 79 Troopy and consistently got 700km plus from each
tank. I kept the speed low and avoided rapid acceleration, as other writers are suggesting. I was VERY happy with these figures. I know that if I get heavy footed then these figures evaporate!!
266832
Follow Up By: Member - Dick (S.E. Asia) - Tuesday, Oct 16, 2007 at 19:46
Hi Keith, Curious about your Troopy. Is is a normally aspirated 1hz engine. Have you changed the exhaust or are you still running a standard exhaust.
Dick
in Phuket
529203
Follow Up By: Member - Keith B (QLD) - Wednesday, Oct 17, 2007 at 15:52
Dick,
It is the turbo version and engine is stock. I calculated "accurately" (by recording kms travelled after filling brim full then filling brim full again after the trip) that on one section of typical outback road I obtained 715 km with 86 L diesel. That's 12.0 L/100km. Other sections the Troopie returned 13.5 L/100km !!
Keith
529349
Reply By: redfive - Tuesday, Oct 16, 2007 at 16:54
Hi Steve
I too think about the fuel my wonderful Troopy uses at time but when you weight up the fact that you have "THE BEST" outback tourer on the market some people will tell you different
and you cant kill them with a axe and its just a bloody strong tuff truck
and the fact that it will get you there and back without breaking down and like the other guys say you cant get 500,000 plus kms out of them
the big thing is how much weight you are dragging around it understandable its going to use fuel i get about 14.5 to 16.5 lts per 100 depending on what im doing on the same desert crossing with Shane i used 106lts to do 600kms and trust me we had them loaded to the roof i thinks that pretty bloody good
i did the exhaust 2.5 inch with headers K&N air filter which did help abit and i too drive about 90kph to 95kph never go over 100kph
but the weight is the big factor get the weight off and it will go better with all the stuff i have bullbar,dual batt,roof rack ,wheel carrier,draws,sidesteps,winch,cargo barrier, 40lts
water tank and with full tanks 180lts thats a lot of weight some 2900kgs plus fully loaded
you can see where im going with this my advice is for what its worth keep it you can buy a lot of fuel for what you would lose trading it in
Glenn....
266842
Follow Up By: Member - Shane D (QLD) - Tuesday, Oct 16, 2007 at 19:52
How ya goin' Glenn,
Did you get the DVD I sent?
Does it work?
Let me know and I'll do another one, PROPERLY
Shane
P.S sorry I used your thread Steve
529204
Follow Up By: redfive - Tuesday, Oct 16, 2007 at 23:03
Hi Shane
Yes i did get the DVD and yes it worked fine
hope all is
well with you and yours
Glenn
529247
