light steering
Submitted: Monday, Oct 22, 2007 at 17:33
usguys07
I have had my GU lifted by coils and springs 2in and the steering is as light as anything with very little feel. How do I get some weight and feel back into it.
Tim
Reply By: Member - Matt (Perth-WA) - Monday, Oct 22, 2007 at 17:59
If you have raised your vehicle then the caster will be effected by reducing the amount of positive caster from the factory.
When you turn the steering wheel, the front
wheels respond by turning on a pivot attached to the
suspension system. Caster is the angle of this steering pivot, measured in degrees, when viewed from the side of the vehicle. If the top of the pivot is leaning toward the rear of the car, then the caster is positive, if it is leaning toward the front, it is negative. If the caster is out of adjustment, it can cause problems in straight line tracking. If the caster is different from side to side, the vehicle will pull to the side with the less positive caster. If the caster is equal but too negative, the steering will be light and the vehicle will wander and be difficult to keep in a straight line. If the caster is equal but too positive, the steering will be heavy and the steering wheel may kick when you hit a bump.
To fix you need to fit caster correction plates to the front axle mounting brackets or use offset bushes. Both will require the attention of a wheel alignment specialist.
All the best
Matt.
267831
Follow Up By: usguys07 - Tuesday, Oct 23, 2007 at 07:16
Thanks Matt for the info. I will look into it.
Tim
530310
Reply By: Member - Shane D (QLD) - Monday, Oct 22, 2007 at 21:23
How long ago did you do the job?
If its just recent, I would give it some time to "settle", I changed
the springs on my cruiser some time back and made my vehicle almost undrivable, I asked around about castor correction, but the best advise I got was from a place who had nothing to do with original purchase, and was wait and give it 2-3000 ks, best of all go find some tracks that will make springs work, deep wash outs that criss-cross and put vehicle weight on two corners.
Just give it some time before you spent $$$$ on something you may not need.
Shane
267877
Follow Up By: usguys07 - Tuesday, Oct 23, 2007 at 07:15
Thanks Shane. The lift was done a year or so ago and has done some good time in the bush.
530309
Reply By: StormyKnight - Tuesday, Oct 23, 2007 at 20:05
Yep a wheel alignment would be the answer...
When you lift a car with independant
suspension the camber is also effected. The camber is the angle that the wheel sits in relation to the road & is roughly 90 degrees to it. As the
suspension is moved up & down this angle changes. Normally the camber is set with the normal weight in the car & thus at the normal
suspension height. When you lift the car the top of the tyre actually moves in fractionally. Thus putting less rubber on the road & thus less feel.
Have you noticed any unever wear?
Now caster if that is adjusted as I did on my Prado, will effectively move the tyre more to the front or more to the back of the car. I adjusted
mine so that my bigger tyres would fit without rubbing.
When you turn the steering wheel, you are effectively lifting the car up - thats why the steering wheel tends to return to centre when let go (it should anyway!)
As you increase the caster it increases this effect - as you decrease it decreases the wheel centering effect.
Sounds like you need more caster, but I would also get the camber checked as
Richard
268023
Follow Up By: usguys07 - Wednesday, Oct 24, 2007 at 17:20
Thanks Richard much appreciated.
Tim
530652
