cleaning trailer wheel bearings for re packing
Submitted: Saturday, Oct 20, 2007 at 20:31
Anthony (Vic)
I read on the internet somewhere that you shouldn't use petrol to clean wheel bearings, but use only kero or turps. I cannot see why petrol is a no go?
Tomorrow, I'm repacking the trailer bearing ready for an up coming trip and am thinking petol should be fine ... but ... in the back of my mind, I just need to know if this article I read has anything to it with not using petrol.
Any thought from
the pool of knowledge welcome ...
cheers Anthony
Reply By: Member - Wayne B (QLD) - Saturday, Oct 20, 2007 at 20:36
no idea but i have always used KERO seems to be more effective to get the grease out, as for petrol no idea
267575
Follow Up By: Anthony (Vic) - Saturday, Oct 20, 2007 at 21:18
If the kero makes it a bit easier to clean off the old grease then that worth a go - cheers Anthony
529963
Reply By: Max - Sydney - Saturday, Oct 20, 2007 at 20:48
Anthony - I read that somewhere and thought "Yep that's right" but cannot for the life of me remember why now. Bet the world (or your bearings) would not come to an end if you use petrol, but turps is a lot less stinky to use.
Just remember not to make the bearings too tight - always have a little bit of movement in them!
Have fun!
Max
267578
Follow Up By: Anthony (Vic) - Saturday, Oct 20, 2007 at 21:25
I'm not feel so silly for asking the question now. I was thinking I might just be the last to pick up on not to use petrol.
I thought the issue with petrol is that it may have left a residue or something ? I might try the kero or turps ... just in case. Thanks for the reminder on not over tighting the castle nut - cheers A
529965
Reply By: spinifex - Saturday, Oct 20, 2007 at 22:12
Petrol will do a wonderful job cleaning the grease from your old bearing but due to its flammability there are safer options.
Spinifex
267593
Follow Up By: Member - Phillip S (WA) - Saturday, Oct 20, 2007 at 23:19
I agree....it's the safety issue....burns can be horrible
529984
Reply By: Member - greg S (QLD) - Saturday, Oct 20, 2007 at 22:45
Anthony,
I have used petrol on nearly every wheel bearing clean that I have performed over the last 20 years (since the start of my apprenticeship
back in 1987) and have never had any problems. Just make sure you use an air gun to blow dry the bearing/s. But don't try to spin the bearing with compressed air as this can cause damage to the bearing and yourself, as it can fly apart.
BUT...when using petrol or any other chemical or using a compressed air use/wear the appropriate safety gear.
267599
Reply By: Mogul - Saturday, Oct 20, 2007 at 23:57
I've always used metho.
267606
Reply By: alfclp - Sunday, Oct 21, 2007 at 01:10
You may want to consult the MSDS for petrol. Modern petrol has stuff like benzine and assorted aromatic hydrocarbons to reach the required octane ratings. these can be absorbed through the skin.
Kero, being less volatile and having less if any additives would be safer option. It also leaves a thin oily film on the bearings.
267609
Reply By: Member - extfilm (NSW) - Sunday, Oct 21, 2007 at 01:45
I remember back in the day I would be washing out a bearing with $2 worth of fuel. was about 5litres then(maybe more). Whilst I was washing them out I would have the bearing in one hand and a paint brush and cig in the other.
Now days I would still use unleaded but there is definatly a film that appears????? either stick with it or as I do, my hot
water cooker uses metho so I will use metho after cleaning my bearings and use the metho to make my coffees on my next adventures.........
Having said all this. If you plan to have the machine sitting around then it really does not mater because the film no matter what it is will dissapear when the truck is doing 110kms an hr..
I would not use kero or turps unless I was going to burn the excess film off.
Mate the trailor bearings if I remember rightly will be either ford falcon front (1086) bearings or holden front (Cannot remember the part number).
Just use petrol...
I have used it for 20 years but I must warn you "Do not try this at home"
267610
Reply By: Peter 2 - Sunday, Oct 21, 2007 at 07:16
As long as the bearings haven't been contaminated with dirt or
water I just use a bearing packer to push the old grease out as it pushes new grease in, never had a bearing fail since using this method and the correct grease.
The bearing packers are worth less than $15, a cheap cartridge grease gun which is kept specifically for wheel bearings and only use Castrol APX grease (or similar from other brands).
NEVER use HTB in trailer bearings or most 4wd's, the bearings do not get hot enough to melt the HTB and the only ever get what they are originally packed with and wear rapidly.
267616
Reply By: Mr Fawlty - Sunday, Oct 21, 2007 at 09:41
Not everyones cup of tea but I found an Ultrasonic Cleaner at my local "recycling centre' & bought it for $10!!!! its a ripper!!! before that I used to put some solvent degreaser in a spray gun, set it to a straight fine pattern and out doors hold the bearing in fingers and blow/clean the old grease out with the degreaser filled spray gun....You just have to have somewhere you can do it where the old grease & degreaser can settle without killing to many weeds....I would not reccomend the use of
water soluable degreaser with bearings under any circumstances. The solvent degreaser you can by from the elcheapo
places, "Export Quality" is the brand, works very
well like this sprayed directly from the can.
Cleaning the bearings before repacking has only to be done approximatley, they do not need to be surgically clean and as I'm sure some of our practical thinkers will say simlpy force out the old grease by packing the bearings from one side with new grease, this is the way "proffessionals" do it. I'm actually thinking of changing over to the "oil lube system" it makes changing the lubricant so simple.
The other question is how often does one do this, I do the Gin Palace every 12 months because it says so in the instructions and the grease I take out seems new, certainly not dry, cracked and oxidised but I guess this is good insurance as a dry hub away from home could cause disaster as
well as a through "Why didn't you get Lube Mobile to do it" from SWMBO.....
267630
Reply By: PhilZD30Patrol - Sunday, Oct 21, 2007 at 10:41
When I was apprenticed as an electrical fitter mechanic in the 1960s I was told by the tech teacher that petrol is corrosive and should never be used as machinery cleaner / solvent. Petrol engines wear out much more quickly than diesel because of the corrosive nature of the fuel.
We used a high quality and expensive solvent that was later banned because it caused cancer in the liver and depleted the ozone layer.
We used kero or turps only if we didn't have a special bearing solvent. We were banned from blowing bearings dry with compressed air.
267632
Follow Up By: roblin - Tuesday, Oct 23, 2007 at 20:05
Phil,
that high quality cleaner wasn't Turco was it? We would just about bath in this stuff when cleaning electric motors and bearings. Another quality cleaner banned for health reasons.
Regarding petrol, there are two aspects why it shouldn't be used. In the old 'Super' days the lead content would be absorbed by the body and affect the liver or kidneys (lead poisoning). The second is that petrol contains octane. Octane is absorbed throught eh skin and it is cumulative in the body (like lead and mercury). Again it can cause internal damage. I don't believe either kero or turps contain octane. By the way, when I was younger and more stupid, I always used petrol for cleaning. It was readily available and cheap. These days, however, I use kero.
Rob
530457
Follow Up By: PhilZD30Patrol - Tuesday, Oct 23, 2007 at 20:44
Hi Rob
The name Turco rings a bell, it could be what we used.
As far as I know I haven't got cancer despite the way we used solvents and other chemicals in our ignorance. But, back then, smoking was harmless and we were all invincible anyway so we didn't have to worry! We were told that science would solve all the worlds problems by 2005.
530480
Reply By: Anthony (Vic) - Monday, Oct 22, 2007 at 14:45
Hi all and thank you for your comments.
I ended up using kero to clean the bearing. It was interesting to hear everyone view. cheers Anthony
267808
