Hypothetical electrical question
Submitted: Tuesday, Oct 23, 2007 at 18:09
Willem
Say fer instance there is an ignition problem on a vehicle and most of the ignition system has to be removed.
Is there an easy way to set up a switching system instead of a key system?
Reply By: Rock Crawler - Tuesday, Oct 23, 2007 at 18:16
yes but , very easy , 2 switches and a relay would do it , BUT , if the local boys in blue see it , you will be charged . Same charge as leaving your keys in the ignition. And no insurance either
267990
Follow Up By: Willem - Tuesday, Oct 23, 2007 at 18:40
Yerr, not really worried about the boys in blue and have no insurance anyway.
Please email the details of what goes where to me when you get a chance. Thanks.
530440
Follow Up By: Richard Kovac - Tuesday, Oct 23, 2007 at 21:25
Or you could upload it into members swap file, I have some mates unemployed at the moment and that could be a hole new enterprise.. :-))
Willem
just buy an old Lucals starter switch $20-30 at auto centre has all the termanals plus glo plugs (starting aids) comes with simple key same for all, have one in the tool kit all the time..
Richard
530499
Follow Up By: Willem - Tuesday, Oct 23, 2007 at 21:34
Thanks Richard but I am looking for something more Hi Tech...hahahaa
530502
Reply By: Member - Axle - Tuesday, Oct 23, 2007 at 21:05
Jumper lead direct from battery to starter, then grasp long handle screw driver, you know the rest!......lol.
But don't stall it at the lights, because thats when its a real pain in the rear!. ;)))))).
Cheers Axle.
268033
Follow Up By: Willem - Tuesday, Oct 23, 2007 at 21:32
Ahhhh you have been waiting for this one, eh?......LOL
530501
Reply By: Rock Crawler - Tuesday, Oct 23, 2007 at 21:40
why dont you pull apart the lock and seperate the rear switch part to the lock , then you can start with a flat blade screw driver from the comfort of your car . Or have you had a wiring meltdown?????
268052
Follow Up By: Willem - Tuesday, Oct 23, 2007 at 22:08
OK
Young fella I will fess up.
Few weeks ago I had a key problem. Replaced keys.
Today I had an ignition problem....ignition tumbler probably rooted.
So mate and I removed the steering lock mechanism and ignition and can now start GQ with screwdriver.
I want to take wires from this unit to switches on the dash and then reinstall the dead ignition to the column so that it looks normal.
What I need is to get advice on is which wire goes where as I have Accessories, Glowplugs, Ignition.
Can you help???
530511
Follow Up By: Rock Crawler - Tuesday, Oct 23, 2007 at 22:12
what i would do bud , is bust up the tumblers so they do nothing , then assemble it so it looks original and buy a blank toyota key that look like a flat blade to start the car, if this dosnt suit , i will get a wiring diagram to yo u
530513
Follow Up By: Rock Crawler - Tuesday, Oct 23, 2007 at 22:16
if your not replacing the lock because of the shock when nissan gave you the quote , ring ford , I did for my shorty and it was half the price , cheers
530515
Follow Up By: Nick R (VIC) - Tuesday, Oct 23, 2007 at 22:34
I got the 60 working sort of on switches and some key turning, makes for a good security system, not many people know how to start it!!!
Nick
530522
Follow Up By: Willem - Tuesday, Oct 23, 2007 at 22:37
No I am not replacing the steering lock because it is a PITA especially out bush. Didn't even contact Nissan. I want to make the truck simple to start with the aid of two or more switches.
No one is going to steal a 13yo diesel Nissan....LOL
Actually I probably know what to do just need some confirmation on which connections go where.
530524
Follow Up By: Richard Kovac - Tuesday, Oct 23, 2007 at 22:46
just put a
sign in it Please do not steal... that should do.. ;-)
530526
Follow Up By: Willem - Wednesday, Oct 24, 2007 at 18:46
Got it sorted today mate.
2 x switches and a button starter. Its all sweet.
530677
