How do you feel about regional forecasting?
Submitted: Wednesday, Oct 17, 2007 at 00:41
ThreadID: 50621 Views:2919 Replies:7 FollowUps:14
Considering that there is over 500,000 Caravans, Campers out there, sometimes relying on weather forecasts to determine "tomorrows conditions" to enable planning of the trip ahead, I don't recon enough coverage is given over regional stations to cover the information required by travellers.
Wouldn't it be great if Wind direction/strength & temperatures could be aired each hour of each section of the country to keep all of us travellers abreast with travel conditions.
Just a thought, when you consider a strong head wind can increase your fuel consumption by 30%.
What's your thoughts?.
Reply By: Member - Jeff H (QLD) - Wednesday, Oct 17, 2007 at 01:33
Hmm.
AnswerID: 266936
Follow Up By: furph - Wednesday, Oct 17, 2007 at 06:39
At home I use "Weatherzone" and the BOM site for met. conditions both local and Au. wide.
One would think with the ease that gps, sat.nav, in car systems work, a similar meterological based device should be equally feasible.
Perhaps something already exists?
furph
FollowupID: 529262
Follow Up By: Bware (Tweed Valley) - Wednesday, Oct 17, 2007 at 06:53
If you have access to the internet you have access to regional weather.
Regional ABC Radio gives regional weather reports.
FollowupID: 529264
Follow Up By: Member - Doug T (Qld) - Wednesday, Oct 17, 2007 at 09:26
Jeff
Sorry ....I can't control the little bugger, he got to the keyboard again
FollowupID: 529290
Reply By: Mike Harding - Wednesday, Oct 17, 2007 at 07:00
I'm currently building an antenna which will allow me to receive images of weather systems on my notebook computer from the NOAA satellites on ~137MHz, my rationale is the localised weather we get in the Vic High Country - weather forecasts are often useless up there.
Many airports broadcast up tp the minute weather on long wave at around 350KHz and VOLMET broadcasts in Oz on the hour and half hour on 2.9650, 6.6760, 11.3870MHz USB - you'll need a quality short wave receiver capable of side band reception for this - Sony at about $200+ is good.
Mike Harding
mike_harding@fastmail.fm
AnswerID: 266938
Follow Up By: Andrew from Vivid Adventures - Wednesday, Oct 17, 2007 at 07:52
Just for clarity for the non-technical types a HF radio will receive VOLMET broadcasts if you have the channel set up.
FollowupID: 529270
Follow Up By: traveller2 - Wednesday, Oct 17, 2007 at 08:23
I used to get a channel on the HF that when it was hooked to a laptop printed out a sat picture of the weather map, don't know if it is still available though, was about ten years back ;-))
FollowupID: 529274
Follow Up By: Steve - Wednesday, Oct 17, 2007 at 08:30
you had a laptop 10 years back?
Jeez mate, what are you running now?
FollowupID: 529275
Follow Up By: Andrew from Vivid Adventures - Wednesday, Oct 17, 2007 at 08:34
There is a Weatherfax service - you need a PC connection on your HF I think... of a fax machine... it is still there.
FollowupID: 529276
Follow Up By: Mike Harding - Wednesday, Oct 17, 2007 at 09:06
For HF radio weather fax the following two links will be of use:
The BOM page giving frequencies, times etc
Software which uses a PC to decode the fax
Mike Harding
FollowupID: 529285
Follow Up By: traveller2 - Wednesday, Oct 17, 2007 at 10:38
I gave up using a laptop for mobile use/mapping a few years back now as they eventually break due to dust/vibration and general use. I always used Toshiba's as the others didn't last as long.
These days use an Ipaq, no moving parts and very reliable despite very rough and dusty conditions.
FollowupID: 529306
Reply By: Member - Oldplodder (QLD) - Wednesday, Oct 17, 2007 at 08:26
I like travelling for the new and unexpected things and sights that occur each day. Fair enough, flat tyres and other incidents are not fun, neither are cylcones, but a bit of wet weather is a chance to stay in bed and read for a while. :o) So if I can get the major weather forecasts that's all I need, which I can get from the ABC. A holiday is the number of times I don't have to turn on the laptop.
