'Plasma' Winch Rope
Submitted: Wednesday, Oct 17, 2007 at 12:49
ThreadID: 50630 Views:3434 Replies:3 FollowUps:2
G'day all,
Just to let those of you that are interested in synthetic winch rope know, Mitchell Bros, in Brookvale, have imported a quantity of synthetic winch rope. The brand they imported is Master Pull and going by the US website it is one of the strongest on the market.
I purchased the 3/8" Super-line XD which is rated for about 26,000lbs - and comes fully sheathed to protect the rope.
No affiliation etc - just a happy customer who thought he'd help out 'small business'.
Sites for Master pull - www.masterpull.com
and Mitchell Bros - www.mitchellbros.com.au
Tim
Reply By: Truckster (Vic) - Wednesday, Oct 17, 2007 at 14:04
What price?
I cant see it being anywhere as cheap as imported from USA yourself
AnswerID: 266982
Follow Up By: Member - Tim - Stratford (VIC) - Wednesday, Oct 17, 2007 at 14:11
Truckster,
As mentioned I went the 3/8 XD - which is rated the highest. Worked out less than $600 with hause (?) fairlead, rated hook and rock guard.
At the time of ordering the $Aus wasn't as strong as it is now. If Mitchell Bros are importing more the price will probably reflect the stronger $AUD.
Probably could have got it for about the same price importing it myself - but for the same price why not support a small Australian business.
Not sure what they are going to sell it for, you may have to drop them an email.
Tim
FollowupID: 529338
Reply By: Peter McG (Member, Melbourne) - Wednesday, Oct 17, 2007 at 16:23
Another reliable supplier in the US is OKoffroad.com
I bought my rope from them when recently in the US. Their price for 100ft of 3/8 rope is US$203 and so when you add freight costs it works out a good deal. They also supply the same hooks and fairleads.
AnswerID: 267013
Reply By: nuboy - Thursday, Oct 18, 2007 at 00:57
Hi Tim,
Could you please explain a little about this synthetic winch rope to me.
I have a winch on my cruiser that I haven't had to use in earnest as yet. I ran it out when I first brought the veichle to check the winch operation and cable condition. I found the cable had a strand here and there that was broken (bad news on the fingers) and the cable was very hard to get back onto the drum neatly. Ever since then when ever I have read about synthetic winch rope I have thought it would be so much easier to handle. Is it just a matter of taking the steel cable off and replacing it with the synthetic and what do you mean when you talk about :
(fully sheathed to protect the rope, hooks and fairleads)
Regards Terry
AnswerID: 267109
Follow Up By: Member - Tim - Stratford (VIC) - Thursday, Oct 18, 2007 at 10:13
Terry,
A strand here or there on your cable isn't too much of a drama. It won't greatly reduce the strength of your cable (I'm talking of the small single wires sticking out of your winch cable).
I would be much more concerned about flat spots and kinks in the cable reducing strength by a larger margin. If you are concerned it is best to replace the cable, with wire or synthetic, or get it checked by a 4WD shop you trust, or a testing authority.
As for getting the wire back on the drum neatly. When I did my work 4WD training we were shown a great way to get the wire back on neatly.
Find a gentle slope with an anchor point that allows you to run out the full length of cable. Keeping six wraps of cable on you drum attach the cable to your anchor (tree). Winching safely, tree-trunk protector, rated equipment and dampner etc, begin winching.
The idea is to keep the wire coming in at ten degrees off centre. It is a little hard to explain but, if your wire is winding on from the drivers' side to the passenger side you would keep a ten degree angle on the wire off centre to the right. When the wire gets across the drum and starts to come back you turn the wheels to move the wire ten degrees to the other side.
In effect the angle of the wire coming onto the drum pulls against the previous wrap tightening it up. You end up with a factory looking winch cable - neat - but tight on the drum. Winching with only 20' of cable out will not damage the lower layers due to the tightness of cable on the drum.
The synthetic rope can been put on 'less neatly' to make it easier to free spool out. The rope is hollow and won't crush like cable. It is heaps easier to handle - like ski-rope - and is terriffic in the snow. It is as easy as unspooling your cable and removing and replacing with rope and then re-spooling under load. Most manufacturers recommend a hause fairlead, not roller fairlead.
Some synthetic rope have a UV block on them to stop them breaking down in sunlight. Some of this is water soluble so I went for a sheathed version. The sheath also prevents dust, grit and dirt getting into the rope which is bad - if left it will abraid the rope from the inside out. The upside is if dirty the rope can and should be washed.
Hope this helps.
Tim
FollowupID: 529541
