porridge
Submitted: Wednesday, Oct 17, 2007 at 21:09
Member - Phillip S (WA)
I have a 59 litre aluminium
water tank fitted to the rear of my troopy...anyway I removed the hose so as to fit a small 12v pump and the last of the
water started to run out so I left it to do something else and when I came back it had emptied and on the driveway was this milky residue that looked like porridge....does anyone know what it is.....cheers Phil
Reply By: Member - John - Wednesday, Oct 17, 2007 at 21:22
Phillip, think you will find it is common in aluminium
water tanks, some think it is harmful, others think it is not......
267081
Follow Up By: Member - Phillip S (WA) - Wednesday, Oct 17, 2007 at 23:35
I stopped drinking the
water some time ago....just use it for washing up and washing hands etc...I use them green "healthy, food quality" jerries for my
drinking water now....but I was not prepared for this, the
tank has been there since 99 and so it's holding o.k. but the stupid tap was right underneath, anyway I swapped today for one of those "whale" 12volt inline pumps, now I don't have to reach underneath to wash my hands....swing and extend the laundry arm outlet, pull the switch and wash the hands....I had to put a small "retic" tap to regulate the flow as the pump works really good. So I guess as long as I keep the
tank full....should be no more "porridge"
529474
Reply By: Chris VK2UW - Wednesday, Oct 17, 2007 at 21:23
It sounds like Calcium to me, we use to get in the hot
water tank in the caravan and it would eat the
tank out in about 12 to 18mths.
267082
Reply By: Shaker - Wednesday, Oct 17, 2007 at 23:01
It is probably just sediment, have you ever looked into the
water tank of a Cafe Bar?
267100
Reply By: traveller2 - Thursday, Oct 18, 2007 at 12:24
"Hard" or
bore water will quite often 'eat' the aluminium away causing the white powder/sludge, we used to get it a lot with aluminium billies.
Since changing over to stainless billies it has reduced heaps but still occurs but only because of the minerals in the
water building up not corrosion of the billies as with the ally ones.
267168
Follow Up By: Member - Phillip S (WA) - Thursday, Oct 18, 2007 at 14:49
Might have to replace with a stainless steel
tank in the future...there are certain grades of SS too arn't there?...I'd better find out and not get stung!!!
529578
Follow Up By: Shaker - Thursday, Oct 18, 2007 at 16:21
Marine grade is 316.
529587
Follow Up By: Member - Phillip S (WA) - Thursday, Oct 18, 2007 at 18:18
Thanks Shaker
529620