If I get a head wind, I just slow down a little and take an extra 30 minutes to get there.
AnswerID: 266944
Reply By: Member - Doug T (Qld) - Wednesday, Oct 17, 2007 at 09:22
Make that a DOUBLE Hmmmmm Hmmmmmm
and add a bit of C'mon ,
Easy to tell how hot it is , wind the bloody window down and stickum arm out, If the sky is blue then it must be a good day ,
AnswerID: 266950
Follow Up By: Kinggeorge - Wednesday, Oct 17, 2007 at 11:46
Thanks all that answered, I WAS hoping that someone would agree with me and say "YES", "We should have more radio regional coverage on weather forecasts", but it didn't happen.
I guess most of the odd 200 that read my comments are satisfied with the present forecasts.
I thought an extra 3 minutes of air time each hour on the ABC regional would be a benefit to those who do not have CB's & Laptops for access to quick forecasting, but I was WRONG.
FollowupID: 529317
Reply By: Member - Doug T (Qld) - Wednesday, Oct 17, 2007 at 11:52
King Georgie Boy
We all know where your coming from mate but I can sit here in my Caravan at 97% of the towns and get a weather report for any area/Town in Australia right here at ExplorOz Weather
. Doug
AnswerID: 266966
Reply By: Motherhen - Wednesday, Oct 17, 2007 at 12:40
I do agree Kinggeorge
When i am home, i have access to umpteen dozen weather reports on the Internet. I do not use Internet when travelling, so trying to find out what is in store for us is either the old "red sky at night" touch or watching the ants I sit in the car scanning the radio in the hope of picking up a weather report, which, even on ABC regional radio, tells us nothing about the area we are in.
On our recent trip around the Kalgoorlie goldfields, we were camping out, so really did want to know how much rain those clouds looming were likely to bring, and how long it would last. Regional ABC gave us nothing for the inland regions.
AnswerID: 266972
Reply By: Member - Shane D (QLD) - Wednesday, Oct 17, 2007 at 15:06
What if you lived where the ABC radio station was all you could get.
Constant repetitive weather forecast getting shoved down your throat for a few people who are passing thru, NO THANKS, Previous reply's have shown that there are a number of ways to find out what the weather is doing if it soooo, interests you, that doesn't impact on those are really aren't worried.
Shane
AnswerID: 266996
Follow Up By: Kinggeorge - Wednesday, Oct 17, 2007 at 18:18
You make a good point Shane D, but being "shoved down your throat" at 3 minutes in every hour wouldn't be a BIG hassle would it?. The "Few people passing through", dependant on where it is of coarse, may be thousands. But as you say if I WANT TO GAIN THIS INFO, SET MYSELF UP FOR IT. Well just thinking of the rest out there, that's what it's all about, I reckon.
FollowupID: 529393
Follow Up By: Mike Harding - Wednesday, Oct 17, 2007 at 20:16
Sounds to me like you're a grumpy old bugger just thinking of himself.
Mike Harding
FollowupID: 529419
Follow Up By: Member - Shane D (QLD) - Thursday, Oct 18, 2007 at 18:36
That was my point, while it's great that you are thinking about others (travellers) who feel the need for in depth weather forecasts, would only need them for the duration for their trip thru a particular area, wouldn't that be fair to say?
What about the people who don't get much choice what to listen to in regards to radio only to have what they do get be influenced by people who are just travelling thru, I'm NOT thinking for myself, I'm just saying that if a particular field of interest appeals to a minority, why should it be put onto the majority
Shane,
PS Mike, Who where you calling old?
FollowupID: 529625
Follow Up By: Mike Harding - Thursday, Oct 18, 2007 at 18:54
The original poster who posts as "KingGeorge" - although the emphasis was really on the "grumpy" :)
Mike Harding
FollowupID: 529627
