80Watt Solar Panel-40ltre Engel Fridge
Submitted: Friday, Oct 19, 2007 at 17:23
ThreadID: 50699 Views:25444 Replies:8 FollowUps:5
Hi just wondering if a 80watt solar panel would be good enough to keep a 105amphour battery top enough for camping using a 40litre Engel fridge.
I run the fridge on 1 most of the time and id say i would try to keep panel in full sunlight during day time hours as good as i could.
I new to solar panels so not sure.
Reply By: Turist (The Original One) - Friday, Oct 19, 2007 at 17:44
Works for me, just so long as the sun is shining.
AnswerID: 267395
Reply By: Motherhen - Friday, Oct 19, 2007 at 18:01
Our 80 panel mounted on a stand was sufficient to keep the battery charged when put it out when we stopped each afternoon and left to face east ready for morning. We also had trickle charge from the vehicle, but that did very little compared to the solar panel; even in semi shade late afternoon. It ran an upright Engel caravan fridge (around 130 ltrs) and a couple of fluro lights.
We recently put the solar panel on the canopy roof of the F250. We were away for two weeks, mostly fine but it did rain one night. It ran the 40 litre Engel and the fluro lights. The battery was reading full charge most of the time.
More than adequate.
AnswerID: 267397
Reply By: Sand Man (SA) - Friday, Oct 19, 2007 at 18:10
Should have very little problem.
I get by with a 40 watt panel for my 40 litre, also on about 1, but longest time so far is three days stationary. That includes a couple of 12 volt lights as well.
I have the option of running on the 80 A/h auxiliary battery for 3 days and then the 75+ A/h "Thumper" for another three or so.
Haven't needed to increase the solar wattage yet.
Bill
AnswerID: 267398
Reply By: Member - Debbie R (SA) - Friday, Oct 19, 2007 at 19:34
You will definately have enough power for as long as you like, as long as the sun shines. There is no better way, do us all a favour dont be tempted to use a generator.
Debbie and Barry
AnswerID: 267410
Reply By: Mainey (WA) - Saturday, Oct 20, 2007 at 00:15
What brand of solar panel ??
as the number you really need to know is the 'average' watts and in what ambient temperature and also what Amps does it produce on an average day ?
Are you going to use a solar regulator (why not ?)
AnswerID: 267460
Reply By: ozwasp - Saturday, Oct 20, 2007 at 00:21
Correct if I'm wrong people, but why wouldn't you just buy a 3 way chescold?
At least that way it's working rain, hail or shine.
I've got both and use the engel more often, as I'm never in the one place for too long.
Will
AnswerID: 267461
Follow Up By: Member - GeeTee (NT) - Saturday, Oct 20, 2007 at 08:29
Hi Will,
I had a Chescold but got rid of it ... hopeless on 12 volts ! Great on gas and OK on 240 Volts. Engel with a 100Ah battery on solar through a regulator works for me.
FollowupID: 529887
Follow Up By: Axel [ the real one ] - Saturday, Oct 20, 2007 at 08:36
Havent you answered your own question , ' Ive got both and use the Engle more often as Im never in the one place for too long ' ,
a 3way can and is great IF your at a static camp , pretty damn inconvenient though if on the move every day or 3 setting back up the unit to dead level for gas ,too much constant amp draw on 12v , and most forget that once you have the correct solar setup there are no ongoing expenses , no gas to buy , no fuel to buy/carry for the generator.
FollowupID: 529888
Follow Up By: ozwasp - Saturday, Oct 20, 2007 at 10:50
Hi Axle
I don't want to get into a debate on fridges, but how much does it cost to get a solar setup for a fridge (so it can run all day and night) and what's the lifespan of a solar panel?
I'm guessing its over $1000 and about 5-10yrs tops.
I got my Chescold before the Engel and find the Chescold is only good for gas and 240V, while the Engel is great when I'm on the move. So it really depends on what type of travelling I'm doing.
3 way fridges aren't perfect, but so aren't solar panels - thats why I've got the 2 fridges
Will.
FollowupID: 529898
Follow Up By: Axel [ the real one ] - Saturday, Oct 20, 2007 at 16:48
No debate , solar panels have a life span of 25+ years and to set up a system to run something like a 40lt Engle would top out at $1000 -$1200 ,,
FollowupID: 529930
Reply By: natureisone - Saturday, Oct 20, 2007 at 08:38
Yeh sorry new to this its a Suntech freedom 80Watt solar panel kit with a regulator,they say it should do the trick nicely.
Its produces about 5amps per hour so i think enough for what i use i guess.
AnswerID: 267483
Follow Up By: Mainey (WA) - Saturday, Oct 20, 2007 at 13:07
Yes, your very new to Solar :-((
As I said, the important numbers are the "average" on a hot day,
not the maximum number attainable on a 'best conditions' day
or put another way
the total number of Amps delivered to a battery in a (full) day, as different brands of 80W panels will give very different Amp numbers in exactly the same identical conditions, and they are all the exact same number of Watts, over the duration of a (full) day.
Suntech are the 'cheapest' panels available, and don't deliver the same "total" output as higher technology (expensive) panels over a full day.
Yes, they do & will work, but just not as effective as the high tech panels.
As for solar regulators, if you get a basic on/off regulator your just wasting money, well only a small amount of money 'cause they are cheap too, get a 3 x stage reg that will fully charge a battery 100% and with PWM.
Anyway, they say to me "Mainey, if you can't say sumthing nice - then say nuffin"
FollowupID: 529912
Reply By: spinifex - Saturday, Oct 20, 2007 at 22:24
You shouldnt have any problems with that set up. I have 120 watts mounted flat on roof which puts out about 5 amps and can camp indefinately running a waeco plus lights.
spinifex
AnswerID: 267596
